Question about HP DeskJet 932c InkJet Printer
Printer is not printing, the power light is on, the other lights are off. I click print on the soft ware, properties and other relavant alustments and no response.
I had a hp printer that didnt want to print I found out that if one of the ink cartridges is empty it wouldnt print. I needed to print a letter in black ink so I had to trick out the cartridge by putting black electrical tape over the small site glass(plastic) so the printer thinks it is full,after this the printer would at least print the letter
hope this helps
Garey
Posted on Nov 13, 2010
How to clear a full memory?
try going to the control panel of the computer, click on printers and hard ware , click on the printer , right click on the properties and see what data is ready to be printed
high light each line and end task
Nov 20, 2015 | Canon iR 2016i Black and White Copier
Why does my printer only print half of a page?
Let's start by trying this:
Unplug the printer power cord from the printer and the wall.
Turn off the PC.
Disconnect the USB cable from both ends.
Plug the printer back in and turn it on.
Now, can you print a self-test page from the printer?
Make sure there is unused, plain white paper loaded in the input tray.
On the product control panel, press and hold the Power button and the Cancel (X) button at the same time.
Release both buttons. The diagnostic page prints.
If that does not work, are there any blinking lights on the printer? This document might explain them: Blinking lights.
If the self-test page does print normally, reconnect the USB cable, turn the PC back on and try to print a Windows test page:
Click the Windows icon and then click Control Panel . The Control Panel opens in a new window.
Click Hardware and Sounds .
Click Printers . The Printers folder opens.
Right-click the printer icon in the Printers folder.
Click Properties . The printer Properties window opens.
In the General tab, click Print Test Page . The Windows Printer Test Page prints.
If you have problems printing from Windows, you can try some of the troubleshooting steps in this document:
Printer Prints Blank Paper.
Finally, you may have to uninstall and reinstall the print driver.
Jun 03, 2015 | Office Equipment & Supplies
Help. Cannot print from black ink cartridge
Hi ....
There could be many reason for black ink not printing. You could try couple of steps starting with cleaning the print head ... Follow the below steps to clean the print head ...
After confirming that the cable is connected (if applicable) and the printer is powered on, perform the following.
Note: Standard print head cleaning can also be performed by holding down the <Resume> on the printer until the power light flashes one time. Deep print head cleaning (a more power process that uses more ink) can only be performed from the computer.
  1. Open the Printers folder.
    For Windows Vista
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
    For Windows XP Home Edition
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000/Me/98
    • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
  2. Right-click the printer icon and select 'Properties'.
  3. Click the Maintenance tab, and then click the 'Cleaning' icon.
  4. Select which nozzles should be cleaned.
  5. Click 'OK' to continue with the print head cleaning. The power lamp will flash and print head cleaning will start. Do not perform any other operations until print head cleaning completes.
  6. When the print head cleaning has finished, print the nozzle check pattern by clicking on the 'OK' button to determine if further cleaning is necessary.
  7. Once the page has printed examine the nozzle check pattern.
  8. If the pattern does not print correctly, click the 'OK' button to return to the Maintenance tab.
  9. Click the 'Deep Cleaning' icon.
  10. Click the 'Execute' button after selecting the nozzles to be cleaned.
  11. Confirm the message, and then click the 'OK' button to start the Deep cleaning.
  12. The Power lamp will blink and print head deep cleaning will start. Deep cleaning completes when the Power lamp stops blinking and lights. (It will take about a minute for the Power lamp to stop blinking and light solid.)
  13. Print another nozzle test pattern. If the pattern still does not print correctly, replace any ink tank that may be low, and then perform another deep print head cleaning.
  14. If printing is still not satisfactory, there may be a problem with the print head or the printer may need to be repaired.
This resolves the problem most of the time but if this does not work, please just leave me a note and we'll move to the next step which is checking the cartridge installation to check if its inctalled correctly or not ....
Please vote if this helps .... Cheers :)
Aug 04, 2009 | Canon PIXMA iP90 Mobile Printer
Printer only prints one page of multiple page document
hi..
You may try to change the spool data format:
1. Click on "Start," "Control Panel," "Printers and Other Hardware" and "Printers and Faxes."
("Start," "Control Panel," "Hardware and Sound" and "Printers" for Vista...)
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. Under "Print processor" it should be set to "Lexmark *** series print processor." Next, under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Try printing again.
Apr 24, 2009 | Lexmark P4350 All-In-One InkJet Printer
Hp psc 2210 all in one printer
You can't load the software that came with the printer.
HP has a Vista page for your printer. Here is a link: PSC2210 Using Vista
Basically, you need to uninstall the software AND delete the printer from your computer. Disconnect your USB cable. Power up your printer. Connect the USB cable.
The above link gives some workarounds for scanning and importing images.
Nov 07, 2008 | HP PSC 2210 All-In-One InkJet Printer
Only print red
I AM NOT DISPONING IS INSTALATION CD PRINTER
May 30, 2008 | Epson Stylus C46 InkJet Printer
I have an HP D5360 Printer. Please tell me how to see ink cartridge content levels.
you have to install the software first to see the ink level.If the soft ware is installed then follow the following
Checking ink levels
  1. In the HP Solution Center, click Settings , and then click Printer Toolbox .
    NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box , click the Features tab, and then click Printer Services . The Printer Toolbox appears.
  2. Click the Estimated Ink Level tab. The estimated ink levels for the print cartridges appear.
Apr 03, 2008 | Office Equipment & Supplies
Can't get my printer to print
Hello lilltlellulu2,
This is Enday, to solve your problem, try to check if you have installed the ink cartridges properly... If you have installed the software for the printer ,you must restart your system unit inorder to take effect on what changes you made..so as ther hardware to work.
Now, after restarting, click on the control panel, then printers..as you can see your printer installed,,right click on the printer icon>properties>print test page...
Just see if its working this time...
Thank you... and Good day...
Enday
Jan 26, 2008 | Lexmark X1270 All-In-One InkJet Printer
Prints only in black and white
Windows 2000 / XP:
Go to Start, Settings, Printers. (Windows XP: Start, Control Panel, Printers and Faxes).
Right click on the printer icon and select Properties.
Click Printing Preferences.
Click on the Quality/Copies tab.
un check mark Print Color images in black and white.
Click Apply and then OK.
This start ur printer to printer to print in colour
Dec 21, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
HP DeskJet 932c InkJet Printer Logo
61 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
