Question about Dell Dimension E510 PC Desktop
I'm getting a disk read error on my dell e510 desktop computer?? I hit ctrl+alt+del as advised and it takes me back to the disk ead error page. I also tried the f11 11 dignostic and it says drive 1: no device??? Help !!
sandrew
  • 2961 Answers
SOURCE: PC disc read error with my hard drive
this is a sign that either you hard drive is about to fail, or there is a corrupt sector on it. Next time you boot up the pc go to my computer, right click and explore, then right click on the 'C' drive and select properties, then at the tools tab at the top of the window select error checking and click check now. The pc will probably need to restart to do the check. Back up any important docs as it may be aboit to fail.
Posted on Jun 27, 2007
melnavz
  • 1226 Answers
SOURCE: A disk read error occurd
Try to open the CPU casing and then try to refix all the connection inside ..maybe it just a loss connection.
if the same error then try to go to bios setup and then load the bios setup default and then save and exit and let the computer restart.
melnavz
Posted on Nov 25, 2008
rockitman187
  • 2559 Answers
SOURCE: NTRL is compressed Press Ctrl+Alt+Del to restart
First you need to boot to the recovery console.
To boot to the recovery console follow these steps:
1. Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer. Click(or press any key) to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3. When prompted type "1" or if you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4. When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5. Now you should be at the comman prompt and ready to repair the ntldr file!
Now all you need to do is enter the following commands(in order) and each command on a new line just like you see them here:
cd \
attrib -c ntldr
exit
Your computer should now reboot, and everything "should" work!
Please rate this fixya
Posted on Jan 26, 2009
SOURCE: ntldr is missing press ctrl alt del to restart cant install o/s
This problem may occur if the basic input/output system (BIOS) on your computer is outdated, or if one or more of the following Windows boot files are missing or damaged: Ntldr
Ntdetect.com
Boot.ini To resolve this issue, verify that the BIOS on your computer is current, and then use one or more of the following methods, as appropriate to your situation, to repair the Windows 2000 startup environment.
Verify That the BIOS on the Computer Is Current loadTOCNode(3, 'summary'); Make sure that the latest revision for BIOS is installed on the computer. Contact the computer manufacturer to inquire about how to obtain, and then install the latest BIOS update that is available for the computer.
Method 1: Use a Boot Disk to Start the Computer loadTOCNode(3, 'summary');
  1. Create a Windows 2000 boot disk that contains the following files: Ntldr
    Ntdetect.com
    Boot.ini
    Ntbootdd.sys For more information about how to create a boot disk, click the following article numbers to view the articles in the Microsoft Knowledge Base: 301680 (http://support.microsoft.com/kb/301680/ ) How to create a boot disk for an NTFS or FAT partition in Windows 101668 (http://support.microsoft.com/kb/101668/ ) How to use a Windows boot disk to prevent boot failure
  2. Modify the Boot.ini file to point to the correct hard disk controller and to the correct volume for your Windows installation. For more information about how to create a boot disk, click the following article number to view the article in the Microsoft Knowledge Base: 311578 (http://support.microsoft.com/kb/311578/ ) How to edit the Boot.ini file in Windows 2000
  3. Insert the boot disk into the computer's floppy disk drive, and then restart the computer.
  4. Copy the Ntldr file, the Ntdetect.com file, and the Boot.ini file from the boot disk to the system partition of the local hard disk.
Method 2: Use the Recovery Console loadTOCNode(3, 'summary');
  1. Use the Windows 2000 Setup disks to restart the computer, or use the Windows 2000 CD-ROM to restart the computer.
  2. At the Welcome to Setup screen, press R to repair the Windows 2000 installation.
  3. Press C to repair the Windows 2000 installation by using the Recovery Console.
  4. Type the number that corresponds to the Windows installation that you want to repair, and then press ENTER. For example, type 1, and then press ENTER. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 229716 (http://support.microsoft.com/kb/229716/ ) Description of the Windows Recovery Console
  5. Type the Administrator password, and then press ENTER.
  6. Type map, and then press ENTER. Note the drive letter that is assigned to the CD-ROM drive that contains the Windows 2000 CD-ROM.
  7. Type the following commands, pressing ENTER after you type each one, where drive is the drive letter that you typed in step 4 of "Method 2: Use the Recovery Console," of this article: copy drive:\i386\ntldr c:\
    copy drive:\i386\ntdetect.com c:\If you are prompted to overwrite the file, type y, and then press ENTER.
    NOTE: In these commands, there is a space between the ntldr and c:\, and between ntdetect.com and c:\.
  8. Type the following command, and then press ENTER: type c:\Boot.iniA list similar to the following list appears: [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINNT [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect If you receive the following message, the Boot.ini file may be missing or damaged: The system cannot find the file or directory specified.
  9. If the Boot.ini file is missing or damaged, create a new one. To do so, follow these steps:
    1. Use a text editor, such as Notepad or Edit.com, to create a boot loader file similar to the following boot loader file: [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINNT [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect For more information, click the following article number to view the article in the Microsoft Knowledge Base: 102873 (http://support.microsoft.com/kb/102873/ ) Boot.ini and ARC path naming conventions and usage 301680 (http://support.microsoft.com/kb/301680/ ) How to create a boot disk for an NTFS or FAT partition in Windows
    2. Save the file to a floppy disk as Boot.ini.
      NOTE: If you used Notepad to create the file, make sure that the .txt extension is not appended to the Boot.ini file name.
    3. Type the following command at the Recovery Console command prompt to copy the Boot.ini file from the floppy disk to the computer: copy a:\Boot.ini c:\
  10. Type exit, and then press ENTER. The computer restarts.
Posted on Jul 07, 2009
kpkelly703
  • 4 Answers
SOURCE: Computer will not re-boot
TRY RESTARTING YOUR COMPUTER IN SAFE MODE ( TAP f8 AS SOON AS YOU TURN IT ON AND UNTIL IT SAYS SAFE MODE) THEN CLICK ON TO LAST GOOD KNOWN START UP
Posted on Oct 07, 2009
Read disk error press ctrl alt del restar
this problem often is fatal.. you could either try changing the IDE cable or the hardisk itself.. if you have spares.. but IDE type is not manufactured already..
Dec 19, 2013 | Dell OptiPlex Computers & Internet
"A disk read error occurred Press Ctrl+Alt+Del to
Most likely the hard drive is failing, run diagnostics on the hard drive if you have a resource CD. Or you can download them from support.dell.com
Jul 21, 2011 | Dell Latitude C810 Notebook
Hello, While trying to boot up, I received the message, "disk read error occurred. Press ctrl+alt+del". The same message appears after I press ctrl+alt+del. What can I do to resolve the issue? Thank...
This is called a disk error which generally means your disk has failed. You need to get your data off it if it is not backed up. You will have to replace the disk.
A local computer shop might, just might, be able to install it into a second computer and read the data. The more you fuss with it the lower your chances of getting any data off it.
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Sep 16, 2010 | Dell Dimension 4500 PC Desktop
THE COMPUTER GOES THROUGH THE STARTUP SCREEN AND THEN SAYS DISK READ ERROR PRESS CTRL ALT DEL TO RESTART AND THAT'S AS FAR AS IT GOES
This show that the disk has much bad sector and that was the extent the system could read. Replace the disk and reinstall your application slave the faulty disk to the system to see if you could recover some of your file on it.
Dec 28, 2009 | Dell Dimension E520 PC Desktop
I have a optilex 170l dell computer i replaced the hard disk and now i gives me a disk read error occured press ctrl+alt+del to restart
Press ctrl+alt+del to restart is just an instruction. Did you do it?
What happened? Was it read? Tell us more. Send your e-mail for
us to give you our feedback.
By the way, assuming that it did not work, Your hard disk must be
configured to your PC, by running a software driver for your new hard
disk. You can download it from the internet by running search " hard
disk driver". Just specify the brand.
Oct 17, 2009 | Dell Computers & Internet
When i turn on my computer,it goes to a "error reading disk message",hit ctrl,alt and del,when i hit that it goes right back to the above message
Use your windows CD and do a repair install of the operating system. If you have a recovery partition you can simply do a system restore to a date before this happened.
Dec 17, 2008 | Computers & Internet
Problem with a disk read error
There are a couple of possibilities.
1. The hard drive is defective.
2. The operating system is corrupt.
The easiest way to test this is to run the restore cd that came with the computer to reload Windows.
If you get this error while running the restore cd then you will need to get a new hard drive.
Jan 03, 2008 | Computers & Internet
Dell Dimension E510 PC Desktop Logo
105 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
