Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Starts runs for a minute two the shuts down and blowes smoke
  • 232 Answers
By design the heater will shut down anytime there is a flame-out. If there is a flame-out (fraction of a second) there is nothing there to re-ignite the flame because the ignitor only glows long enough to initially start the flame and the flame must keep itself going.
The black smoke tells me that the pump is still pumping fuel(?) into the hot chamber, therefore black smoke.
My suspicion is there is some water in the tank causing a momentary flame-out condition when it passes. I could be wrong because there are other causes, but this would be a good starting point.
More troubleshooting tips.
Posted on Nov 13, 2010
  • 1,476 Answers
Jerome kr406,
This is a classic problem with the reddy heaters. They have a filter which over time plugs up. This causes the air/fuel mixture ratio to change because the pump pressure is determined by the air bleed. As the filter plugs the air pressure drops and the fuel also drops meaning the burner is running lean. This eventually causes the unit to shut down and as you said smoke comes out. It is a fairly easy fix and I have a tip which will walk you through it at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters . My tip will link you to the place to get the parts you need as well as how to perform the additional maintenance that these heaters require.
Thanks for using FixYa and for the excellent rating. Great ratings help to keep experts helping everyone solve their problems. Thank you.
hardrocko
5 Suggested Answers
SOURCE: reddy heater pro 110
My best guess is that you are are connecting to your AC receptacle with an extention cord that is too small. The Reddy Heater contains a computer that will shut the unit off if it cannot pull enough amps from your service. The longer the cord the higher the loss from receptacle to unit. This loss can be reduced by increasing the size of your extention cord. I run a 100' 10/2 cord.
Hope this helps!
Handy Home Guy
Boone, NC
HandyHomeGuy.com
Posted on Nov 22, 2008
koolbreezes
  • 540 Answers
SOURCE: ready heater forced air runs few minutes then shuts off
Sounds like a full services like its getting too much air,and blowing out the flame. Check your fuel filter,and add a new spark plug ,also change the vanes on the pump, thus aFuu service. these sould be performed every fall before .
Posted on Dec 18, 2009
  • 69 Answers
SOURCE: i have a master 150000 btu kerosene direct fire
The white smoke is the kerosene fuel hitting the hot combustion chamber. Your flame has went out. The cause for this could be many. The first thing you need to do is check your fuel. Remove your fuel cap and look at the bottom of the tank for trash or water. Use a good flash light. It will all settle to the bottom. If so, drain and clean out your tank. Add fresh kerosene. Check your fuel filter. Replace if dirty. Test again. If problem continues, It is possible that your photo eye could be deffective or just dirty. It is located next to the ignitor or spark plug. It sees the flame. If the flame goes out, the unit shuts down. The flame has to be smooth (not sputtering). Water in the fuel will make it sputter and the unit will shut down. When the water/moisture in tank settles to the bottom, your suction fuel line is just off the bottom which results in it picking up the water instead of good fuel. Always disgard the old fuel from previous year and start with fresh fuel. This will cut down alot of your problems in the future.
Posted on Dec 10, 2010
  • 674 Answers
SOURCE: I have a knipco portable
Check the air line and the fuel line. Look for cracks in the lines. Also check where the air line connects to the fan motor and fuel nozzle and the where the fuel line connects to the filter and the fuel nozzle. You need it to fit tight. If it is stretched out trim some from the ends and put them back on. This will help them fit tighter. Also check the fuel filter. If this doesn't help let me know and if it does don't forget to rate the answer.
nitensheaterservice@earthlink.net
Posted on Jan 11, 2011
My Dayton heater will not fire up and tries to fire and then shuts down tries to fire and shuts down blows smoke out the end
Check noggle for dirt, check fuel filter for dirt. Check al rubber hoses for leaks, Set air pressure All these will cause it not fire.
Dec 28, 2014 | Dayton Heating & Cooling
Reddy repair center
There are four possible answers to this problem, if the heater starts normally, runs for a few seconds or minutes and the shuts down but was still running normally at the time of shut down, this could be caused by the photocell, also known as the flame out control. This safety device may be failing, shutting down even though the heater is working normally, check the operation of the photocell. The second cause may be partial fuel filter blockage, the heater is effectively starving itself of fuel, so the flame blows out, hence the puff of smoke, and then shuts down on the safety cut out. Third cause, if this model has a compressor at the rear of the motor, the problem could be low pump pressure, caused by wear or contamination of the carbon blades, this would cause the wrong amount of fuel to be syphoned up, with weak fuel mix the heater may blow itself out and shut down. The fourth cause, perhaps indicated by the puff of white smoke, is contamination of the fuel with water, water will cause the white smoke and also is indecated by white residues or a power like substance on the end plate of the heater which glows red hot when burning.
Jan 24, 2014 | Desa International R40 Utility Heater
What causes a 1995 chevy blazer 4x4 4.3 die when u come to a dead stop ?
Try doing the following.
Engine stalling issue at low speeds
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
Jun 18, 2012 | 1995 Chevrolet Blazer
Lawn Boy pushmower blew out lot of whitish-blue smoke after starting (has not run in 110 days). Checked oil level, was to high, so removed some oil, after thar ran fine but after 10 minutes, same...
Hi, change the oil and your problem will be solved. Basically it was over full because fuel has by-passed the carby needle and leaked into the sump while its been sitting idle. Regards Phil.
Aug 14, 2011 | Garden
I just bought a briggs 23 hp single cylinde engine and repowered my tractor and having alittle trouble,it has about 4 hours on it, but when mowing uphills it blowing alot of blue smoke, and engine just...
Hello, You have too much oil in it.
Your air filter is most likley soaked with oil and need to be replaced. Are you sure it's a single cylinder?
Hope this helps.
Jul 28, 2011 | Garden
I have a Simplicity model 1692762 with a 16hp Briggs and Stratton. The mower blew large plume of white smoke three times while cutting grass over a period of 10 minutes. Engine seemed to lose some power...
I suspect an internal engine issue such as a valve, the white smoke was oil and it could mean a bent, burned valve or damaged valve seat causing the valve stem seal to leak allowing the engine to **** some oil and burn it (the white smoke) and now you lack compression. It is less likely but possible the oil was overfilled and you "lipped" the piston which causes the compression to drop. check the compression, 100-120 is normal, less than that means bad internal parts.
May 27, 2010 | Garden
Readyheater portable forced air 170,000btu/hr
reset switch my heater did the same thing after 5 sec of running
Dec 20, 2007 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
229 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
