Question about Dell 924 All-in-One InkJet Printer
Each try to print I get a PRINTING ERROR ENCOUNTERED sign. Tried re-installing printer several times & it still won't budge. Checked all the connection also. Can you help? Florence
  • 2,973 Answers
Flo,
Please reinstall the drivers following the link below:
http://www.fixya.com/support/r3559995-installing_devices_on_pcs_and_laptops
Posted on Nov 13, 2010
How do I fix error cf 248 for my Kyocera 1128. I have tried several times shutting off. Taking out toner and checking paper jam
If its what I think it is, then the error occurs when your machine is receiving a corrupted print job. This is shown by the data light flashing for several minutes before showing the error.
If this is the case, then unplug the network cable from the machine, power the machine off & on & wait until it comes ready. If the machine comes ready then try a photocopy. If that works then it is a corrupt print job. Before plugging the network cable back in, check any PC's that print to the copier & check the print queues to see if any PC's are still spooling a print job. If so, delete the print job & re-connect the network cable & test the machine.
I have found most corrupt print jobs will be from the internet & will have "www......" listed as the print directory list.
Hope this helps.
Dave.
Feb 13, 2016 | Kyocera Office Equipment & Supplies
There are no signs of error but the paper comes out blank
Hi Zanda
if you haven't used your printer for that long, your printhead is more than likely dried up and clogged. Try running the "Head cleaning" utility 2-3 then print a "Nozzle check" (find both of these functions on "Maintenance" page under "Printer properties".
If the nozzle check shows any print, you're on the right track. Run few more head cleans or try printing several pages (with LOT of colour) on high (best photo) quality. Combination of printing & nozzle checks works best. Be prepared to waste lot of ink doing this!
If you get no print at all, it's probably time to get a new printer. There are other things you can try eg. buy set of cleaning cartridges, try to clean the printhead by placing some folded tissue soaked with Windex under the printhead or forcing some Windex through the printhead pickup (using a syringe & rubber tubing fitted over the pickup needle - where the cartridge usually sits) etc.
Another way yet is to remove the printhead from printer and soak it in cleaning solution (if if you're handy and prepared to pull your printer apart).
good luck!
Lumir
www.inkbank.com.au
REFILLABLE CARTRIDGES
Mar 02, 2014 | Epson Stylus RX425 Multifunction...
Problem encountered installing rhe new printer canon MX 360
Make sure printer jobs are cleared and try printing again. Delete any stuck or error'd jobs. Also confirm that it is the default printer. It should have a check indicating so in printers. You can assign default by right clicking and choosing set as default.
Aug 28, 2012 | Office Equipment & Supplies
Carrage won't calibrate - more details
Hello! There are many types of error in Canon Printers like P07,P08, E15etc. So please notify the error or check it through your computer notification. After you see the error number (s) please send me a message. Let me try my best for you. Thanks
Jun 20, 2012 | Canon PIXMA iP4700 InkJet Photo Printer
I can not get the printer to stop printing ...what do i do?
Hi please turn off the printer and restart it after five minutes if you still have the problem please uninstall and reinstall the drivers for your printer.
Jun 13, 2010 | HP Office Equipment & Supplies
New tri-color cartridge has a problem. I can't see what.
I have an HP Photsmart C4100 printer. I purchased remanufactured ink cartridges (both black and tri-colored) from Vivasmart. The black one works fine, but when I installed the tri-color, I got an error message that says "Print cartridge problem" The following print cartridge has a problem:
Tri-color.
And I can't print. The screen on my printer says "Remove and check color cartridge." I have done this several times and it still won't print. I have turned off the power, removed the cartridges, and unplugged the unit, but it still didn't help. Any suggestions?
Jul 21, 2009 | HP PSC 1510 All-In-One InkJet Printer
I had a problem with my dell all-in-one photo 924 printer. I decided to delete the Dell AIO 924 driver to fix the problems with printing the docs by getting error message, ? communication not available?...
The problem could be because of ONE out of FIVE problems listed below. Try the steps recommended and it should fix the problem.
Thanks,
Abhishek
Jun 08, 2009 | Dell 924 All-in-One InkJet Printer
Laserjet 2840 has error 59.4 have reset power several times but error returns when it tries to print
laserjet 2840 has error 59.4 have reset power several times
Nov 07, 2008 | Office Equipment & Supplies
Dell 924 All-in-One InkJet Printer Logo
29 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
