Question about Dishwashers
Electrolux model eidw6305gs1 dishwasher leaks on floor. Pump was replaced but dishwasher still leaks. email
    Champion:
  • 203 Answers
Check all the seals again
Posted on Jul 10, 2014
4 Suggested Answers
SOURCE: GE 24in GSD980X Dishwasher water leak in pump &motor area
I had the same problem. There is no way of replacing seal/joint between pump and motor. It can't be taken apart w/o destroying parts, it only comes as an assembly. Costs around 130$ for pump/motor assy, so it might not be worth it.
Posted on Jun 12, 2009
arikrom
  • 528 Answers
SOURCE: Sir,
go to sears part web site :) good luck
Posted on Jan 01, 2010
tattootech2
  • 72 Answers
SOURCE: EWDW6505GS0 Model Electrolux dishwasher 10 months
Dishwasher likely has leaked into drip pan underneath. Unfortunately, you need to remove dishwasher and flip onto back and remove 3 phillips screws that hold drip pan in place. Install "leak kit" to correct leak problem with this model of dishwasher. Part number is 154769101
Posted on Apr 07, 2010
What solution will fix a leak under the door of the dishwasher?
Hello friend, thank you for your post!
It is possible that one of your gaskets need to be replaced inside of your dishwasher. I would recommend having a technician come out and properly diagnose your appliance. Hope this helps. -Matt
Sep 02, 2014 | Electrolux EIDW6105GW 24 in. Built-in...
Error code 01 keeps coming up and will not let dishwasher complete its cycle. My dishwasher no. is ewdw6505gso and it is only 3 years old. I have 2 other appliances that are Electrolux. Please help.
Mine was only a few months old when error 01 arrived - it is a leak. The Electrolux dishwashers have a leak detector at the bottom inside the plastic pan, that when water appears it sets off the code and you cannot restart the dishwasher until you dry the pan out (tip the unit forward and water will come out) but it will keep on doing it unless you repair it - mine was covered under warranty and they replaced a lot of parts at the bottom. Not even a year later it leaked again, but not as bad. I took it apart and removed a fabric pad that sits in the bottom of the pan, it does not go off that much any more since the water evaporates before it does any damage. I think this feature is completely useless - I would rather see a wet spot on the floor than not be able to do dishes... If you got 3 years you are doing well. I will just replace my appliances as they die and never buy Electrolux ever again! PS if a refrigerator is one of your other units, be aware that their main boards can fail and are very expensive to replace. You will know it is blown when your food freezes in the lower compartment and your lights come on instantly instead of glowing up slowly.
Nov 15, 2013 | Electrolux Dishwashers
Cannot find leak in this Electrolux dishwasher
If you are getting the E01 error code for a leak being detected, it could be the unit is not installed correctly and not leveled properly. That can throw the leak/water sensor off big time. Contact a professional - this might be covered under a limited warranty with your manufacturer.
Sep 03, 2012 | Electrolux Dishwashers
Frostfree freezer leaking from lower front
From what you have described, without a model number, it sounds like the unit is leaking from possibly going into a defrost cycle. Check to see if you have any ice build up that is now melting or "slushy" in that general area. Water tends to run along the nearest plastic ridges and parts til it can escape underneath.
Jul 31, 2012 | Electrolux Frigidaire Professional Series...
Ewdw6505gso electrolux. error 1. have turned off
the water will have leaked into the drip pan underneath, which is installed to protect your floors. Unfortunately, only way to get at it is to pull out dishwasher and remove 3 phillips screws that hold it on. In order to repair leaks, Electrolux came out with a "leak kit", which is part number 154769101. Comes with all parts that they had leak issues with
Mar 14, 2010 | Electrolux EWDW6505GS Fully Integrated...
EWDW6505GS0 Model Electrolux dishwasher 10 months in service has Error Code 01. Leak. What to do?
Feb 14, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
All the light on my new, Electrolux dishwasher are
Remove the kickplate at the bottom of your dishwasher and see what error you are getting. Likely a leak error.Dishwasher likely has leaked into drip pan underneath. Unfortunately, you need to remove dishwasher and flip onto back and remove 3 phillips screws that hold drip pan in place. Install "leak kit" to correct leak problem with this model of dishwasher. Part number is 154769101
Jan 25, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
Electroluxe dishwasher starts and once water runs it quits working and all the lights on the display start blinking and it won't work. Any ideas?
Electrolux 6505GSO dishwasher. Says ERROR 01 onled panel and will not function. What is this code and how can I make the the thing work?
Dec 31, 2008 | Electrolux 24 in. EDW5505EPS Stainless...
Dishwashers Logo
94 people viewed this question
Top Dishwashers Experts
