Question about Toshiba Satellite A65-S126 Notebook
Toshiba Satellite AC Adapter?
My sister managed to break my power adapter for my Toshiba Satellite A215. I need a new one so I can keep my lap top charged, but can't find one that's decently priced.
  • 57 Answers
You can use an adapter with a lower or the same voltage, but not higher voltage. Also it should have similar amperes. Also it needs the same polarity. That's the +/- indicator. This page has a positive polarity symbol:
There's no need to pay ridiculous amounts of money for an exact brand name adapter.
Posted on Nov 04, 2008
    Problem Solver:
  • 19 Answers
The wire on my power adapter was frayed and finally broke rendering it unusable. A new one costs $110. I didn't like that price so realizing I've nothing to lose, I split the case open on the power adapter, recut, strip, and solder new connections for the bad wire, put it back together and use duct tape to hold it together and I'm back in business. They don't usually make the adapters so they can be taken apart but a screwdriver and hammer so delicately used can open it up.
Posted on Aug 08, 2008
  • 284 Answers
Try ebay
usually around 45 Dollars
Posted on Jun 18, 2008
Laptop won't boot up
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. Toshiba Satellite A215 adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Feb 20, 2013 | Toshiba Satellite A215-S7444 Notebook
Toshiba satellite L305-s5955 will not power up
If there is no power light and it can't charge your laptop, it is likely that the charger is dead. You need a new laptop charger. So try a new adapter to confirm the real issue.
There are two kinds of ac adapters for your toshiba l305-s5955
Toshiba Satellite L305 AC Adapter 75Watt 19V 3.95A
Toshiba Satellite L305 AC Adapter 90Watt 19V 4.74A
You should choose the right charger depending on your original adapter's specification. If the original one need 90w, you won't buy 75w that will bring damage to your laptop. If it needs 75w you can use 90w too.
Oct 14, 2012 | Toshiba Satellite L305-S5955, L305-S5956,...
The battery will not charge when the power is plugged in on my toshiba L305-S5021 laptop. Do I need a new battery or ac-adapter?
if the lap top works ok with the adaptor AC , so must to change the battery , find on ebay or amazon good prices
Aug 14, 2010 | Toshiba Satellite L305-S5921 Notebook
My averatec lap top os stuck in sleep mode
Hi. I suggest you try pressing the power button to wake it up or you could also try power draining it and turting it on. To powerdrain your computer you must remove first the battery and unplug the ac adapter then press and hold the power button for 20 seconds, after that you must place back the battery and plugin the ac adapter then turn on your computer. Hope This Helps
Jun 02, 2010 | Toshiba Satellite M100 Notebook
Nothing on my toshiba satellite a215 will come on
Try the following.
1. Remove battery and plug in the AC Adapter and check if it works
2. Check the AC adapter LED indicator if its lighted or not(double check by a multitester)
If lighted - it works properly
if not - replace
3. Try to reinstall WINDOWS operating system by the use of the installer CD
4. If problem persist - the motherboard might be defective.
Thanks. Cheers!
Apr 18, 2010 | Toshiba Satellite A215-S4767 Notebook
Toshiba satellite m35
Are you sure that you fixed the power issue it sounds like there is still a bad connection in the power socket if you want info on this problem go to this site
Mar 29, 2009 | Toshiba Satellite M35-S456 Notebook
There is power in the laptop.
if you say that either the battery nor the adapter was tested and seemed working fine but not actually giving power to the laptop itself then the problem is the motherboard from your laptop i m afraid
sorry i have no idea about the service center in tamilnadu
Feb 04, 2009 | Toshiba Satellite A215-S7422 Notebook
Lap top will not start up
First that u need to do is to remove the battery from your toshiba laptop. Plug in the AC adapter alone and power it on. If it works, then u need to check your battery. If the notebook wont power on with the AC adapter alone, then i think its a NO POST issue. The motherboard needs to be checked.
Sep 16, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A65-S126 Notebook Logo
79 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
