Question about Canon I960 InkJet Photo Printer
Will not print cyan - Canon I960 InkJet Photo Printer
  • Canon Master
  • 32,281 Answers
The cyan print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked cyan print nozzles. Also check the cyan cartridge, make sure it is not empty.
If none of this works then the print head needs to be replaced. NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Posted on Nov 13, 2010
Why too much yellow and red no greens or blues ?
Inkjet printers use additive pigments. CMYK, Cyan, Magenta, Yellow and Black. It sounds like you're not getting any Cyan ink to the paper. Either your printer is out of Cyan ink, or your Cyan print head is clogged.
Go into your printer's Properties and run a Nozzle Check. It will print a series of lines with each color. There will probably be a big empty space where it tried and failed to print Cyan. You can try cleaning the print heads, but if you're getting NO Cyan that is unlikely to work.
If you're lucky, your printer is one of the ones that the print heads are built into the ink cartridge so replacing the cartridge will resolve the problem. If you're not, you might need to get it serviced (or probably more cost effective, buy a new printer).
Apr 30, 2014 | Epson Stylus CX5700F All-In-One InkJet...
Aficio SP C411DN does not print cyan
Well, since you've tried everything, my recommendation is to try to clean the contacts with dry cloth in the left or right side inside the printer where the cartridges place in. see the result
Feb 01, 2014 | Ricoh Aficio SP C411DN Laser Printer
Instead of Bule print DC12 prints Violet
Hi there! The blue color is becoming violet because the Cyan and the Magenta toners are not getting mixed in the proper 100:100 ratio (100% Magenta and 100% Cyan make CMYK Blue). Since the print is violet, the culprit is the Cyan toner. Now, first, get the Cyan Developer Assy checked if there is enough developer in it. If no, get it refilled by a proper tech and manually mix about 50 grams of the Cyan Toner with the developer. Also get the tech to check the trimmer gap on the Developer Assy with a metering gauge. If yes, next check the Cyan dispenser motor located on the backside of the Toner Housing Assy. It is probably broken and not dispensing any toner to the Cyan Developer Assy . Additionally, check for the Cyan Dispenser Auger blockage or jam. It is located under the Cyan Toner Cartridge in the Toner Housing Assy and also check the auger under the Cyan Developer Assy. After sorting these out, you should get proper CMYK blue from the 10th or 12th page once you resume printing.Let me know. Regards
May 26, 2011 | Xerox DocuColor 12 Color Copier
Hp clj 5550 not printing cyan
Check the black cover on the pick up assembly under the cyan cartridge. If it is only a fraction too high cyan will not print. Make sure it is clipped in place correctly.
Jan 20, 2010 | HP LaserJet 5550 Printer
My magicolor 2350 has cyan print problem
replace the cyan image unit might go a bad one
Oct 04, 2009 | Minolta magicolor 2350 Laser Printer
After cyan ran out, installed new cartrige. Printer produced everything colored blue as red. Purchased new cyan cartrige and the problem recurred.
The problem seems from your new cyan cartridge.
It doesnt print cyan ink.
Try to clean print head and test print for each color
from the utility menu
Sep 09, 2009 | Epson Stylus CX6000 All-In-One InkJet...
HP CP1700 - no cyan or blue printing
Try taking a look at your printheads. Have they been installed for some time. You may need to change them. Start with the Cyan first.
Inkworks
866-381-0541
Oct 24, 2008 | HP cp1700 Color Inkjet Printer
Hp 4600 no cyan printing
Firstoff, if you have tray 1 set to "any size" & "any type" they had problems with it going into calibration to frequently. If you upgrade the firmware this will take care of that. As for no Cyan, check the scanner interlock to insure it is opening the scanner cover. You could also go into diagnostics and disable cartridge check and swap the cartridges around, ie. cyan & magenta, run the print quality pages and see if the problem follows the cartridge. It could also be HV power supply.
Jun 18, 2008 | HP LaserJet 4600dn Color Printer
Canon I960 InkJet Photo Printer Logo
119 people viewed this question
old marine
old marine
