Question about Maytag Neptune MDE5500AY Electric Dryer
My neptune dryer has power to the unit but willnot turn on
    President:
  • 1,554 Answers
One or both of the thermal fuses are blown. These thermal fuses are wired in series with the motor and the motor will not run if one or both of them are blown. Verify this condition by bypassing both of the thermal fuses then starting the dryer.
Disconnect power then open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
Refer to the parts diagrams and locate the thermal fuse on the blower housing and the thermal fuse on the heater housing.
Posted on Nov 13, 2010
  • Jahn27
    Jahn27 Nov 13, 2010
    Disconnect the wires from thermal fuse on the blower housing then connect them together. Insulate the connection properly then close the door firmly and reconnect power. Start the dryer and if it runs, then the thermal fuse is blown. Replace it along with the cycling thermostat. But if the dryer still doesn't run, disconnect power and reconnect the wires back to the thermal fuse terminals then do the bypass with the thermal fuse on the heater housing as with the thermal fuse on the blower housing. Reconnect power and start the dryer. If it runs, then the thermal fuse is blown. Replace it along with the high-limit thermostat. But if the dryer still doesn't run, disconnect power and bypass both of the thermal fuses. Replace both thermal fuse along with the thermostats if the dryer runs.
MY MAYTAG MDE9700AYW WILL NOT TURN ON
Are you getting power at the console? Also, check to see if one of the breakers has not tripped. Dryer runs on 220v and you may have tripped one breaker that will show power to the unit but won't let it start.
Dec 24, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
.8.8 error message on my neptune electric dryer
sounds like a serial connection problem or glitch in the c.c.u.,first try removing power to the unit for 5 to 10 minutes to clear the memory on the c.c.u.,if this doesn't resolve the issue you may need to replace this board you can power it down by unplugging at the wall or if not easily accessible,then at the power panels breaker or fuse
Jan 01, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune shows power but wont function
A dryer can not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Has power but will not start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Feb 23, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer willnot heat
heating eliment is most likely burned out. Better off getting new dryer. But if that is not an option then call a repair person that can replace the heating element.
Nov 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
How do i turn OFF the pilot light on a maytag neptune so I can fog the house for fleas?
The MDG5500AW doesn't have a pilot it has a glow bar igniter but both the washer and dryer have electronic control boards unplug both units you'll be fine.
Oct 04, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Neptune Intellidry dryer.
You need to do a continuity check on the dryer cord. Also manually reset the breakers and make sure you have power (both legs). After this and you still have trouble, do a continuity test on the door switch. The door switch will keep a dryer from operating. After that, you will need to check that your motor is being called to come on. Also check the capacitor and that it is reading the correct microfarad's with in 5%.
Apr 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune gas dryer does not start , panel is lit up
Bad door switch.
Bad start switch.
Bad thermal fuse.
Bad motor.
In that order.
Check each with a meter set to OHMs.
Feb 22, 2009 | Maytag Neptune MDG5500AW Gas Dryer
MAYTAG NEPTUNE GAS DRYER
Unplug the unit and take off the cover where the cord goes in. You may have one burnt wire under that cover.
Mar 06, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
182 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
