Question about Canon PowerShot A70 Digital Camera
View screen on back of camera blank,ie dark. No picture follows despite looking thru manual view-finder.
  • Canon Master
  • 17,970 Answers
Hi there:
CCD problem would explain the black or lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used in digital cameras.
Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value. This last step occurs outside the CCD, in a camera component called an analog-to-digital converter.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details: Bad CCDs. This, isn't a good new, but hope helps to solve it.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day
Posted on Jan 04, 2012
I have canon sd 750. its lcd gets black. Shows pictures etc but view finder remains dark. display is zz. what to do?
Look for DISP or DISPLAY button in the lower-right corner of the back of your camera. Press this once while the camera is turned on. The DISPLAY button manually turns the screen on and off. This is to save battery power for extended use. You would then use the optical viewfinder in its place.
Oct 25, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
WHEN I LOOK THE THE VIEW FINDER IT IS VERY DARK.
mirror is struck to ground glass/failure of the mirror mechnism
Mar 02, 2010 | Minolta XG-A 35mm SLR Camera
Images thru view finder are blurry
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Oct 04, 2009 | Canon PowerShot A60 Digital Camera
View screen is white (blank) with internal cracks
Look fo the switch that has two setting. one of them will say LCD and the other Migt EVF if you have a view through your view finder this is your problem.
Jun 28, 2009 | Samsung L200 Digital Camera
No image in view finder
There is definately a problem with the camera. You will want to call Canon technical support and seek repairs.
Please mark as FixYa!
Aug 25, 2008 | Canon PowerShot A60 Digital Camera
SCREEN AND VIEW FINDER BLANK
Is the battery dead? Try taking it out and charging it, then put it back into the camera.
Also, you can try using another battery of the same type.
May 30, 2008 | Panasonic Lumix DMC-FZ50K Digital Camera
Blank view finder fe-190
try switching your camera on in a dark room (do it at night with the curtains closed and the lights off).
if the screen lights up (should still be black or a very dark green),
then the lens or light sensors might not be functioning correctly.
if the screen stays conpletely black, then the actual screen might be damaged.
note- you might need to let your eyes adjust to the darkness before you switch your camera on.
May 22, 2008 | Olympus FE-190 Digital Camera
Streaking in view finder
The problem you are having is the bad ccd board . It is covered underr a recall notice from NIKON .
Just send it in
Feb 06, 2008 | Nikon Coolpix 5700 Digital Camera
No picture on view screen of my ixus 400 cannon
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Jan 09, 2008 | Canon PowerShot S230 / IXUS 179 Digital...
Blank view finder and screen
I fear that your camera is having damaged CCD. Pls contact nikon service centre for free repairs as it is a manufacturing defect.
Aug 19, 2006 | Nikon Coolpix 5700 Digital Camera
Canon PowerShot A70 Digital Camera Logo
93 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
