Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
I have a Philips 60" with a convergence problem.
  • 1,476 Answers
Info20999,
You need to use the exact chips that are in your unit. Any other ones would cause bigger problems and not work. The number is on the IC and from what you have said you must have already identified them. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains in detail how to change the units. You will need very good soldering skills and equipment. Also an attention to detail couldn't hurt. It can be done but be concientious and methodical. Leave nothing to chance and your repair should turn out great.
Thanks for using FixYa and for the great rating. Great ratings will keep experts helping everyone solve their problems. Thank you.
hardrocko
Posted on Nov 13, 2010
Poor convergence on my 60"
It is very possible that the IC's were not installed correctly. Check and make sure you do not have any solder bridges on your pins, or that the solder pads did not pull up from the board. If all that looks good, check your resisters that are in circuit. It is possible that 1 or more was already week and popped when the new STK's were installed. Also as far fetched as it could be, you might have gotten defective parts though not likely. I hope this helped and good luck to you.
Aug 10, 2011 | Philips Magnavox 51MP392H Rear Projection...
I have a friend with a Philips 60PP9202 TV, and she describes her problem as: "The top/bottom corner of the picture is kinda waved and the color is blue/red (3D like)". Would anyone have an...
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 15, 2010 | Philips 60PP9202 60" Rear Projection...
How can I find a "convergence circuit" for my 8 year old 60 in Phillips projection TV? Could I install it myself or would I need to hire an expert to do the work?
There are no a whole DLP tv model Philip convergence board out there to buy.U only can buy a convergence kit,came in parts like 2 STK convergence ICS and some or all of it resistors parts for sale.Hire a shop to fix ur DLP tv convergence board.They'll charge u like $300-350 for parts and labors.
Nov 09, 2010 | Philips 60PP9202 60" Rear Projection...
My 60 inch Maganvox tv is blurry and the letters at the bottom are blurry. Can;t hardlt make out the picture now.
Replace STK convergence chips there are two next to the heat sink.Unsolder old and solder in the new.
May 21, 2010 | Philips Magnavox 9P6034C 60" Rear...
Red curves on bottom and top of picture
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jan 18, 2009 | Philips 43PP9202 43" Rear Projection...
Philips HD 60 No red convergence
they are the STK 392-120's ic's on the big heat sink , depending on the numbers in there they may have been replaced with the upgrade or are original , also this could be the cause of a resistor on the chips connection lines (6.8 ohm) , or even a bad solder connection , testing of these should be done before getting the ic's and heat sink compound or solder wick and solder for the job
Jan 07, 2009 | Philips 60PP9202 60" Rear Projection...
Convergence problem with Philips 60PP9352
Screen looks 3D
Solution:
Oct 01, 2008 | Philips 60PP9352 60" Rear Projection...
60PP9352 60 in. Rear - Blue convergence issue
Replacing only the ICs MAY solve the problem, however, many people have also had blown resistors requiring replacement. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice.
You do not have to replace any transistors to fix this convergence failure.
May 28, 2008 | Philips 60PP9352 60" Rear Projection...
PHILIPS 43P8341 CONVERGENCE OF GREEN AND RED
Look for the STK ICs mounted on 2 big heatsinks.
I would suggest to replace both of them once you have the TV taken apart.
I think the part markings are STK392-040.
Let me know if you need further assistance.
Apr 29, 2008 | Philips 60PP9352 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
370 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
