That means that a problem occurred with the airbag.
This is a common fault with clios especially the 3dr models but it still occurs in the 5dr models as well, I've had a 3dr clio and currently own a 5 dr clio as I'm a young driver my friends move the passenger seat back and forth a lot so this is causing the problem, to fix it cost free you have to.
1) Open the car - leave keys out of ignition
2) Look under drivers seat, middle front for a grey connector with a yellow side clip
3) Pull the yellow clip sideways, then disconnect the grey connector - count to 30
4) Plug back in, push yellow clip back in
5) Start car - serv light + airbag light off
If this still doesn't work repeat on passenger side seat
Hope this helps its worked for me in both of my clios! :)
CHECK WIRE CONNECTERS UNDER FRONT SEATS SOLVED 3 CLIOS WITH THIS PROB
had an interior fire, replaced sensors,seat, steering wheel and wiring light comes on blinks 7 times and service airbag comes on. will resetting code help?
i have got a clio 1,4 s and it has got the same problem as the SERV lights and airbag lights stayin on all the time.... i checked the wire connecters under front seat tried all the ways writing on internet etc etc...
any other ideas????
