Question about Tomtom ONE GPS Receiver
Doesn't see satellites, more exactly sees some, but they never become blue
My laptop brand toshiba Satellite L635-10U should operate in 64 bit but it is operating in 32 bit? what shall i do to change it.
Just because it can, doesn't mean that it shipped with 64-bit operating system. Machines have been able to run 64 bit for some time, but only recently did that become the norm. It will require a reinstall of your operating system. You'll need to do a full backup of your information first. You'll also have to get the 64 bit operating system, as your machine probably does not have a license for it.
Nov 12, 2012 | Toshiba Computers & Internet
Laptop Satellite A305-S6853, restart each moment
Hello and Welcome to FixYa!
Please explain your query in a bit details, what exactly happens, did the restarts occurs, after a blue screen occurs... Or did any component makes a tripping like sound or what so ever that you can observe..
Concerned.
Jun 28, 2011 | Toshiba PSAG0U-02900L Satellite A305-S6853...
Cant find the wifi switch
Press the Fn + F8 on the keyboard.
The Fn key is located at the bottom right corner of the keyboard and F8 (you'll see a small antena icon with F8) is at the top center.
(See Fig1)
Fig 1 - Keyboard Layout
Regards,
Shrey
Jun 05, 2011 | Toshiba Satellite L500 Series Notebook
Toshiba satellite A100 slot 2 doesn´t work. A
Is memory matched (DDR2 667)
Have you put original mem in slot 2
Download / install CPU-Z with both modules in and run program to see if it shows.
If all above is correct may be damaged mobo.
This is for your laptop from vendors site.
Memory5
• Configured with 512MB DDR2 SDRAM (1 slot occupied and 1 available)
• 512MB(min)/2048MB (max), 2 memory slots using 256MB, 512MB or 1024MB PC4200 DDR2 533MHz SDRAM.
Mar 29, 2010 | Toshiba Satellite A100-S8111TD Notebook
The vcr gains 3 min. after time reset
It goes by satelite time no matter what you personally set it to.
Aug 01, 2009 | JVC HR-A592U S-VHS VCR
RCA TV/VCR combo T13060GY won't go below channel 5
I had a similar trouble with a couple of tv sets, one was a Granada and the other a Sony, but once connected to the satellite or digi-box via the scart socket it seemed to concentrate it's mind and override all the channels - so the tv stops being a tv set but becomes a monitor displaying whatever analogue video signal the digi-box sends to it.
The channels should arrive from the satellite receiver/decoder box and that remote control is all you need and the only thing you need to touch the monitor tv for will be the volume...
Scart sockets and plugs are apt to become dirty and unreliable and are responsible for many problems, including once a blue screen.
May 28, 2017 | RCA T13060GY Combo
Toshiba Satellite M35X-S163 wont start
send me ur email and I'll send u software to repair hard disk.
it seems your hd has bad sectors.try to install new copy first(xp)may give you more insight.
many reasons for no screen from worse case scenario proccessor fried to damaged hd.
Feb 03, 2009 | Toshiba Satellite M35X-S163 Notebook
Toshiba satellite web cam-where is it on my notebook?
I wish I could but I have the same frustrating problem with my Toshiba Satellite P300. I can see the darn thing there in front of me, I've evn had the blue light on it......once. Now absolutely nothing. I just get an Error message saying the driver doesn;t work so I should restart my computer or the camera. Aaaagh!
Oct 31, 2008 | Toshiba Satellite A205-S4617 Notebook
I cant get past the blue screen that appears when turn my television on
Make sure your cable or satellite box is turned ON before you try this:
If you have a cable box or satellite box plugged to this television with a regular cable wire, press 0-3 on your Philips remote (unless you have a dual tuner system - in which case, you will have to press Ch + on the Philips remote until you find the right channel).
If you have any other connection, press the AV+ or SOURCE button on the Philips until you see your cable or satellite box.
This is the best I can tell you without knowing your exact model # of TV.
Jun 20, 2008 | Philips Televison & Video
Toshiba Satellite 2450
It sounds like the hinge itself is broken. I have a relative with exactly the same problem, her laptop screen became floppy and didnt stay in the upright position. The hinges for the screen are complicated in that they appear to come as a top/bottom part already joined together, and need to be replaced as such. The metal used for the hinges is really flimy and easily snaps. this sounds like what has happened to yours. The problem is that is appears to be not econimcally viable to repair, and your probably better off scrapping it or buying another with say;.. a cracked screen and doing a swap-over of parts to get one fully working one (thats what I did)
Feb 25, 2008 | Toshiba Satellite 2450-401 Notebook
Tomtom ONE GPS Receiver Logo
26 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
