Question about Refrigerators
Ice maker cubes tasty yucky.. water from faucet taste normal. put new inline filter and still taste yucky. this has been few months ago. help.
IFIXALL
  • 868 Answers
SOURCE: ice maker's ice taste funny
You may consider pulling out the ice maker and tossing it in the trash if you look at it and see that where the ice sits it's corroded or its close to a 10 year old in age (IT'S DUE TO GO OUT ANYWAY).Other than that:you have a 3% chance that the tube that goes to your ice maker is bad. Please Rate This !
Posted on Jun 12, 2008
  • 399 Answers
SOURCE: Bad water & ice cube taste
the feed line of the water source is bad replace it you will also need to clean the ice makers insides to remove the rest of the contamination
and 2 more suggestions:1) change the filter - older refers have the filter in the water line serving the ice maker - newer refers have the water filter in the refer (it looks much like an auto oil filter); 2) do not store ice for extended periods when ice use is not high e.g. during cooler months. Unless you use a full basket of ice over say a few weeks you should dump all and start over periodically.
thanks.
Posted on Sep 16, 2008
huuum
  • 750 Answers
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Posted on Oct 12, 2008
philbran
  • 242 Answers
SOURCE: Ice tastes bad from ice maker
Sometimes filters have issues like this even being new , it is located at the bottom kickplate [round] , pick up a new filter -part number 4396841 - install the filter , dump remaining ice in bin out , purge the water through the new filter through water in door for a few minutes and you should be good.
Phil
Posted on Apr 14, 2009
  • 9 Answers
SOURCE: ice maker water taste like chlorine but tap tastes fine
Put a in-line water filter on the water line if you want. The taste is from the food and items you have in the refrigerator. Clean it out and keep your items in proper storage. Ice collects the smells in the line and the fridge. Change your ice that is sitting in the bin, wask out the bin with water and baking soda. Hope this helps.
Posted on May 01, 2009
Whirlpool ED25RF Does ice maker have a filter? My ice taste funny and sometimes its dirty
The ice maker doesn't have a filter , the problem could be the ice maker itself that the tray ,which is made out of aluminum is losing particles.Look at the conditions of the ice maker tray ,if you see like white spots replace the ice maker.
Aug 30, 2009 | Whirlpool Refrigerators
How do i get clean ice cubes from frigidare?
In order to get as clean an ice cube as possible, it all depends on the quality of the water that goes into the ice maker. If you have a water softener, your cubes will always be a bit cloudy, since the added salt slows down the freezing slightly and thus the cubes get cloudy.
That said, there are a few things you can do to improve your water. Adding a whole house water filter with a sediment charcoal filter, will remove the impurities and help to improve the overall taste. Then add an inline charcoal filter on the water line into the fridge. That will filter your water a bit more and help further improve the clarity and taste of the cubes.
Beyond that, you might want to look into a reverse osmosis system to really get the best possible tasting water you can.
The old adage of "garbage in, garbage out" is a good analagy for water quality issues, so you need to figure out what's in your water in order to take the steps to treat your water for the best possible results.
I recall that Sears offers free water testing (to help sell water softeners) so that's an option, as well as getting a home water test you can perform yourself.
Hope that helps you with your situation. Best regards!
Jul 31, 2009 | Frigidaire FRT17G4B Top Freezer...
Ice from ice maker taste bad and can not find a water filter on it.
I would install a filter inline on the water filter I have one under the sink and on the ice maker
Apr 14, 2009 | Refrigerators
Phil
Apr 14, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice from ice maker does not taste right
Hi
Ice storage bin needs to be emptied and washed. Unsealed packages in the refrigerator and/or freezer compartments may be transmitting odors/tastes to the ice cubes.
Interior of the refrigerator may need cleaning.
Water chemicals. Installing an in-line filter can help with many odor/taste complaints.
An open box of baking soda in the refrigerator section can help with preventing the transmitting of food odors.
This is a common in-line water filter, they are fairly easy to install and usually come with instructions.
Even when your well or municipal water supply provides healthy, potable water to your ice maker, some impurities may remain. These can affect the smell or taste of the ice cubes, and therefore the beverages in which you serve them. A taste and odor water filter on the incoming water-supply line--such as our charcoal "Universal Replacement Water Filter"--can help a lot.
Also, over time, the ice cube bin can absorb difficult-to-remove odors from the freezer. Some manufactures recommend that you replace the bin every 2 to 3 years, whenever it seems to be retaining objectionable odors and transferring them to the ice cubes.
A Fixya Rating would be appreciated.
Thanks
Rylee
Feb 11, 2009 | Whirlpool ED2GHEXN Side by Side...
ICE CUBE MAKER SMELLY ICE CUBES
your model will have a filter for it. it is located usually on the fridge side torwarss the top back of the fridge. it sounds like you need to replace the filter. it needs to be replaced every 4 monthes or so to keep the water clean. also you may put some water in a cup from the tap/faucet and make sure it is not the water it's self. if it is you may want to think about also having a water filtration system installed in your home.
Jan 07, 2009 | Refrigerators
then change your filter. the new filter could be different with the old filter. check the new filter, see if there is odor removal and taste removal with it.
if not then get the filter with carbon filter, odor and taste removal.
then with a new filter, run about 5 gallons of water before using the water for drinking.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Hello redwood City
Welcome
You said,
copper tubing."
Whirlpool remedy
Thank You ,
HUUUM!!
Sep 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
thanks.
Sep 16, 2008 | Refrigerators
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
