Question about GE Profile Prodigy WPSE4270A
My prodigy does pump out water. - GE Profile Prodigy WPSE4270A
  • GE Master
  • 8,220 Answers
Could be a shoe strang in the pump. Or a coin. Remove the front panel and inspect the pump for obstacles. My prodigy does pump out - themobilian_129.jpg
TRAINING MANUAL
Posted on Nov 12, 2010
Why won't Ice maker make ice?
Scotsman Prodigy - bad Ice thickness probe
May 10, 2014 | Prodigy Scotsman CU1526MA-1A Ice Maker...
Ge prodigy top loader wash machine. washes fine, spins, but water won't drain. have checked for blockage in hose and found none. water will trickle through hose then stop. what do I do? Don't...
Water will not drain from machine
1. Kinked or clogged drain hose---clean hose
2. Pump does not run----readjust & tighten pump, drive mechanism
3. Suds lock---remove suds add cold water
4. Faulty transfer value---replace
5. Defective timer---replace
6. Loose belt----adjust belt
Sep 22, 2011 | Washing Machines
GE Profile Prodigy will not drain water out. It starts and then stops after about a quarter of the water is drained out
Check your hoses to water pump,appears to be a restriction. Have a shallow pan and towels to collect water
Oct 24, 2009 | GE Profile Prodigy WPSE4200A
Ge profile prodigy make clunking before spin cycle
Is there a humming sound? Check you have the hot and cold water supply turned on. Check the water inlet hoses are not kinked.
May 03, 2009 | GE Profile Prodigy WPSE4200A
Ge prodigy wpse4270aoww won't rinse or spin
try to clean out the water pump lines from pump to out to the drain
Feb 25, 2008 | GE Profile Prodigy WPSE4200A
Washer not spining
i think there is problem in your water outlet pump problem first of all you check water is come out or not from machine
Feb 11, 2008 | GE Profile Prodigy WPSE4200A
GE Profile Prodigy filled with water & won't start
If you don't hear a click when you close the lid, replace the lid switch.
Jan 29, 2008 | GE Profile Prodigy WPSE4200A
Spin and Agitate problem on GE Profile Prodigy WPSE4200A
This machine uses an electric water pump. I would check to motor. Remove the front panel and operate the machine to see if the motor is working. Check this by listening to the motor and watching the belt. If you hear the motor but the belt does'nt move then there may be a problem with the pulley or motor clutch assy.
As far as not draining or pumping water ? Check the wiring from the pump to the control panel. If these wires are alright then i suspect the pump.
Nov 15, 2007 | GE Profile Prodigy WPSE4200A
Washing machine leaking
pump seals worn or possible obstruction - remove pump and check for wear and rep[lace .
Oct 25, 2007 | GE Profile Prodigy WPSE4200A
Washing Machines Logo
82 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
