Question about Kenmore 57029 Side by Side Refrigerator
Model: 363.50242000 The freezer is not cold enough and refrigerator is warmer than usual. And frost build up on the back panel of freezer. I cleaned condenser coil. I hear all sounds as usual. Nothing seems stopped. Please let me know what to do.
  • Kenmore Master
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly. The symptoms you describe are typical of a refrigerator that is not being automatically defrosted.
Take a look at this picture item 257 to locate your defrost timer. ( PN WR9X489 )
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fE2141186-00007.png
Actual part:
http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Refrigerator-Parts/WR9X489/0046/363/Model-36350242000/0582/0165000?keySuffixId=NA&productTypeId=0165000&searchModelNumber=36350242000&subCompDesc=Fresh%20food%20section&brandDesc=KENMORE&modelDesc=REFRIGERATOR&pathTaken=partSearch&blt=11
Using this picture.... I want you to rotate the dial on the face of the defrost timer untiol you hear a click. (It can only rotate in on direction viat the tabs.) The compressor and the fans should shut off and the defrost cycle should begin. The defrost cycle should last for around 40 minutes or so. If after 1 hour the unit does NOT restart by itself rotate the dial again until it clicks and restarts.
You most likely have defrost problem and the failures can be:
1. the defrost element,
http://www.appliancepartspros.com/part_details.aspx?part_id=2071523
2. the defrost thermostat
http://www.appliancepartspros.com/part_details.aspx?part_id=2071262
3. or the defrost timer.
http://www.appliancepartspros.com/part_details.aspx?part_id=2061695
Worst case.. you do a manual defrost with a fan for about 2 hours to get rid of the excess ice. Your refrigerator auto defrosts every 16 hours and 35 minutes. Doing a manual (external fan) defrost will get you 3 days max of normal temps and you will have to go through the manual defrost drill again. You need to find out why it is not normally defrosting.
Thanks for choosing FixYa,
Kelly
Posted on Nov 13, 2010
Hotpoint Future fridge freezer - freezer working well but top of the back of the fridge has a large build up of ice ??? And doesn't appear to be keeping the food cold enough
here are lots of things that can cause cooling problems. One of the most common causes of poor cooling in a frost free refrigerator is a defrost system failure. In such a case one or the other compartment may appear to be keeping proper temperature but that too may change in a short period of time. The fridge compartment's temperature rise is usually (but not always) the first to be noticed. Frost" and "Ice"
There is a difference between "frost" (a white, snow-like substance) and "ice" (usually clear and solid). When referring to what is seen during an inspection, please keep this distinction in mind as the possible causes for each are often very different. The Defrost System
Inspecting the (usually rear) wall of the freezer compartment for a frost build up is necessary. (In the case of many GE top freezer models, check the freezer's bottom panel.) If there is a frost coating on it, it is often a sign of excessive frosting beneath it. Sometimes however the evaporator cover panel will actually need to be removed (see the illustration below) before an excessive frost build will visible.
The refrigeration system's evaporator (cooling) coil is usually in the freezer compartment. This evaporator will periodically frost over and have to be defrosted by means of a heating system. When the defrost heating system fails, the frost can accumulate to such a degree that airflow throughout the appliance is hampered. There may be just enough air circulation to cool the freezer section but that will eventually stop too.
Sep 28, 2016 | Hotpoint Refrigerators
I have a whirlpool refrigerator model #GT15HTYMQ81
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets. The defrost timer The defrost thermostat (also called the bi-metal switch)
Aug 21, 2011 | Whirlpool GT1SHTXM Top Freezer...
Refrigerator does not freeze enough
Lets have a look at rear wall of freezer, is there frost building up? Usually in top freezers the cold air settles to bottom and you don't notice fresh food section until about a day. If frost is building open fresh food sections door and in control panel=> CLICK HERE see item 257 in photo? That is WR9X565 or 311082 Defrost Timer Just below that is the control panel cover and you should have a small plastic plug covering a hole just below the defrost timer. Pry plastic plug out and using a flathead screwdriver turn the defrost timer clockwise slowly. Once you hear the compressor and fans stop stop turning timer and about a minute later you should hear some crackling noise coming from freezer. Allow to stay like that for up to 30 minutes and timer should come out of defrost and compressor and fans should start again on their own. If this action caused defrost then replace the defrost timer. If that does not seem to cause defrost the we need to go to step two, unplug and place items in a cooler or alternate refrigerator and use a hair dryer to assist in melting the ice behind rear panel. Remove rear panel in back of freezer and see => Freezer Components item's 621 and WR51X10038 or 880036 Defrost Heater Assembly
You will need to remove rear panel and work with refrigerator unplugged from power. On this=> Page watch how to test your defrost element just beside a photo of the timer. Most times I replace the defrost thermostat while inside freezer wall but I will let you try this first and please respond and rate, Thanks, Sea Breeze
Feb 13, 2011 | GE GTS22KBP Top Freezer Refrigerator
Freezer cold. Refrigerator very warmer.
Hi there. This should be a self defrosting unit. Check the defrost clock. It's usually behind the grill at bottom front of frig. or near the compressor. There is probably a little window on the clock motor where you can see it turn. You can manually advance the clock to put the unit into defrost mode. Check the defrost heating element. This is the usual problem. It is under shrouds where all the frost builds up. If element good, check defrost thermostat connected to element mechanically and in series electrically.
Thanks
Paul
Jul 12, 2009 | Kenmore 61042 Top Freezer Refrigerator
Refrig not cold enough, ice buildup on banck panel of freezer
ice build up means your refrigerator is not going through defrost cycle. you have ice build up on evaporator which restricts your cold air flow into the fresh food side. check defrost timer, defrost thermostat located on evaporator behind the wall where your getting frost. check defrost heater. it wraps under the evap.
Jun 21, 2009 | GE Refrigerators
Freezer/refrigerator
Refrigerators with an evaporator (called a humid plate on this type of refrigerator) in the refrigerator section are called a semi-automatic defrost. This means that the freezer section occasionally needs defrosting but the refrigerator section defrosts by a means called "heat leakage defrost". How it should work....
the cold control, (the electrical device under the dial), leaves the compressor off for long enough for the plate to melt off each cycle.
If yours is not melting off perhaps you have a faulty control or you have it set too high. hope this help
Oct 07, 2008 | Frigidaire Freezer Refrigeration White...
Frost build up on the back wall of the freezer
The thermostat is not functioning the way it should leading to frost build up. You need to replace it. Should cost you around 40$
Sep 02, 2008 | GE GSS20IEM Side by Side Refrigerator
Ge side by side not cold enough in fridge or freezer
if there is no frost build up in freezer section sounds like a refrigerant leak
Apr 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore 57029 Side by Side Refrigerator Logo
245 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
