Question about Sharp Microwave Ovens
We have a 1000w/R-21LV in our cafe, went to touch one of the buttons to warm up an item and it would not turn on. It's seeme like its not getting power but there is power at the plug outlet
3 Suggested Answers
01fordeb
  • 1033 Answers
SOURCE: went to warm up a food item and after 3 seconds
You have a fuse behind the screen panel. You have screws inside the microwave holding the panel. you have 1-2 at the bottom. You may also have to remove the vent. It has 2-3 screws which will be inside the vent. These can be removed from the front. Once these are removed the panel will pop off and you will see the fuse The fuse can be bought at a radio shack. BE SURE TO UNPLUG THE MICROWAVE! Good Luck
Posted on Dec 04, 2010
heatman101
  • 43501 Answers
SOURCE: GE Microwave JVM1540 will not turn on. I have
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Posted on Jan 25, 2011
My GE Cafe microwave touch pad will not work. Everything seems to be working. It is a built in , above the stove 2008 model.
Here is the information page on the repair of GE Cafe microwave ovens.
http://www.microwavecontrol.com/jvm2070.htm
For more free DIY and other help & advice, feel free to contact me with your full model number and FCC ID number from the tag on your oven.
William E. Miller, AS-EET
pupista@gmail.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 11, 2017 | GE Microwave Ovens
Amana microwave reset button?
Does the power panel have anything on it?? If not. it probably has a burnt fuse inside the unit, one year old should have a warranty on it Check out places that work on microwaves.
Mar 05, 2015 | Amana Commercial Microwave RMS10TS Touch...
Highpointe combo oven no instruction so have no way to use it can you help
Have you tried contacting Highpointe to get the user's or operator's manual? I suspect you have since I've looked and others seem to have the same problem. Is there any kind of contact information on the serial number plate or area?
If you can, call and ask them for one & tell them you never got one, or better yet, ask them why there wasn't a manual with the unit. That almost always works to get them to send one for free.
Ok, assuming none of this helps try this, I once could get no response from a manufacturer & after two weeks of trying everything I went on-line to search for the item. I found the web site of a supplier that was very positive about this particular item and so I contacted the supplier. The supplier helped me get in touch with the manufacturer and the problem was resolved to my satisfaction. Sometimes you need an intermediary and a reputable supplier is always a good one since they buy many items from the manufacturer in question.
I found this one for you but you can do a search as well, 800-776-6728 for Burnstine's Distributing. They had the following: High Pointe 1.0 CU FT 900-Watt Built-In RV Microwave w/ Turn Table and Black Trim Kit - Black (replaces EM925RSL-B) - call them & tell them your problem and see what they may be able to do to help.
Good-luck.
Jun 08, 2014 | Microwave Ovens
Will not power up after power outage
it contains two fuses one of 10 Amps and other for 500mA.
Replace 10Amps fuse with same type and rating.Best thing is to take this fuse and show it to the sale person of electronic shop.
Before you touch any parts of the microwave oven please disconnect the mains power chord and never touch the main power capacitor as this contains very high voltage even after disconnection.
Mar 24, 2014 | Whirlpool Microwave Ovens
Kenmore microwave's exterior and buttons
Hi it is quite normal for the outside of a microwave oven to get quite warm to the touch. with regard to the buttons not working; this will be due to a faulty touch panel mebrane that will need to be replaced. They are not too expensive so is a viable repair
Hope this helps
Jan 07, 2010 | Microwave Ovens
Need to find turntable mount for Emerson MW8117W Microwave
Go to repairclinic.com and type in your model number. I suspect you may be talking about item 1063610, Turntable Coupler. You may also try searspartsdirect.com. If this isn't the part you need, please post back and provide more information, so that I may assist you better. I hope this helps.
Jan 04, 2009 | Emerson Black Microwave Oven
Error Code
I would recheck the control board installtion that you made, as well as verify that you got the correct replacement. Also the board may contain static sensitive componets so you might want to make sure you are grounded when handleing the control panel. Good luck
May 14, 2008 | KitchenAid KHHS179LSS Convection /...
Microwave buttons not responding - microwave running constantly with door shut
It seems the micro switch for the door close have moved from and is not aline the door clip or the micro switch is faulty
Dec 17, 2007 | Sanyo EM-S9515W Microwave Oven
Microwave Ovens Logo
114 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
