Question about Reddy R60A Utility Heater
My heater is not getting any fire at sparkplug torpeto heater buy lawn-boy model num ph150
  • 232 Answers
Lawnboy? Man, that thing is old! Keep it running cause they don't make 'em that good anymore.
Check to see if the Ignition Device (transformer, spark box) is getting 110v. This box must have a good ground to the frame. If not, the unit will not produce a spark at the plug. If it does have a good ground, then the part must be replaced. The current replacement part is 102482-01
Posted on Nov 13, 2010
TORPETO HEATER KICKED OFF SAYS E1
error 1 is low fuel on most of these models
Mar 05, 2015 | Heating & Cooling
Why will Ariens lawn mower starter engine not turn over?
These machines have carb and coil issues. Check for fire. Nice when new, but once a little age creeps in, the engines just aren't that sturdy. Sorry, but as a small equipment mechanic, I don't recommend Lawn Boy. Next time, buy another brand.
May 30, 2014 | Briggs & Stratton Lawn-Boy Insight Series...
HAVE OLD LAWN BOY 150 BTU HEATER WONT STAY FIRED EVERY THING ELSE WORKES JUST WONT STAY BURNING ON AND OFF AS FAR AS THE BURNER
There are a number of things that will cause the symptoms described. From as simple as water in the fuel to a more complex problem such as a defective Ignition Device (transformer, Spark box).
You will need to read & follow the tips attached and attempt to narrow the problem down.
Troubleshooting tips
Nov 05, 2010 | Reddy R60A Utility Heater
Not getting fire to new sparkplug
first does it turn over at all. if then check to see if the blades are turned off, out of reverse seat interlock ect.
Jul 21, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn Boy mower will not start. New gas and plug.
Is the plug getting wet? if not, try introducing fuel to the intake and attempt to start it again, the interlock on the handle works by killing the ignition fire and applying a brake to the flywheel, this should be a Tecumseh engine, carb troubles are quite prevalent on these, by substituting fuel to the intake you are acting as the fuel supply, if it starts and runs briefly you have confirmed a fuel system issue
Jun 01, 2010 | Garden
Model 917.377580 / need air breather plastic housing
you can go online to toro who owns lawnboy and order the parts and ship them to your house or go to your local Tec dealer with model num and they should be able to help you
Sep 02, 2009 | RTO Lawn Boy 6.75hp Mower
Mower surging silver serieslawn boy 6.5 h.p. tecumseh motor model lev 120 spec 362006a. I cleaned out carb bought a rebuild kit replaced o rings in center jet and another under float also little metal...
let it surge, it will usually get better as it warms up. These 6.5 Hp engines are fine except they have an cheap badly designed carburator. Nothing can be done about this problem. They all surge eventually.
Jun 07, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
My mtd tradesman lawn mower does not run smooth. where is the idle mixture adj. screw? the engine is the tecumseh 5.5 hp model #VLV55 501029A(D)
The newer machines do not have a way for you to adjust the Idle, what you can do is change the spark plug or spray some carb cleaner or remove the air filter and run it for a few minutes without the air filter and see what happens
Apr 14, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
PH55 "lawn boy" porta- heater need parts
Lawn Boy sent me an 800 number for the company they sold the heater line to.
800-362-6951 portable heater parts. I have not called yet to find out if they will have qhat I need. Will call tomorrow, Tuesday.
Steve
Jan 25, 2009 | Reddy R60A Utility Heater
Reddy R60A Utility Heater Logo
235 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Richard Marsh
Richard Marsh
Level 1 Expert
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
