Question about Car Audio & Video
I have installed a sterio and when splicing the stock radio connector to the new sterio connector - the dash panel lights do not work - fuse blew - trying to solve
    Problem Solver:
  • 7 Answers
Take it to a professional, if you cannot even spell STEREO how do you expect to connect it???!!!
Posted on Nov 13, 2010
After installing a new radio, everything worked fine for couple days. Why are my dash lights, stereo, and tail lights not working?
you blew the fuse, in the fuse box.
or it blew again, do to shorts you introduced or IT, manifested.
Apr 16, 2015 | 1993 Geo Tracker
I installed a new tv radio on my 09 honda accord lxp. Now the parking lights and the ac climate control lights are not working. Can somebody please help me.
Check your fuses and double check your wiring. You've likely mis-wired something to the radio that also supplies power for the lights in the dash. So if you find a blown fuse, you might blow it again if it's a wiring issue. Of course, you may have bumped a wire to ground during the install which blew the fuse, so replacing it may be all that's needed.
I had an issue where a "small light fuse" in my 97 accord blew and my parking lights and dash lights didn't work. Small fuse under the hood was all that needed to be replaced.
Nov 23, 2014 | 2009 Honda Accord
Ford windstar radio won't work
Check that the wiring and/or connector inside the console was not disturbed during removal or reinstallation
Mar 24, 2013 | 2003 Ford Windstar
Fuse keeps blowing to my dash guages in my 95 gmc sierra why?
have you recently installed a new radio ? I have knowen people to install radiosincorectly the dim wire behind the radio shows as a earth. however when you turn headlights on this becomes a positive. if you have wired this wire to your sterio this is whyyour dash lights & internal cab light etc keep blowing.. if your wondering why sterio still works is because its earthed through the aerial or mounting bolts.
Jan 05, 2013 | 1995 Chevrolet Silverado 2500
I have a honda odyssey 2001 the light of the panel are not workinkg all the rest of the lights are working i check the fuse and are ok only i did was change the radio and install a new one but did not...
I'm guessing you're talking about the dash light aound the radio. The dash lights around the radio share the same fuse with all the other lights that come on when you turn the parking light on. If the other light are working then your fuses are fine. What i think might have happen was when you took the dash cover off, the bulbs behind it might had burn out. You might want to try new bulbs.
good luck
Jan 20, 2011 | Honda Odyssey Cars & Trucks
Radio/cd player went dead. Tried replacing fuses
Do NOT Cut and Splice. Your local parts store sells an aftermarket radio plug in which connects to your factory harness and then you can splice in your radio into the new connectors ends that are labeled for what they go to.
Jul 31, 2010 | 2000 Chevrolet Venture
Need color code diagram for sterio
I'm not sure what year you have but this color code works for 87-93 mustangs.
Radio Connector:
Light Green / Yellow - Hot at all times (Fuse 8)
Yellow / Black - Hot in ACC or Run (Fuse 11)
Light Brown / Red - Goes to instrument panel dimming rheostat (Fuse 4)
Red - Ground
White / Purple - Hot in ACC or Run (Fuse 11)
Speaker Connector:
White / Light Green - (+) Right Instrument Panel & Door Speaker
Dark Green / Orange - (-) Right Instrument Panel & Door Speaker
Brown / Pink - (+) Right Rear Speaker
Pink / Light Brown - (-) Right Rear Speaker
Pink / Light Green - (+) Left Rear Speaker
Tan / Yellow - (-) Left Rear Speaker
Light Brown / White - (+) Left Instrument Panel & Door Speaker
Orange / Light Green - (-) Left Instrument Panel & Door Speaker
Hope this helps.
Jun 19, 2009 | Ford Escort Cars & Trucks
My dash lights don't work.
this got easy after a while 2 ways, i had friends who would not take the time to spend 8dollars to buy a harness connector for a new cd player and would splice everything together like takeing the red and yellow wires and connecting them all together as one. this drains ur battery unless ur cd player can completly power down by the power button not all do... but keep this in mind on GM cars the 2 wires of the same wires like purple the one with a black stripe is ground they go together stripe on stripe also there is 2 extra wires one is ORANGE and BROWN u dont need these dont even mess with them even if u have a connector block them off THESE TWO COLORS IS FOR FACTORY STEREO IF SO THESE WIRES CAN AND WILL MAKE IT SO U DONT HAVE DASH LIGHTS so always buy a connector ond dont mess with these wires block them off and dont ground them out.
Jan 12, 2009 | 2001 Chevrolet Blazer
Replace factory radio on 2002 yukon xl
all you gotta do is carfully pry the dash panel off (prying from the far left end is easiest) completely remove panel. then there are 2 clips that hold the factory sterio in place. push on the both clips while pulling the radio out. simply disconnect the wiring harness from the back of the radio. using an adapter avaliable at your local radio shop (scosche p/n gm02, mdarb and gm1483b) wiring harness, dash install kit, and antenna adapter. then simply match the colors on the new radio's harness to the adapter harness, crimping each connection with a "but plug". then simply follow the instructions included with the dash install kit to assemble the kit.connect the antenna adapter to radio, plug in all cables. test to see if everything works properly before the final install. install sterio into dash install kit, re installing kit where origional radio was. then simply put the panel back in its place by firmly pushing on it untill it snaps into place. then enjoy your new radio!
Dec 29, 2008 | 2002 GMC Yukon XL
95 Geo Tracker Dash Lights out?
replace the blow fuse
above left knee, fuse panel there.
1 is blown.
your amp was shorted, it blew and took out what oem wiring they hacked into .
bad installation.
Sep 09, 2008 | 1995 Geo Tracker
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
