Question about Windsor SR12 Sensor Bagged Upright Vacuum
Red light indicating bag is full, but is not.
  • 4,340 Answers
Look for air flow restrictions, like plugged passageways. sometimes it is difficult to get to every part, but with restricted air flow, you could have the indicator turn on.
Posted on Nov 13, 2010
Red light indicates bag is full when it is not
you could have vacuumed up a fine powder that is clogging the bag.
Oct 08, 2014 | Vacuums
Get red light off after changing filter
Depends on which model you have. If it's a red light it might be your full bag indicator. If it's glowing red you might have a clog somewhere .
Jan 07, 2014 | Riccar Vacuums
Riccar 8850 red light is on and won't go off, I changed the bag but do not know what the light indicates
The light indicates a restriction, a full bag or clog or something restricting the airflow
Dec 15, 2013 | Riccar Vacuums
The red light on my electrolux vacuum comes on and cuts power.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 26, 2010 | Electrolux Guardian Bagged Canister Vacuum
Bag was full, changed it, the unit now turns off
Try dialing the control valve to the mid way position. If the unit still shuts down with the bag full light on you have a damaged control valve under the dial on the top of the vac.
This valve failure is common in this model and can only be repaired by someone with original AERUS Electrolux repair parts, generally at an AERUS repair shop.
Oct 29, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Bag full indicator light on only when I plug the hose back in...
drop a marble or something similar through the hose to see if its clogged
Sep 11, 2009 | Bissell 3522 PowerForce Bagged Upright...
Red "bag is full" indicator shows even though new bag has been put in and vacuum cleaner wont pick up. Also floor adjustment does not adjust. This is for a powerforce model 3522 series
The red light tell you that it is sensing a full bag. But a clog in the hose or the inlet down by the brush roll will also do this.
Apr 17, 2008 | Vacuums
Red light won't turn off
You probably have a clog in either the hose, or the dirt inlet by the brush roll. That red light is telling you that either the bag is full or a clog is not allowing suction.
Mar 14, 2008 | Vacuums
Red light stays on
Most likely the hose or the inlet down by the brush roll has a clog in it. The red light indicates a full bag, but if there is a clog, then it thinks it has a full bag.
Dec 07, 2007 | Lindhaus Activa 30-38 Bagged Upright...
Windsor SR12 Sensor Bagged Upright Vacuum Logo
179 people viewed this question
Top Windsor Vacuums Experts
Mike
Thatvacguy.com
Are you a Windsor Vacuum Expert? Answer questions, earn points and help others
