New Archer Aurora Gas Log Fire with Built in Humidifier. Humidifier has not worked since installation. Have phoned Archer, they state humidifier is working or the heater would not work. The humidifier is not working and has not worked. They will not listen to us and got extremely angry, raised their voice and told us that we know nothing about the heater, they are the professionals and do not wish to discuss this matter further. Please could you tell me if the heater can work without the humidifier and how do we correct this problem. Thank you
  • Anonymous Mar 22, 2009
    i have archer aurora gas fire and the flue fan light fade out even with out the flue connected and the heater wont fire up what could this problem be
If the humidifier is faulty the unit would not fire up. The humidifier is a lot quieter then the bay window model. So you do not have a problem. Also the frequency of the pump will depend on the type of flue you have. Hope this helps.
Concerned Archer Dealer
Posted on Jan 05, 2009
Built-in humidifier just stopped working. Any ideas how to fix?
Troubleshoot and Repair a furnace mounted Humidifier
www.instructables.com/.../Troubleshoot-and-Repair-a-furna...
InstructablesThis instructable will explain how to diagnose and, hopefully, repair a broken humidifier... While my humidifier was an Aprilaire 700 model humidifier, I would still expect ...Does it just take several on/off cycles of the furnace to finally stabilize?
Amazon.com: Customer Reviews: Honeywell Easy to Care ...
www.amazon.com/...Humidifier.../B00464E7VE
Amazon.com, Inc.Honeywell Easy to Care Cool Mist Humidifier, HCM-750. byHoneywell .... It does have a light built in, that shines through the falling water, and onto the ceiling. The primary.... It worked fine for a couple nights, then randomly stopped working.
Whole House Humidifier Troubleshooting - YouTube
? 2:42
https://www.youtube.com/watch?v=piKVU3JLQwg
Aug 23, 2009 - Uploaded by ntsupply
This video offers practical tips for troubleshooting whole house(furnace mount) humidifiers from Aprilaire ...
How to Fix a Humidifier ' HomeTips
Feb 03, 2016 | Heating & Cooling
Tip
Whole House Humidifiers ? The Types and Benefits of the Furnace Humidifier
As your gas furnace or other type of furnace heats the air in your house it will be forcing the moisture out of the air. To maintain the proper comfort and to keep things from cracking from lack of moisture you need to install a furnace humidifier.
Furnace humidifiers offer many health benefits. They help to relieve the irritation of breathing dry air. More humidity in the air has shown in studies to lead to healthier lungs and fewer illnesses. To many people, another very important benefit of installing a good furnace humidifier is that the addition of more humidity to the space during cold-weather months allows for you to lower your temperature setting on the thermostat while still maintaining comfort.
If you are already looking for a furnace humidifier, you are probably familiar with many of the great benefits of installing one in your home or office. A good furnace humidifier will also help alleviate some symptoms associated with asthma or allergies as well. A good furnace humidifier can also help you to prevent cracks in your precious wood. Another great benefit of installing a furnace humidifier is that it will help eliminate static electricity.
The three most common types of humidifier are bypass furnace humidifiers, the power spray furnace humidifiers, and also steam furnace humidifiers. The bypass humidifier seems to be the most common furnace humidifier is the bypass humidifier.
All of the different types of humidifiers need to have a lot of maintenance. On the pad type humidifiers you need to clean or change to pads often. On spray type humidifiers the nozzle and pad will need to be changed or cleaned yearly. On the best types of humidifier is the steam furnace humidifier. They produce the most humidity but are very expensive and do require more regular maintenance and upkeep then the other types of humidifier.
A humidifier can be a fantastic addition to your hot air heating system. The type of humidifier that you need to have will often be dependent on the size of the space you are planning to serve. Also, do you need precise control or not? Overall a humidifier is often a must have item if you are heating with hot air heat. Dry air is not any fun and causes many problems. Put up with the time you will need to invest in cleaning and servicing your humidifier. Having the proper amount of moisture in your house will pay you back many times over.
on Dec 12, 2009 | Heating & Cooling
Have a new evaporator to install, and directions on box say to "1. Note Humidifier Control setting and turn dial to "OFF" position." ... however, there is no dial, at least, not on the...
They are talking about the Humidistat which is separate to the Humidifier. Turn the power off to the furnace and that will disconnect any power to the humidifier. Turn the water off to the Humidifier if you have to remove it from the plentum. Then go ahead and install your new evaporator. If you are looking for the humistat follow the T-stat wire and see where it goes from the water valve of the humidifier...... But they may not have installed one and are useing a different way to turn the Humidifier on in the heating cycle.....
Feb 01, 2011 | Aprilaire 550 Humidifier
I installed a honeywell 360a flow thru humidifier, and a new transformer. I have power thru the wires to the fan cover. Also the humditstat clicks when turned on. The fan does not work and the solenoid...
Posting a diagram of how you wired the installation will help the both of us figure out what the problem is. You don't have to accept or rate this solution in order to post comments or information. But accepting a solution will not stop you from communicating with the expert. You can still communicate with the expert as long as you need assistance regarding the issue stated herein.
Jan 11, 2011 | Honeywell HE360A1027 Whole House...
Our aprilaire humidifier is only 4 years old and it does not seem to be working. We have static in the house and when I did test mode it never drained water like it was supposed to. Any ideas what I can do...
Hope this helps, check and see if humidistat is set to 35% humidity and that bypass damper on humidifier is in the open position or winter position.(humidistat is usually located on cold air return duct near furnace). Next, replace humidifier media pad, remember to replace media pad (filter) annually, you also may want to clean any lime deposit out of humidifier housing with a solution of warm water and white vinegar before installing your new media filter.Remember to turn power off at side of furnace when cleaning humidifier and replacing media. Before installing new media turn power back on to furnace, set humidistat to the on position, turn furnace thermostat above room temp., and inspect humidifier to see if water is running from top,(you may want to have a bucket under humidifier when checking for water), if you see water running, turn power back off to furnace, properly install new media filter, reconnect humidifier cover & set humidistat to 35%. If you do not see water present, check water supply valve to humidifier and make sure its turned on. If water supply valve is open, then check water supply tubing for blockage.And the last things to check is to make sure all registers through out your home are open and not blocked by any objects, also make sure furnace filter is cleaned, if none of this works refer to installation manual to see if humidifier was sized and installed properly, Good luck.
Mar 03, 2010 | Aprilaire 600 Humidifier
Excessive water usage with Carrier LBP humidifier.
hi the water runs down the pad the fan blows air across is , this controled by the stat which should control the water flow / on or off, this should be under warranty in the first year
Mar 01, 2010 | Carrier LBP Humidifier
Humidifier was installed on return duct on new trane gas furnace
you are ok. this way humidity will get to whole house if your supply duct splits off. done this way often.
Dec 29, 2008 | Aprilaire 700 Humidifier
Error Code E3
I have the same type of Aprilaire humidifier unit with automatic temperature sensing control. My unit also displayed the 'E3' code. The HVAC technician was on site today and replaced the temperature sensing unit that is located outside the house. The humidifier is functioning normally once again.
Dec 03, 2008 | Aprilaire 600 Humidifier
Wall heater does not work!
it sounds like the gas valve is not getting power. There is probably a saftey device that has tripped, preventing the voltage (24v) from energizing the gas valve. check for 24v throughout the circuit. It should be a simple series circuit.
Nov 11, 2008 | Honeywell Power Humidifier: Furnace...
Heating & Cooling Logo
560 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
