Question about Poulan Garden
My Poulan/weed eater(FeatrerLite) will only run at Idle speed Acct the throttle trigger,located on the shaft is broken. Where can I secure this piece?also where can I pick up an Owners manual?
  • 718 Answers
Go to psep.biz
Posted on Nov 13, 2010
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Why will My weed eater only run with the choke fully on and cant give throttle?
    It sounds like the carb needs adjusted. Things can even happen to new weed eaters.
    May 31, 2014 | Poulan P4500F 16-Inch Straight Shaft 25cc...
    Weed eater head spins on its own, no power.
    check the compression on your weedeater low compression will cause this
    Jun 26, 2013 | Poulan Genuine Weedeater Part # 36006-128
    Weed eater will not run in high speed but will idle
    Lack of fuel is my first thought. Check to be sure the trigger control is working at the carb. From there I would suspect plugged fuel line or plugged carb, (most likely contaminated fuel) either way I would suggest someone that knows about these. Hope this helps
    Apr 26, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
    I bought this poulan weed eater on 4-2-10 at walmart in westworth village . the trimmer head does ok at any spped for a 2 or 3 minutes then it just goes real slow with the speed at cutting speed . the two...
    new doesnt mean free from defects sounds like the shaft is binding can be from a kink or not lubed correctly-- its new so bring back to walmart and replace or return
    Apr 14, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
    Poulan Weed Eater PPB250E won't accelerate
    definatley running out of fuel. this sounds dumb-just check it. the fuel line from the tank to carb is made of tygon, it gets hard and cracks allowing air to enter fuel line and lean out the unit,sometimes till it quits. also drain the fuel from the tank, look in tank, youll see a hose with a weighted fuel filter in the end of it, get a peice of wire,carfully pull it out and chack for cracks or a broken off 'clunk' fuel filter. then which is hard, the fuel pump-a little built in vacume diaphram in the carb that re-verberates with engine vacume and pumps fuel at high demand times. there will be a metal cover on the carb with a hole in the middle, carfully remove the screws ans the diaphram will be part of the gasket so dont rip it or youll need a carb rebuild kit. look for rips or tears or a broken return spring. also make sure the carb hasnt loosened up from the engine, this will cause a vacume leak and then the pump wont keep up. check the lines first that what you will probably find. good luck!
    Sep 03, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
    Poulan Pro weed eater won't accelerate.
    check the fuel mixture screws on carb high should be turned in & 1 turn out & low side should be turned all the way in & 3/4 of a turn check those & let me know thanks wade
    Jul 06, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
    Garden Logo
    80 people viewed this question
    Top Poulan Garden Experts
    Roland W VanLue
    Roland W VanLue
    Phil Walker
    Phil Walker
    Are you a Poulan Garden Expert? Answer questions, earn points and help others
