Question about Krups Irons
My krups iron which I loved has been snagging the clothes as i iron and to my surprise the bottom plate has torn itself away around the steam holes and causing the iron to rip clothing. I am not able to use the iron any longer..... I have never had this problem before with any other iron.....Please advise...thank you.
snakehead
  • 1074 Answers
SOURCE: My Tefal Steam Generater Iron will not steam
check the little tube that regulates the water to the holes it needs to be changed.good luck.
Posted on Apr 18, 2007
oscarn
  • 109 Answers
SOURCE: Water drips out of steam holes
I suspect that by placing it on its heel rest the water from the tank is not allowed to enter into the steam chamber and when you go into ironing mode there is a rush of water that is cooling down the sole plate to below steaming temperature. Try keeping it in the horizontal position on a heat proof pad and press the steam button just before going into ironing mode.
Posted on Sep 21, 2007
satscoop
  • 59 Answers
SOURCE: Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
Posted on Nov 15, 2007
  • 79 Answers
SOURCE: Brown gunge
Try filling full-strength white vinegar instead of water. Then allow to steam out on scrap cloth. The white deposits are likely to be calcium. The brown gunge may be rust. When the deposits are minimized, use only distilled or bottled water from then on.
Posted on Mar 16, 2008
DiYerTech
  • 70 Answers
SOURCE: CALCIUM BUILDUP COMING OUT OF THE STEAM HOLES...
Hi, the other two responders were correct, use clear or filtered drinking water only. Also, use your iron until it runs dry and use burst of steam or self cleaning function to clear out the last bits of water, being sure it is empty before putting it away. Several cycles of this using and purging process will clean the iron without chemicals. Standing water that evaporates is just like a tea kettle with water left in it, all the white mineral deposits settle to the bottom, and the water dissolves the mineral salts, and when dissimilar metals are wet (think of a an old flashlight battery and the corrosion that occurs if left in storage.
Posted on Jul 26, 2008
No steam coming throwc
Normally when water is put inside steam irons, it get stored in tank then if thermostat knob is set for steam then water moves to bottom heated portion of iron. Water converts to steam as base plate is hot, heated steam comes out through perforated holes. If holes are blocked due to scale formation steam flow is blocked. The descaling has to be done as per instructions given on descaling wax manufacturer. sometimes if water does not enter through a rubber washer that is water tank to heated bottom portion then also steam will not get generated hence no steam. Please check above points and identify the problem.
Jan 08, 2015 | Irons
Steam generator wetting clothes
Heating plate has come detached from the tank. You have to remove the base and tighten the bolts on the heat plate. This ensures that the necessary temperature can be reached and thus steam rather than water comes out. Unfortunately the base is secured with security screws (6 point star with centre hole) so you will need to get one of these to fix it. They are same as used to secure number plates and can be purchased on ebay or at car parts shop
Sep 01, 2012 | Tefal Pro Express GV 8120 Iron
Iron leaking and plate dirty
If you have hard water, there will be a buildup of minerals where the rubber gasket on the water tank meets the steam chamber that is built into the sole plate. This will make the rubber gasket surface become hard and no longer seak to the team chamber, resulting in water leaking from the tank onto the outside of the iron.
If you are reasonably skilled with tools and have a Torx T20 driver, you can disassemble the iron and remove the rubber gasket between the tank and the steam chamber and soak it in vinegar to remove the mineral scale. First remove the three Torx screws visible at the rear of the iron and gently pry off the gray rear cover plate. This will expose two screws holding the rear end of the sole plate. Remove those two screws. Then gently pry off the stainless steel nose piece on the front of the iron; this is the curved piece that says "high precision" on it. This will then expose the screw that holds the front of the sole plate on the handle. Remove thqt screw. Pull the black connector at the rear of the iron off the two rods to which it is attached, and you can move the sole plate away from the handle. The rubber piece in the handle that is sort of oval shaped and about 2 inches long is the gasket that is probably causing the leak. Gently remove it and soak it in vinegar to remove the scale, and remove the scle from the round hole where it meets the steam chamber in the sole plate. .When they are clean, reassemble the gasket onto the handle and the sole plate onto the handle, connecting the electrical connections, and replace the screws, It is not simple, but it is doable.
Apr 14, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
BROWN MATTER COMING FROM IRON
iron need to be self cleaned
Jun 03, 2009 | Euro-Pro Shark GI490 Iron
Holes clogged with plastic
I would put the un-plugged iron in to the freezer so as to get the plastic as rigid as possible and then try to extract all of the plastic from the steam holes.
As far as cleaning the irons surface.
Step1 Place about a teaspoon of salt on a paper or cotton towel and run the iron over it on the high setting gently with the steam off. This will cause the dirt to stick to the salt and will wipe away easily. Step2 Rub the iron across newspapers to remove a waxy build up on the surface. Use the high setting with the steam off. Step3 Apply ammonia to a rag and use it to wipe the surface of the iron to remove oil. Use a separate cloth that is wet with water to rinse it off. Make sure the iron is turned off. Step4 Combine equal parts vinegar and baking soda and scrub the surface of the iron with it. Use a separate clean cloth to wipe away any residue. Step5 Heat in a saucepan a cup of vinegar and sprinkle in about a teaspoon of salt. Heat the mixture until the salt is dissolved. Use this to clean the iron's surface with a clean cloth. Use a second cloth to wipe away any residue.
Good luck
Aduz
Mar 22, 2009 | Tefal Ultraglide 1549 Iron
I have a Black and Decker First Impressions (about 2 yrs old). When on steam it always spits out large puddles of water on the clothes as I'm ironing. It seems to come from the top or bottom part of the...
It's a possibility that you iron steam making elements are caked with lime and possibly the steam holes as well.
Purchase some "Lime Away" and dilute it 50/50 and pour it into your steam iron (drain all the old water out first and leave the iron unpluged) let sit for an hour or so and drain out, fill it again with clear water shake and drain out do this a couple of time then turn on the steam and see if it works properly, use the first time on an old towel to be sure all the chemical has been rinced out. Good Luck.
Feb 28, 2009 | Black & Decker D2030 Iron
Steam iron
time for a new iron, safety first , you will be surprised at what you can get on sale these days
Sep 01, 2008 | Irons
How many holes is it supposed to have
Sometimes is normal having different hole diagram on the iron Plate.That one is up To the engineer worked on the project.Some Company believe having more hole in the tip will increase the efficiency of your iron.Some other company believe having more hole on the side is better.If you have a chance to look a professional iron system..most of them have a triangle hole located on the tip and it`s been in that way for so long.This is different for regular home iron with less pressure and different Plate.
Fabio
Jun 21, 2008 | Rowenta SM700 Iron with Auto Shut-off
Rust
No. The machine is not gone but you may have to replace the steam compartment of the machine.. You can also try cleaning the rust.. You will need to get a pair of gloves open the steam compartment and clean the rusted area with dilute oxalic acid.. It will work more often than not..
Good Luck!
Sai.
Mar 15, 2008 | Krups V65 Iron
Irons Logo
27 people viewed this question
Top Krups Irons Experts
Are you a Krups Iron Expert? Answer questions, earn points and help others
