Question about Toshiba Satellite A200-0ET00X Notebook
My toshiba a200 does not work on charged battery ,but when plugged in it sometimes works and sometimes cuts and dies and shows flashing blue light and refuses to boot at this stag.e,can you help thanksTerry
  • Toshiba Master
  • 32,281 Answers
Whenyou connect the power adapter into the laptop, does the power LED light up? Ifnot then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Posted on Nov 13, 2010
Toshiba safelite A215-S4817
Disconnect the power. Remove the battery. Reconnect the power and see if the laptop turns on. If it works without the battery, replace the battery with a new one.
If it still does not work your laptop needs factory service.
Mar 03, 2014 | Computers & Internet
Toshiba satellite A200-27Z power cord led flasing failure to post will try any suggestions
Have you tried another Cord with the EXACT same power specs? Remove the battery. Has the cord/charger/transformer been damaged? Has the AC jack been damaged? Due to pulling on the cord while plugged in? At the AC jack "wiggle" the plug a bit to see if the plug and AC jack are making a good connection or Loose. Sounds like a loose AC connection.
Jan 10, 2013 | Computers & Internet
Toshiba a200 cant boot
You need a repair shop because with the hit some internal parts maybe are bad.
May 12, 2012 | Toshiba Satellite A200-0ET00X Notebook
Laptop Toshiba Satellite A200 Model No. PSAF6A-02C01N fail boot
Try removing / swapping / reseating the memory.
Try booting with one stick only, if the top slot doesn't work, try booting the bottom slot. Try both sticks.
Let me know what happens.
Apr 04, 2010 | Toshiba Satellite A200-0ET00X Notebook
My Toshiba Satellite Pro A200 works fine if I use a battery charged on an identical machine, with the same mains charger. With the mains charger plugged in it either shows 'plugged in not charging' or...
It sounds like the connector from the A/C adapter to the motherboard is loose or the inside of the adapter plug that attaches to the motherboard is defective.
Jan 08, 2010 | Toshiba Satellite Pro A200-EZ2204X...
Toshiba a200 flashing power light .. blue blue red red HELPPPPPPP
Remove battery and power
Remove memory in lower socket, the one on the system board and try reboot with just power cord. May have bad socket
Dec 11, 2009 | Toshiba Satellite A200-0ET00X Notebook
Toshiba Satellite A200 -AH9 Wont Turn On.
maybe you have power conection problem
your problem maybe on the circuit after the battery
so you must check your circuit
or you can contact your Laptop manufucturers
Jan 21, 2009 | Toshiba Satellite A15-S129 Notebook
Toshiba Equium A200-1VO won't turn on
Remove the power adapter and the battery. Hold the power button in for up to 60 seconds to discharge the laptop. Try starting it again.
Apr 22, 2008 | Toshiba Satellite A60 Notebook
Toshiba Satellite A200-0ET00X Notebook Logo
214 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
