Question about Samsung TV Remote Control
The Remote for my Samsung Series 5 530 LCD TV will only activate the power ON (and OFF) button -- nothing else. I've replaced batteries -- no difference, My TV is 15 months old, and this is the original remote. I changed batteries several months ago.
SOURCE: Samsung TV remote control
I HAVE THE SOLUTION TO THIS PROBLEM.
Confirmed with Samsung tech support. Problem is with remote. to fix, simple take the batteries out of the remote. Press and hold the UP Volume button for 2 Mintues (no cheating, it has to be at least 2 minutes), this Reset's the Remote Control. Put the batteries back in. Bob's your uncle. all fixed.
Posted on Jan 26, 2008
SOURCE: remote control
I had the same problem.  The problem is strange and seems to be with the receiver in the TV and not the remote control.  The reason I say this is that when this first happened my Samsung brand DVD could actually control the TV.  This then also failed, but still works fine with the DVD player.
Anyway there is an even more bizarre fix to all this......
- Remove the batteries from your TV remote. - Press and hold the red (ON/OFF) button for at least 1 min. - Replace the batteries and hey presto!!
I know seems far fetched but I found it on the Samsung website and it does work.
Posted on Mar 30, 2009
SOURCE: bn59 00463 volume works nothing else cant turn on
Step 1: Remove the batteries
Step 2: Press the power button (red button) on the remote control 5 times.
Step 3: Replace the batteries and your remote should work fine.
Posted on Oct 27, 2009
SOURCE: We have an AK59-00104R remote
To program this Samsung remote to work with a TV, press the TV POWER button on the remote while entering a manufacturer specific code into the remote at the same time.
1. Switch the TV on. 2. Point the remote towards the TV. 3. Press and hold the TV Power button and enter the two-digit code for that brand of TV. If the code is compatible, the TV will switch off. 4. There may be more than one code for that manufacturer, so try them all until one works.
For Samsung TVs, one of the following codes should work: +01 +02 +03 +04 +05 +06 +07 +08 +09
Posted on Jan 29, 2011
  • 1335 Answers
SOURCE: my samsung remote BN59-00852A just stopped
Try the instructions below. If you need to replace the remote, you can order one from:
http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=BN59-00852A&uuid=12967730823440
Before replacing the remote, try the following:
How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck!
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote. If you do then the problem might not be the remote but the sensor on the TV unit.
Let me know if you have further questions. Please make sure to rate this solution. Thanks.
Posted on Feb 03, 2011
May someone please send the service mode specifications for a Samsung LED 40 inch TV UA40EH5000R?
I don't have service mode specifications but I do have a Samsung and looked around for how to get it in service mode some time ago because the HDMI cables somehow disconnected themselves a lot. Thought it was an electronic problem but it turned out to be a parenting problem instead SO I have never used this information and can not vouch for it. I cut and paste it from a note I copied from a forum entry to use at your discretion:
First post:
To enter "Service Mode" Press the remote - control keys in this sequence :
From Standby Info-Menu-Mute-Power On
- The buttons are active in the service mode.
Remote - Control Key : Power, Arrow Up, Arrow Down, Arrow Left, Arrow Right, Menu, Enter, Number Key(0~9)
Careful though there are things you shouldn't touch in this menu.
avforums.com/forums/lcd-led-lc­d-tvs/601553-samsung-service-m­enu-research.html
Another post:
Method 1
Put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu.
Method 2
Turn the power off. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
Method 3
With the TV in standby, press the {DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Method 4
With the TV in standby, press the {SLEEP} {P.STD} {MUTE} {POWER} on the remote.
Method 5
With the TV in standby, press the {DISPLAY} {MENU} {MUTE} {POWER} on the remote.
Method 6
With the TV in standby. On the remote, press Mute followed by 1, 1, 9, Enter in sequence.
Samsung LCD Monitor Service Menu Instructions
End quote.
Good luck. Just a basic suggestion you probably don't need: keep track of any changes made by writing them down so you can put it all back if you have to.
Dec 20, 2014 | Samsung Televison & Video
Tip
Input Switching issues Harmony Remote and Samsung TVs
The following 2008 Samsung TV’s have Anynet+:
LCD
All 9 Series LCD TVs (LNxxA950)
All 8 Series LCD TVs (LNxxA850, LNxxA860)
All 7 Series LCD TVs (LNxxA750)
Most of the 6 Series LCD TVs (LNxxA650, LNxxA630) excluding the 19” and 22” models
All of the 5 Series LCD TVs (LNxxA550, LNxxA540, LNxxA530)
Most of the 4 Series LCD TVs (LNxxA450) excluding the 19”, 22”, and 26” models
Plasma
All 7 Series Plasma TVs (PNxxA750, PNxxA760)
All 6 Series Plasma TVs (PNxxA650)
All 5 Series Plasma TVs (PNxxA550, PNxxA530)
Half of the 4 Series Plasma TVs (PNxxA450) excluding the 410 line (PNxxA410)
DLP
All 7 Series DLP TV’s (HLxxA750)
All 6 Series DLP TV’s (HLxxA650)
All 5 Series DLP TV’s (HLxxA510)
2007 Samsung TVs With Anynet+
The following 2007 Samsung TVs have Anynet+:
Note: Excluding all 26" models and below.
LCD
All 81F series (LN-Txx81F)
All 71F series (LN-Txx71F)
All 65F series (LN-Txx65F)
All 61F series (LN-Txx61F)
All 53H series (LN-Txx53H)
Plasma
FP-T5084
FP-T6374
HP-T4254
HP-T4264
HP-T5054
HP-T5064
DLP
All 89S series
HL-Txx89S
HL-T7288W
Information on Samsung TVs that support AnyNet has been refered to from: http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view.jsp?isARS=Y&SITE_ID=1&AT_ID=18104&ARS_ID=8514159
How To Disable Samsung Anynet+ so your Harmony Remote Control properly controls your devices. This mainly impacts Input Switching.
1) Press your Tools Button.
2) Scroll down to Anynet and press your Select Button.
3) Once on the Anynet screen, please press your Left/Right Button(s) to select the Off Setting on the Anynet+ (HDMI-CEC)
4) Scroll down to the Auto Turn Off and select No.
Once this is completed, please turn off your TV and all device and power them back on using the Harmony Remote. Also please test this in the Activities mode, if this does not work, let me know
on Feb 10, 2010 | Logitech Harmony 520 LCD Remote Control
Tip
Input Switching Issues with Harmony and Samsung TV's
LCD
Plasma
DLP
LCD
Plasma
FP-T5084
FP-T6374
HP-T4254
HP-T4264
HP-T5054
HP-T5064
DLP
All 89S series
HL-Txx89S
HL-T7288W
Once this is completed, please turn off your TV and all device and power them back on using the Harmony Remote. Also please test this in the Activities mode, if this does not work, please e-mail us back for further assistance.
on Feb 10, 2010 | Logitech Harmony 880 LCD Remote Control
Samsung DVD Player remote buttons activate Samsung TV settings
To do a reset of the remote control follow the instructions below.
1. Remove the batteries from the remote control.
2. Hold down the Power button for a full minute.
3. Once done, put the new batteries back in and test the remote control. Please power cycle the unit as well by unplugging it from the wall and leaving it of for a couple of minutes. Once done, test the remote control again. To delete the recorded programs, please follow the steps below
1. Press the BD button on the remote control then press Home. This should bring up the home screen.
2. On the Homescreen, choose AllShare Play and press the Enter Button.
3. On AllShare Play, scroll down to Recorded TV and choose ''HDD''.
4. Now the titles of the recorded programs will appear.
5. Press the Tools on the remote control and select ''Delete'' from the side menu.
6. Select the titles to be deleted by highlighting them, then press the Enter button on the remote control.
7. Select ''Delete'' from the side menu then confirm deletion.
To try and resolve this issue, please reset the remote control. To do so, please refer to the instructions below: 1. Remove the batteries from the remote control. 2. Hold down the Power button for a full minute. 3. Once done, put the new batteries back in and test the remote control. Please power cycle the unit as well by unplugging it from the wall and leaving it of for a couple of minutes. Once done, test the remote control again. To delete the recorded programs, please follow the steps below: 1. Press the BD button on the remote control then press Home. This should bring up the home screen. 2. On the Homescreen, choose AllShare Play and press the Enter Button. 3. On AllShare Play, scroll down to Recorded TV and choose ''HDD''. 4. Now the titles of the recorded programs will appear. 5. Press the Tools on the remote control and select ''Delete'' from the side menu. 6. Select the titles to be deleted by highlighting them, then press the Enter button on the remote control. 7. Select ''Delete'' from the side menu then confirm deletion.
Jun 27, 2017 | Samsung LA40A550 40 in. HD-Ready LCD TV
My LCD TV Series 530 keeps on blinking and would not turn on. why does it keep doing that?
I've experienced similar issues with a 42" Samsung LCD TV. From what I've read online, I believe it could be a problem in the circuitry of the power supply. Apparently, Samsung used under rated capacitors in the power supply and the result is a turn on delay or blinking on and off. If this is the case, then the capacitors would need to be replaced to fix the issue.
Aug 07, 2011 | Samsung Televison & Video
I have a Samsung LN40c530F1F and I accidentally pressed the button below the power button labeled "DVD receiver/TV" and now nothing works at all on the remote. I have tried re-pressing the...
Take the battery out like about hour for a hard resetting.After putting the battery back in u should push the button that said TV only.The remote should be functions again for the tv again.
Jun 18, 2011 | Samsung LN40C530 TV
Bn59 00463 volume works nothing else cant turn on
Oct 20, 2009 | Samsung Televison & Video
Harmony 659 won't learn samsung LN-52A850S1F remote
Samsung has recently acknowledged an issue with 8 series LCD TVs (e.g. LN52A860). When the TV is first turned on, it outputs strong IR interference which can render the Harmony unable to control your devices for several minutes. After the TV is warmed up, the interference dissipates and the Harmony will work correctly again.
To determine if your Samsung television is causing the issue:
1. Start an Activity that uses your Samsung TV
Confirm the Harmony is not controlling your devices
2. Completely cover the screen of your television with a blanket or dark colored sheet
3. Try changing the channel. If the device now responds, the television is interfering with your devices. Please contact Samsung for support
It is possible that by disabling certain features on your TV can also resolve the issue. Features that may cause interference with your remote include:
1. DNR/Active Control
2. Power Saving Mode
To disable either of these features, please consult the user manual for your TV.
Mar 04, 2009 | Logitech HARMONY 659 Remote Control
Samsung TV Remote Control Logo
404 people viewed this question
Henry  Thomas
Henry Thomas
