Question about Dell Computers & Internet
Blue Screen error on Dell Inspiron 1440. Suddenly shuts down, sometimes it completely crashes. I wonder what's causing the problem and how to prevent it?
Pyrhyc
  • 2028 Answers
SOURCE: Dell Inspiron 8600 - overheating and shutting down
Start by cleaning the fan and heat sink. Dirt or dust build up can cause them not to work as efficiently as they should. If cleaning doesn't fix it, you might consider replacing the fan and heat sink or purchasing a cooling pad.
Posted on Jul 22, 2008
rachelgeek23
  • 155 Answers
SOURCE: Dell Inspiron 6000 PC Notebook, No Wifi Radio Signal
Open Intel Proset Wireless or Dell wireless utility from start>all programs. Make sure the the checkbox for 'enable radio' is checked.
Posted on Jan 02, 2009
  • 110 Answers
SOURCE: Problem in internal speakers in dell inspiron 1440
Probably just a software setting...many different things in software could cause this.... OS, driver, something... but could be bad speakers.
Try external speakers in the headphone jack.. if they work fine, then probably bad internal speakers.
Software is the most likely culprit.
Posted on Sep 08, 2009
  • 30 Answers
SOURCE: Dell Inspiron Mini 10 Not Shutting Down Properly
There could be a corrupted file. I would try to give dell tech support a call
Posted on Sep 21, 2009
cabanagj43
  • 225 Answers
SOURCE: Dell Inspiron 1440 keyboard keys issue
you need to isolate this issue first.
where are you typing? inside IE or in MSWord?
If both has issues then try typing in the DOS Command Window. If same issue try to boot in safe mode and check if you will still be getting same issue in safe mode. If all yes try to check the bios and update it by downloading the latest bios version from the support site from dell.
Posted on Oct 06, 2009
Sudden Shutdown due to Overheating
either your power adapter os faulty or the cooling fan inside the laptop had failed forcing the laptop to shut down as safety precaution.
Aug 29, 2012 | Dell Inspiron 14 N4010 Laptop 4g 500gb...
I have a dell xps m140, when I turn on the computer I get a blue screen with the message, STOP: c000021a {FATAL SYSTEM ERROR} the windows logon process system process terminated unexpectedy without...
Hi
You do not say which operating system you are using.
A blue screen can have many causes, so you need to undertake an elimination process to identify the cause.
Most importantly, do not repeatedly keep trying to boot if blue screen keeps appearing, as this could lead to hasrdware failure. It is important to identify and fix the fault as soon as possible.
If you read the full error message, there will usually be an indication of the likely cause of the crash as well as some suggested remedies.
Typical causes are:
Conflict with newly installed software
Driver conflict or corruption
Malware infection
Insufficient Hard Drive space
Operating system corruption
Hard Drive fault
Overheating
Memory corruption
Graphics card fault
Each of these will have a different remedy.
Start by studying the error message in more detail, try the suggested remedy options, then post again with more specific information, if necessary.
Hope this helps.
Aug 22, 2011 | Dell Inspiron XPS M140 Notebook
My dell laptop suddenly started getting a blue screen error and crashing, the error is driver rlqc not less or equal, the laptop is still under dell warrantee is it covered by the warrantee if not how do i...
The Blue Screen Error IRQ Driver not less or equal is a memory problem. Basic things you can do is reseat the memory. However, I highly suggest to contact Dell and have them guide you in doing a Memory Diagnostics. They should replace it if its faulty.
Mar 30, 2011 | Dell Inspiron 1525 Notebook
How do i fix blue scree error tha reads stop:0x0000007E
is this a recurring problem. There isn't much you can do, usually a software crash causes this,
maybe defrag the computer, uninstall any unneccary software, run a virus scan, etc. Sometimes it just happens, if it happening all the time, there maybe a hardware problem, or you may need to restore to factory settings.
Jan 06, 2010 | Dell Dimension E310 PC Desktop
Computer crash
this is all happen to not properly shut down, if your read the problem from blue screen so we can identify it give you some instruction how to fix it. YOu know only one can repair this is a computer technician or expert.. but i think you don't have so maybe your the one going to do it, here's is a instruction: 1. Put a Bootable System Disk XP or Vista or etc. 2. Make a Bootable Disk run before the system comes up... 3. Follow the procedure which appear on the screen... then so on.
Jul 09, 2009 | Dell Inspiron 1000 Notebook
Blue error screen and system shutdown on Dell Dimension C521
Rule of thumb test ram out first usally that is the cause what does the code say on the blue screen
Feb 13, 2009 | Dell Dimension C521 PC Desktop
Blue screen with error message on startup
Most likely problem is a physical problem with the hard drive, but could be plenty of other things. Best bet is to back up your information (if possible) and do a fresh windows install, if you continue to get the message after a clean windows install, your hard drive is not stable, and has a problem.
Dec 30, 2008 | Dell Inspiron 6000 Notebook
Hard drive undetectable
first u check ide cables and u check ide connectors on the mother board
Dec 15, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
239 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
