Question about Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool Washing Machine model number GHW9300TWO,,,I am getting the error code SDL..what does this mean?
  • 87 Answers
SOURCE: Whirlpool AWM 8023 -error F06
This erroe code means drive motor tackometer error Probably a bad motor or motor drive pc board or cable problems
Posted on Jun 08, 2007
  • 183 Answers
SOURCE: zanussi washing machine
E90 is not a listed error code however most 90 range codes relate to a faulty pcb, some times worn motor brushes and blocked filter and air traps can cause some innacurate error codes being displayed we would normally check these items prior to replacing the PCB Regards Advisor
Posted on Sep 01, 2007
Master_Tech
  • 770 Answers
SOURCE: 5L error code
I will pull the book and get back to you today
Posted on Jan 27, 2008
jsrock516
  • 5911 Answers
SOURCE: Fault code C1
"C1" is known as an Instantaneous Current Limit Error. This will occur when the Motor Controller detects a current spike of 26 amps or greater at the motor windings. Overloading the washer, excessive water and/or excessive suds can cause this problem.
The manufacturer recommends the following:
- Wash smaller loads and use the correct detergent (HE only for Calypso machines). NOTE: Make sure the HE detergent is not double or triple concentrated as this will also cause suds problems.
- Check for objects under the nunate plate. This is the wash plate. Sometimes clothing can get stuck under the plate and cause the motor to bind up. To remove the nunate plate, follow these instructions:
1. UNPLUG THE WASHER.
2. Open the washer top. Look along the front seam of the washer where the top meets the front. There are a couple of retaining clips (about 2" in from each side) that you will need to push in on with a putty knife while gently lifting up on the top to get the top to release. Carefully open the top and lay it back against the wall in a resting position. Make sure you support the lid so it doesn't fall open when you tilt the top back.
3. Remove the tub ring. This is the plastic donut shaped ring that sits on top of the wash tub. There will be a tab on either side of the outer tub near the back that you can use a screwdriver to release the tub ring. The ring is filled with fluid and is used to balance the tub. So, if you hear liquid sloshing around, this is normal.
4. Remove the center cone from the wash plate. Use a flat blade screwdriver and insert it into any of the slots available along the sides. Gently pry until it pops off. I say "gently", but you may have to use a little muscle to get it to come off. Sometimes they stick. Once the center cone is removed there will be a series of nuts under it.
5. Remove the nuts and the wash plate should lift out. Be careful not to damage the gasket under it. Clothing can get tangled in the leveler under the wash plate. This leveler should have a key on it. The wash plate will only go back in with this key mating to a slot on it. So, remember how you took it off. In addition, when putting the wash plate back on, make sure you tighten the nuts in a cross pattern and evenly tighten them as you go. This will ensure the gasket seats properly. Don't forget to put the tub ring back in.
- Check for objects stuck between the inner wash tub and the outer basket. NOTE: It is best to do this with the nunate plate removed. Use a flashlight to peer through the holes in the wash basket to see if anything is catching on the tub.
- Check the Motor Controller. You will need to determine if there is power getting the the board first and that the fuse on the board is good. If any components on the board are defective, the board has to be replaced. If you have power to the board and the fuse checks good, check for continuity between the Machine Controller and Motor Controller.
There is a tech sheet inside your washer along the interior cabinet (usually the front panel) that explains all these procedures to you. I would advise you to research the tech sheet for exact locations of the pin outs for the circuit boards. Its easier for you to view it rather than me explain it. If you need further assistance, please post back and let me know. I hope this helps you.
Posted on Jul 03, 2008
SOURCE: whirlpool duet washer sport ht - error codes
FYI: The pump cleanout is located on the front of the machine, bottom right corner. There are only three screws holding the bottom cover on. It is easy to get to if you prop it up a few inches off the ground. Just thought this would be helpful as I just did this as of 5 min ago. Should take 10 min. or less.
Posted on Jul 28, 2008
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
    Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    On a Whirlpool washing machine model # ghw9150p I have error codes E01, and F08 what or how do I find diagnostic code meanings.
    go google and type in --fault codes for whirlpool washing machine model ghw 150p if one is available there will be a pdf version that you can down load
    or go google and type in --workshop manual for whirlpool washing machine model ghw 150p
    or you can make a call to an authorized service agent and ask what the codes mean
    Oct 13, 2015 | Whirlpool Washing Machines
    My Whirlpool Cabrio (Model Number: WTW6400SW2) washing machine gets an F1 error signal 5 seconds after I power it on to wash something, I have to pause it and then restart it for it to work,
    Your machine needs a new control. The F1 code is an error within the main machine control, and it will only get worse the longer it goes. CLICK HERE for the part. Using coupon code 1050 will get you a discount on the part!
    Jan 12, 2011 | Whirlpool Washing Machines
    What does F1 error mean?
    Whirlpool Cabrio F1 error code - NOW A RECALL ISSUE! model # WTW6600SW2
    Call Whirlpool or a repair center. The number for Whiripool is 1-800-253-1301
    Nov 28, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    Awo5761 front loader washing machine tells me fog on the little screen please help
    This model is incorrect...You should be able to locate the model and serial inside the door on a sticker or a plate. If it isn`t there it will be on the back of the unit. however what you are most likely seeing is the error code F06 not FOG. This error code basically means that there is an error occuring while in the spin cycle. The motor control board may have a problem as well as the motor wiring harness. I would have it properly tested by a technician to ensure a proper diagnoses.Hope this helps
    Thanks
    Nov 19, 2009 | Whirlpool Washing Machines
    Whirlpool AWM8121-The Rinse and Door open light blinks constantly
    This error code means there is an abnormality.
    If the on-off door lock LED on a Whirlpool washer flashes rapidly at the same time as at least one other LED, then this means there is an abnormality.
    Try first to reset the machine. You can press and hold the reset button for a couple of seconds, otherwise turn off the power completely (unplug it) for 5 mins.
    Mar 01, 2018 | Whirlpool AWM8123 Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    Sal De
    Gerry Harvey
    Gerry Harvey
