Question about Samsung Galaxy S GTI9000 Smartphone
My samsung galaxy s gt19000 will not save the bluetooth connection pairing to my car and 'automatically' connect the next time I get in. I have to re pair it each time. It works fine in my wife's car. Any advice....Beees
Will not connect to blue tooth in car
Posted on Feb 24, 2011
This sight did not help me at all
Posted on Feb 09, 2014
I recently purchased a JBL Flip 3 bluetooth speaker. Although I had no problem pairing my Samsung Galaxy 7 to the speak, I cannot pair the speaker to either my Verizon tablet nor my Dell Inspiron.
This usually happens when your speakers has hidden feature, try to look for for appear option. When trying the next time make sure that your paired device is not connected to it, as most probably it can not connect to two devices at time.
Dec 26, 2016 | JBL Audio Players & Recorders
Is the bluetooth on Capella sleep and sound alarm clock, CR50, compatible with an Android samsung galaxy s4? I can't get it to pair
Samsung Galaxy S4: Trying to pair by Bluetooth to Capella CR50 Desk clock: Unable to pair:
Hello..
Yes, the Capella CR50 should be able to Bluetooth pair with any device that can connect via Bluetooth (as stated in the Capella product description).
If you are not able to connect try doing the following (process of elimination) to resolve why this is happening:
  • Turn off and turn on again Bluetooth mode
  • Try resetting the Bluetooth app in Applications>All Applications under Phone Settings
  • Try eliminating apps that may be affecting the bluetooth connection.. you can narrow this down by rebooting the phone into Safe Mode. If in Safe Mode, your S4 is able to connect via bluetooth to the Capella CR50, that will tell you that it is software related, and most likely an app that you installed that is not playing nice with your phone. You can either remove apps one by one and retrying to connect via bluetooth to find and eliminate the issue, or remove all the apps you installed and start fresh.
(Note: removing an app with erase any settings you set up as well as any database within the app (such as a game with scores/levels/and any rewards you received/purchased, unless that database is saved in an online cloud account you sign into specifically for that app, or sync to Facebook (FB) while having the game installed in your FB account
How to get S4 in and out of Safemode:
How To Set Up Bluetooth On Your Samsung Galaxy S4 Phones 4u
Jan 29, 2016 | Samsung Cell Phones
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
I have a Schwinn Blue Tunes Bike Speaker. It pairs to my Samsung galaxy S4 through Bluetooth with no problem. I am able to control my spotify account with no problem using the device. I am able to play,...
It seems many people use only the term "paired" when talking about CONNECTING two Bluetooth devices. Connecting two Bluetooth devices means first "pairing" them and then "connecting" them. Pairing is a one time process done only the first time you try to connect the devices. It is like the two devices getting to know about each other. Next step is to actually connect the two and this process is done the first time after the pairing and then every time you want to use the speaker from your phone. When you open the Bluetooth tab on your phone's Settings menu you will see the names of all the Bluetooth devices it has been paired with previously and a "Paired" word next to it. If you want to use the device/speaker, tap on the name and it will CONNECT to it. You will see the word "Connected" instead of "Paired". Now you should have the music that you play on the phone coming out through the speaker. If you still can't hear the music over the speaker after a successful connection, turn up the volume on your phone (and on your speaker, if it has its own volume controls).
Feb 08, 2015 | Samsung Radio Communications
Bluetooth is paired. Works for about 1 day. Then will not connect again.
Did you try the "Device Discoverable in ___ secs?".In settings, Make device discoverable first then set the length of time. Android phone have this limited BT capability i think.
Nov 14, 2013 | Motorola Mobility L512bt Cordless Phone
Ace galaxy problems
Hello John,
You can download an application for your phone like Bluetooth Auto Connect from Google Play Store and it will auto connect your mobile to your car for you!
Also you can set a number of rules and priority for multiple bluetooth devices!
After you have download the application, connect and pair with your Bluetooth device manually (this is a requirement) and then just turn off and on Bluetooth (or leave Bluetooth on and turn the screen on) and it will auto connect.
Nov 06, 2013 | Cell Phones
Connect bluetooth
Go to Settings > Bluetooth > (Find the speaker you are trying to connect to and delete it from your "Paired Devices" list.)
Then, try it again! Voila!
Oct 28, 2013 | Samsung Galaxy Tab 4G 10-in 32GB White...
Transfer pix on my computer to my galaxy s
You can do it in few ways.
1. By bluetooth. You need to pair your galaxy with your computer. If no bluetooth on your computer then proceed to option-2
2. Connecting the galaxy in USB-Harddisk mode. Just plug in the USB cable that came with the samsung box and your PC should recognize the galaxy as a mass media storage. You can simply copy & paste the images
3. Using PICASA. the android can connect to your picasa albums and download
4. Install Samsung Kies and after that you should be able to transfer pictures automatically (sync)
Hope it helps..
Mar 15, 2011 | Samsung Galaxy S GTI9000 Smartphone
Hi, I have purchased Samsung Galaxy ACE S5830 whether it is possible to connect Samsung Bluetooth Headset WEP 450. Kindly inform me how to do it.
1 Enter Pairing mode. • Turn off your headset and press and hold the talk button until the blue indicator light remains lit after blinking. • If you turn it on for the first time, it proceeds into Pairing mode immediately.
2 Search for and pair with your phone --> turn on the bluetooth with the widget on the home screen or in the settings. (Bluetooth PIN: 0000, 4 zeros)
• If the pairing is successful, the blue indicator light will flash 10 times rapidly before entering Standby mode. • If the blue indicator light remains lit, retry pairing.
Mar 13, 2011 | Samsung WEP450 Bluetooth Headset - Retail...
Blueant supertooth not pairing to samsung omnia i900
Hallo Stu,
Try following the below instructions, if you haven't already tried them..
First Time Pairing to your Bluetooth Mobile Phone
When you turn ON your Supertooth Light for the first time, it will automatically go into Pairing mode ready to be found by devices in Bluetooth searches. This will be the case until you have successfully paired a phone. If you have already paired a
phone, please go to the next section.
1. Power ON your Supertooth Light. The Bluetooth Indicator (3) will turn a blinking
red/blue, The kit is now in pairing mode.
2. Go to Point 3 in the next section, “Pairing to your Bluetooth Mobile phone”
Pair the SUPERTOOTH LIGHT to your Bluetooth mobile phone to create a “Pairing”
link, or audio connection between the two. This has to be only done once when first connecting each new phone.
1. From OFF, Press and Hold the Accept Button (1).
2. While holding the Accept Button (1), switch the kit on (Press-and-release the
Microphone Shaft (5)).
3. The Bluetooth Indicator (3) will turn a blinking red/blue, when you see
this, release the Accept Button (1). The kit is now in pairing mode.
4. While the kit is in pairing mode, access the Bluetooth menu of your phone. Turn on the Bluetooth function then execute a Bluetooth search, or discover. (See your phone’s manual for specific instructions.)
5. When the phone displays the list of Bluetooth devices, select ST LIGHT.
6. When the phone asks for the password, enter 0000 and press Ok.
7. Set the ST LIGHT as a trusted/authorized device, if this is option in your phone.
Important Note: The kit is now paired. Most phones automatically connect to the
kit after pairing. With some phones you need to connect manually after pairing.
Go back to Bluetooth > Paired devices > highlight ST LIGHT > press
Options > then press Connect.
When connected you may see the Bluetooth Symbol on your phone change
slightly, either inverting in color or changing to a headset or car symbol. The kit
is now ready to use.
Repeat steps 1 -7 above for each new phone you want to use with the
Supertooth Light.
This was copied from the user manual, which you may or may not have already.. Here's a link to a .pdf file of the manual which you can also save to your computer:
http://www.blueantwireless.com/downloads/supertooth_light/supertooth_light_manual.pdf
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Dec 24, 2008 | Blueant Supertooth Light Bluetooth Speaker...
Samsung Galaxy S GTI9000 Smartphone Logo
650 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
