Question about Ovens
I have power, light and clock work. Power and turntable goes on and off in seconds. Can not heat or cook.
  • Ovens Master
  • 12,061 Answers
This is happening due to either the magnetron, or the Power Diode, or both, is breaking down, under load, then the unit detects the fault condition, & then, for safety reasons, to avoid a fire or explosion, shuts down the system. You need to take it in to a reputable repair center be looked at. Also, please obtain a "Quote" before proceeding with any work. This way you can decide to repair or replace.
Posted on Nov 13, 2010
I have reset the clock the oven sounds as though it's working for just 2 seconds and then stops. The light will not come on at all. I have cleaned all contact points still no luck .
inverter failure blows safety fuse internally this will power down the oven to prevent further damage new inverter and fuse needed.
Feb 03, 2017 | Neff Ovens
Thermador oven preheat light will come back on during cooking session. The clock has also stopped working.
There may be a fault with the control board.
http://appliancejunk.com/forums/index.php?action=dlattach;topic=9146.0;attach=5091
Oct 05, 2014 | Thermador Ovens
I have a Lincoln Impinger Model No. 1301/1346 electric counter top oven that wont heat up at all, what could be the problem
After powering on set the temperature to cooking temperature. since its electric it is less problematic. if there is no alarm then check the probe.
Jul 25, 2014 | Lincoln Impinger Electric Countertop Oven...
I have a Smeg Wall Oven Model No SA710X-5. When I turn the cooking selection switch to the desired cooking setting the green light comes on. But when I turn the thermostat switch to the desired temperature...
It sounds like the element is missing one side of the 240v power. One side may always be hot while other side is controlled. A qualified repairman can Start at the element and work backwards. Trace wiring back looking for burned wire, bad connections and connectors, all the way back to thermostat. Check thermostat for continuity (with power off), replace thermostat if necessary.
Oct 29, 2013 | Smeg Ovens
Lower oven loss of power
I'd check the control switch first, and the wireing and connections.
Sep 05, 2012 | Ovens
The lock is displayed on the clock and dont no how to get it of
If you're talking about the oven and stovetop being locked so you can't cook, on mine you usually hold the oven or stovetop light button for about five to seven seconds and it clicks off. I have a Kenmore, but I know sometimes they're similar. Also, if the power go outs, it automatially goes into lock mode.
Jun 26, 2011 | Whirlpool Ovens
We have a frigidaire self cleaning oven . It made a bang and now there there is no power to my oven. Clock does not work , Burners on stove still work.
According to your symptoms, it appears that you will need a new electronic oven control board. If nothing on the range heats, you could have a tripped breaker on the 120 volt L2 leg of 240 volt power. This would prevent the cook top burners and the oven elements from heating.
Jan 21, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
My large main oven will not work on my AEG U7101- 4- M. The small second over/grill is working fine.
Is the clock set? The display must show the correct time and must not be set to automatic cooking.
If the light comes on and the fan is working then the clock is set. If there is no heat then the element behind the cover and surrounding the fan is probably open circuit. This can be accessed without needing to remove the oven from the carcass.
Good luck
Nov 27, 2008 | AEG U7101-4 Electric Double Oven
Ovens Logo
27 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
