Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
What is the problem when F1 flashes - Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
  • Fisher and P... Master
  • 3,247 Answers
This will depend on whether F1 is flashing on both drawers or just one (which one).
F1 flashing in both drawers means there is water at the base of the housing which had triggered the flood switch. you will have to get the bottom drawer out and dry the base with towels and hair dryer. Make sure the power is turned off. Need to find the cause of the water leak. Could be drawer seal, broken hose or too much foam in detergent.
If F1 is coming in one drawer and the other drawer has blank display. The power is lost to the drawer with blank display. Could be thermal fuse blown or problem with power board at the base.
Hope this helps.
Posted on Dec 02, 2010
What does f1 mean when it flashes where the temp guage is?
It means you have a problem with the fuel injection system if you can start the bike then take it to a Suzuki mechanic. If the F1 is full on i.e.not flashing then the bike will not start normally. You still have a fuel system problem but now you have to find a way of getting it to a Suzuki mechanic. You should have a red light showing near the neutral indicator light.
Jul 14, 2014 | 2004 Suzuki GSX-R 600
Honda cb1300
Generally the F1 flashing is the code either current or historic. You should count the number of flashes. That used to be the way we would read the codes.
Nov 30, 2013 | Motorcycles
I have a Whirlpool Cabrio top load washer. When I load the clothes and start the washer and it begins to run I hear an alarm, it stops and a F1 flashes on the display. What does this mean?
F1 (F60-68)
Primary Control Failure F then 1 flashes when there is a primary control failure. Replace the machine control assembly.
See Accessing & Removing the Electronic Assemblies.
F1 flashing on the display indicates a primary control failure.
"F then 1 flashes when there is a primary control failure. Replace the machine control assembly."
The link below lists Cabrio failre codes.
http://www.advantagesupplyfl.com/WhirlpoolCabrioWasherFaultCodes.html
Dec 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 keeps flashing and beeping
you can google your oven model for its codes. on our maytag oven the F1 code means defective touch pad or control board.
Jun 21, 2010 | GE Profile JT952 Electric Double Oven
Dishwasher keeps flashing F1
F1 on your dishwasher is the fault code for leaking inside the machine. the water has caused the flood switch to activate. have you put any detergent rather than your normal dishwasher detergent into the machine? if you have, the water probably leaked out of your overflow, if not, then you have a leak on the top drawer or bottom drawer. the easiest way to check is to leave the machine off for a couple of days until it drys then turn on the bottom drawer to go thru a cycle.if the F1 comes up again then the problem is on your bottom drawer. if F1 does not come up then try the top drawer. please reply if you require further help.
May 28, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 appears both drawers are flashing and beeping can't turn off power (it turns off for a moment and then turn itself back on with F1 code, beeping and flashing) Unplugged it hoping it would reset, it did...
F1 means that the flood sensor has been tripped. Remove the bottom draw and dry the water out. Mop the majority out and use a hair dryer to get it all nice and dry. This should clear the f1. There may be underlying issues of why the unit has leaked but see how you get on.
Dec 12, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Both drawers are flashing and beeping, displaying Answer Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If... (More) Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Sep 23, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Maytag MER5770AAW Oven
f1 is a bad range control/ touchpad, here the part number for a white clock for model number MER5770aww 74008106 approx 150 bucks
Apr 08, 2008 | Maytag MER5770 Electric Kitchen Range
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
134 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
