Question about Asko D1716 Built-in Dishwasher
My Asko dishwasher starts, drains, fills with water, then stops before it starts to spray/ spin. What is wrong?
  • Asko Master
  • 12,061 Answers
Http://www.askousa.com/customer-care/technical_documentation/
Well what is wrong unfortunately could be any number of things, it is well with this symptom anyway, pretty hard to tell exactly what's wrong by just this symptom. If it Fills Drains then the In & out are OK, so it must be some controller input problem?
If it is filling with water and then doesn't proceed then it is most likely a sensor or similar, one must perform the necessary troubleshooting steps to isolate and repair this unit. To do this one requires a service manual, Asko, service data is very hard to come by, for some reason. Above, is a support link for Asko.
You best bet will be to contact Asko,and ask them for a referral to a local service agent, now when he calls, ask him for a 'Quote" before allowing any repair work to be undertaken.
Posted on Nov 15, 2010
Not finishing cycle
Is it draining out the water?? Dishwashers fill, spray, and drain more than several times during a cycle. After starting a cycle, let the unit fill, start spraying, and then cancel the cycle--listen for the drain pump activating and pumping out the water. If water is not being drained properly(within a certain time limit), the unit will error code out and stop. Also, make sure the filter is clear--if it gets clogged with "muck", enough water won't be sprayed onto the dishes properly, the pump will require too much energy to try to pump water, the control will sense this and shut down the unit to protect it.
Jul 25, 2015 | KitchenAid KDHE704DSS 24 6-Cycle/7-Option...
Hi, my D3120 Asko dishwasher starts but stops after about a minute. If I press the start button again, it starts but stops again. What's wrong?
When it shuts off, is there still water standing in it? First, you need to know if it stops because the pump (that pumps OUT the water) is working. When it stops, do you hear the water draining? ...(through your sink drain). Many times the tube that pumps out the water is clogged from food matter stuck in the drain tube. If you had a disposal put in recently, there is a plug that has to come OUT of the disposal to hook up the dishwasher drain.
Jan 02, 2015 | Dishwashers
Water drained out of tube, but dishwasher stops and indicators tell me "drain is plugged."
The drain hose on a dishwasher must be long enough to go up above the water level of the dishwasher and then back down to connect to the sink drain. This is to keep gravity from draining the tank. However, you probably replaced the drain hose the same way it was originally.
Try checking the float and float switch for smooth operation. Maybe the float has debris holding it up from dropping to the true water level.
Jan 10, 2014 | Asko 24 in. D3450 Dishwasher
I have an asko d3251 dishwasher that won't stop running. The device in the drain that spins won't stop. I had to shut the power off to the unit.
Our unit had leaking connection on outlet side of fill solenoid valve. Any leak will cause water to accumulate in base pan. there is a float switch in base pan as a safety mechanism when water is in pan it causes a styrofoam float to rise and make contact with switch. This tells machine there is a leak creates error code to run pump continuously until water is removed from base. Disconnet electric from unit first. you must pull dishwasher out to get at back panel. Remove lower back panel to get access to mechanicals of unit. Once you remove panel you should see water in pan. If you see water that is most likely same issue we had. soak up excess water or tilt unit to drain water out of pan. once water is gone unit should start normally. If you look underneath while unit starts up - don't touch anything while unit is connected to electricity! You should notice where water is coming from. Our unit leaked at hose connection from outlet side of solenoid fill valve. connector is a plastic cam-lock fitting with a flow sensor integrated into it. there is an o-ring between the two parts. it comes apart with a very small amount of counter-clockwise motion. perhaps only five or ten degrees of indexing and it falls right off. it is a very flimsy connection for the main water line. the o-ring on our unit Was slightly deformed and not seated correctly. could have been from original installers 4 years earlier! Asko needs to re-design this part. I replaced o-ring and unit is working again however I do not trust that this fitting will hold up over time. Very poor design in my opinion. Other design flaw I noticed while looking at mechanicals is circulating pump isolation mount is not in correct location for pump motor. rubber mount is stressed to the point of almost tearing off! No way for me to correct this since location of mount does not match position of motor. We will not replace this unit with another ASKO when it goes.
Jan 19, 2013 | Asko D3251HDSS Stainless Steel Built-in...
I have an asko 11505 clothes washer. For some reason, it is not going through all of the spinning cycle, it spins for a short time, then stops abrutely. I cleaned the coin stop, cleaned out all water...
My Asko 11505 washer fills only a little water then shuts off. If I drain the washer with the drain hose from under the machine, then the machine will start up and fill enough water to fill the hose again, then shut off.
Oct 19, 2009 | Asko Washing Machines
Water won't spray
Sounds like whatever caused the clogged drain may also have clogged the sprayer arm.  If it is clogged it will not spin.  Remove the arm and if it is clogged see if you can clean it out.
May 29, 2009 | Asko D1776 Stainless Steel Built-in...
No water sprays after resetting an F2 fucntion problem
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Dishwasher overfilling
I have been working on ASKO for several years and have never seen one fill and drain at the same time. Usually if it drains and cannot be stopped, it is because there is water in the lower tray that needs to be removed or left to evaporate, and then it needs to be figured out why the water was there in the first place. If you could post back with more info (does it fill, sit for a while, then drain, or is it doing both at once) I would be glad to help. Good Luck!
Oct 18, 2006 | Asko D1776 Built-in Dishwasher
Asko D1716 Built-in Dishwasher Logo
201 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
