Question about Vacuums
The machine says ready to brew. I close the lid and it says brewing but nothing happens. The machine is 2 months old (Keurig B70 Platinum). No pump sound. Water is fine. Have cycled power.
    Top Expert:
  • Vacuums Master
  • 75,797 Answers
Hello, my advice is do not attempt to fix anything, return the machine for warranty adjustment. If you try to repair it this will void the manufacturers warranty and you will be out a coffee maker, make them honor the workmanship of their products!
Posted on Nov 13, 2010
Won`t brew coffee sez De Scale
Here is a tip that I wrote that goes into detail about how to descale yourKeurig Coffee Brewer
How toDescale your Keurig Coffee Brewer
heatman101
Aug 24, 2011 | Vacuums
My Keurig coffee maker is not brewing. The word prime is on the screen. How do I prime the unit.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jul 14, 2011 | Vacuums
Shows that it is ready to brew, but says "de scale"
What model do you have? I'm guessing we are talking coffee maker, is it a Keurig? If you're getting a message saying to "de-scale" it need a good cleaning. That's usually the issue & the quickest fix. If the Keurig (or any other coffee maker) gets lime/calcium build up on the internal components it will ignore whatever has been programmed into it & just keep cutting off or keep making partial cups. Run some white vinegar thru it - fill the reservoir with a strong vinegar/water mix, remove any kcups/my kcup or filters, also remove the reservoir carbon filter ( fyi - that's not going to eliminate any lime/calcium in your water - it's just to eliminate any bad tastes/odors) and "make" how ever many cups it takes to empty the reservoir. Depending on the build up - you may need to do this 2 or 3 times. Also run about 2 more reservoirs of just clear water to help rinse out the vinegar mix (otherwise your next cup of coffee will not be what you expected).
This should eliminate your problem & should be done every 2-3 mths, regardless of whatever the model of coffee maker you have. Good Luck.
Jul 08, 2011 | Vacuums
It wont brew
heatman101
May 17, 2011 | Vacuums
Cannot get the brewer component out of the machine to clean out the dreg tray in the Coffee machine - instruction manual is very unclear and poorly translated.
The brew group could be out of alignment. Perhaps try turning the machine on, then close the service door. The brew group should realign automatically, allowing you to then remove the dreg drawer (tray).
Try removing the brew group after the drawer is out of the way.
May 11, 2011 | Vacuums
Keurig model B40 How do I empty the resevoir , I can empty the cold watet tank. We are moving so need to completely empty all water.
The water reservoir lifts out. There are two tabs on the side which lock it in place. You may have to pres on them to remove it. If you are wanting to completely empty the entire machine, I have found an instruction manual and have instructions for purging: Fill reservoir with clean water and replace on machine with lid on it. Raise and lower handle without K cup inserted. Wait for the red light next to "heating goes off.
The blue lights on the control center will begin flashing. Put a cup on the drip tray and press "Brew"
When finished, repeat brew procedure 2 or 3 times and inner tank should be empty.
Hope this helps, if it does, please place a vote for me.
Good luck with your move,
Handie Andie
Mar 28, 2011 | Vacuums
I have a Hamilton Beach 6 cup brew station and it has stopped taking the water from the tank and making any coffee. It just sits in the tank making noise like it is working but nothing happens. Thanks...
unplug it,empty contents
put 2 cups white vinegar in tank , plug in and start brew cycle.
discard vinegar and run 2 tankfuls of water through to remove vinegar taste
Jan 08, 2011 | Vacuums
I have the superautomatica saeco vienna machine and am tryi8ng to clean the 2 steel filters of the brew group by unscrewing the pin. I find 1 steel screen but not the second one. Where is it?
Hi, looking down into the brew group you see the bottom filter, looking on the side with the piston (o-ring) you see the second metal filter on the bottom of the piston.
Dec 30, 2010 | Saeco Vacuums
Cleaning mr coffee ecm3 how
Deliming
SUGGESTED CLEANING SCHEDULE
Type of Water Cleaning Frequency
Soft water every 80 brew cycles, Hard water every 40 brew cycles
Your espresso maker may be delimed using one quart of white household vinegar. Clean the water tank first, following steps l-5:
1. Make sure the steam control knob is in the center off position and that the plug is disconnected from the electrical outlet.
2. If the machine is cool and the pressure has been released, remove the pressure cap and pour 10 ounces of undiluted white household vinegar into the water tank.
3. Screw on the pressure cap and allow machine to sit overnight with the vinegar solution in the water tank.
4. Remove pressure cap and discard vinegar through the top opening of the espresso maker.
5. Rinse the water tank thoroughly with tap water, repeating this step twice.
To wash internal parts:
Make sure you clean the inside of the water tank first. Remove the pressure cap and pour 10 ounces of fresh white household vinegar into the water tank. Screw the pressure cap back on top of the water tank. Make sure the cap is on tight. Insert the filter holder into the brew head and place the glass decanter with lid on the drip tray. Plug the machine into the electrical outlet and turn the power switch on. An indicator light on the power switch will tell you the machine is on. Place a cup with cold water under the steam nozzle. When vinegar begins to flow into the decanter, insert the nozzle into the water and open the steam nozzle slowly by turning the steam control knob downward. After a few seconds, close the steam nozzle by turning the knob back up to center. This will clean any residue left in the nozzle from frothing milk. When all the vinegar has been pumped into the decanter and the flow has stopped, turn the power switch to the center off position and allow the machine to cool. Repeat steps 1-7 twice using only tap water to rinse any remaining traces of vinegar out of the machine.
Decanter cleaning
1. Pour warm white vinegar in the decanter and let soak for 20 minutes.
2. Discard the vinegar, Wash and rinse the decanter thoroughly using a
soft cloth. Do not use harsh abrasive cleaners.
Dec 12, 2010 | Vacuums
Vacuums Logo
69 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
