Question about Virtual Reality Black Vr3 Wrless Backup Camera W Color Monit
I have this backup cam on the top of my license plate, got power, however, all I get is snow on the monitor ? Any ideas are greatly appreciated to get this ****** functional. Thank u for ur time and assistance in this matter.
  • 4,340 Answers
Look for any connections and verify that they are clean and not corroded. Some head units have more than one input, as some laws dictate that the camera can ONLY be on in reverse...so one port gets a signal from the backup light circuit, and the others do not..anyways, look for what port the wires are hooked into.
Posted on Nov 13, 2010
  • Mike Nov 13, 2010
    I presume, however, that it is NOT actually snowing.....
  • t7para Nov 13, 2010
    Ty for ur rapid response, I checked it in reverse still just snow but it only stays on for about 5 seconds and the power light stays on. I'm paralyzed from getting deployed n Iraq and is hard at the moment to check fuses due to my wheelchair confinement, but many thanks to u anyway.
Tail lights work but why don't license plate lights?
The license plate lights have their own separate bulbs. If you are able to replace the bulbs, that may solve your problem. If not, you may have a loose or rusted connection to the plate bulbs only. If you are able to gain access, you may want to check the condition of the harness that supplies the power to the license plate portion. Good luck and have a great day.
Aug 30, 2015 | 2001 Toyota Tacoma
How do I replace the license plate bulbs?
The license plate lights are accessed by unscrewing the lens. The backup lightbulbs are accessed with the trunk lid open, behind the cover.
Jan 13, 2010 | 1992 Honda Accord
No power to tail lights or license plate light.
check the fuse with a test light on both sides of the fuse,
next would be the headlight switch.
Jan 08, 2010 | 1995 Dodge Dakota
2001 Miata check engine light on. [cause is P0012]
The cam angle sensor need to be replace. Once it's cooked it will never the same.
Have to consider moving to synthetic oil (Like Amsoil) or remove the front license plate (please check state regulation first).
I'm using Amsoil Synthetic
10W-30 in summer and 5W-30 in winter
Use 65/35 Amsoil coolant mix ration instead of 50/50
Removing the license plate does help air flow.
Clean junk collect in front of the A/C condenser and radiator.
Check radiator cap's plastic gasket.
Get a Rad-Cap
Check/Clean the ECU contacts with CRC electronic part cleaner,
@ 85,000+ miles be prepare for timing belt + water pump change.
Clean / change temp sensor ///// monitor electric fan for operation.
Cam sensor can not be overheated.
<230 F is ideal
I listed everything that can keep the motor cool.
Please rate my answer if it's helpful to you.
Cheers,
MUSTGO
Dec 12, 2009 | 2001 Mazda MX-5 Miata
99Century My license plate and backup lights don't work
remove the light pannel and check the sockets for corrosion and the trunk release should be in the glove box
Nov 04, 2009 | 1999 Buick Century
License plate bulbs on 98 Park Avenue
License Plate Lights Removal & Installation 1997 – 2000 To Remove:
License/backup Lamp Assembly
  1. Remove the rear compartment lid trim. (if necessary)
  2. Disconnect the license/backup assembly connector from the body harness.
  3. While removing the license/backup lamp assembly from the rear compartment lid, disconnect the harness grommet from the rear compartment lid.
  4. Remove the license lamp housing from the license/backup lamp assembly.
  5. Remove the license lamp bulb from the housing and socket.
To Install:
  1. Install the license lamp bulb into the socket and housing.
  2. Install the license lamp housing onto the license/backup lamp assembly
    • Torque the fastener to 18 in-lb (2 Nm).
  3. While holding the license/backup lamp assembly, install the harness grommet to the rear compartment lid.
  4. Install the license/backup lamp assembly
    • Torque the fasteners to 53 in-lb (6 Nm).
  5. Connect the license/backup assembly connector to the body harness.
  6. Install the rear compartment lid trim. (if necessary)
Jun 30, 2009 | 1998 Buick LeSabre
I have no tail lights or liscence plate lights
Does the fuse have power in and out when a test light is used? This test would be run with the light switch on.
Mar 16, 2017 | 2005 Nissan Frontier
Wiring installation for back up camera monitor
yes the black is ground, the red goes to a constant power in the fuse block , and the blue goes to the reverse wire to activate the monitor
Feb 25, 2009 | Virtual Reality Black Vr3 Wrless Backup...
Rear view camera setting???
Dear debbie,
This could be caused by the following:
Purple/white "reverse sensor wire" not connected to vehicles reverse lamp harness. (Are your reverse lamps functioning?)
OR
Reverse cam video out not connected to Kenwood's "rear view camera input" (Yellow RCA socket behind the unit).
The monitor set up controls merely switch R-cam betwen "full, just, zoom and normal" modes. No provision here to ebnable or disable the cam.
When you put your car in reverse dos the monitor screen change?.
Jango
Dec 11, 2007 | Kenwood DDX7019 6.95 in. Car Monitor
Virtual Reality Black Vr3 Wrless Backup Camera W Color Monit Logo
271 people viewed this question
Top Virtual Reality Home Security Experts
Lawrence Oravetz
Are you a Virtual Reality Home Security Expert? Answer questions, earn points and help others
