Keyboard problem whenever i wish to type something like in word,address bar of internet explorer(anywhere something can be typed),some symbol starts apearing there and even if i press the backspace key it resurfaces.Earlier it used to be this (""""""""""")and now it is the 'equal to' sign.I couldn't type' equal to' sign now because that button is not working.Such behavior though doesn't happen continuously.When such thing happens and on right clicking on the desktop a particular sound also appears.
  • zratsewk Jan 21, 2009
    I've got the same problem, the "=" sign appears about once every second. It's not in every program I use, only in a few of them, and I think it's preventing my screensaver from turning on
Are you sure your key is not stuck down?
Posted on May 09, 2009
FACEBOOK UNBLOCK
whenever you are connected to the internet just open your internet explorer and type www.facebook.com from your address bar and then enter it will land you there.
Oct 10, 2012 | Acer Computers & Internet
Tip
How to disable autocomplete in internet explorer 8
Sometimes many of you might have frustrated with the auto complete future as it gives complete website address when you type some part of the website if it was visited already.Even if you try to delete browsing history it will remain in most of the cases.
Go to tool ->Internet Options
Go to Content tab and Click on settings tab under Auto complete
option
Uncheck address bar options and click on Delete Auto-complete
history
Click on Delete
Click OK and again Click OK.Now you try typing something in address bar!! congrats!! you done it!
on May 01, 2010 | Microsoft Internet Explorer 8
I want to reset my security wireless key
If you remember the user name and password for the router, you can log into the router by typing the address in the address bar in internet explorer. you can find the router address by going to a command prompt (press start and click run in windows xp or type cmd in the search bar on vista or windows 7) and typing ipconfig. This must be done on a computer thats either directly connected to the router or connected wirelessly. you will see a set of numbers telling your IP address, subnet mask and gateway. The gateway address is the address of the router. it will usually be something like 192.168.1.1. type this address into the address bar of internet explorer and log into the router. go to wireless settings and you will be able to reset your wireless password. Another option, if you forget your logon for the router, is to jus reset the router to factory default. use a small thing object such as a paperclip and press and hold the reset button on the back or bottom of the router while you unplug and plug the router back in. Once it's powered on, you can let go of the reset button. This will have reset the router back to factory default, with no wireless password. Good luck
Mar 10, 2011 | Linksys WRV200 Router
I m unable to access the internet using the routter , how can i reset the dlink -524 wirless?
There is a small-pinhole on the back of the router next to where you plug in the power adapter. In that pin-hole is the reset button. Stick something in there and hold for 30sec, this will reset your router back to it's default factory settings.
Now you need to setup your router again. On a computer that is attached to the router by an ethernet (LAN) cord, open up internet explorer and type in the default IP Address for your router into the address bar. In your case, the default IP Address is
192.168.0.1
If that does not bring up a login window, then you should go to Start > Run
and in the Run window, type CMD and hit enter (in Vista and Win 7 just select the Start Orb and type CMD into the search bar). In the command prompt window that opened up, type IPCONFIG /ALL and hit enter. You're looking for Default Gateway (that's your router). Write down that IP address and then type it into your address bar of Internet Explorer or your web browser.
Now that the login window for your router is open, you will login with the default login information which is "admin" for the UserName (there is no password) now hit the ok button.
Click on the Wireless button on the left-hand side of the screen. Type in your SSID (this is the name of the network, you can name it whatever you wish).
Leave Channel set to 6.
If you wish to use security (which you should) select your preferred method, for now we'll just use WEP.
Pick Enabled for it.
Select your level of encryption (64bit or 128bit)
select HEX or ASCII and create a key. If you create it in Key 1 Field, select that field, now hit apply at the bottom of your screen.
Now your router is reset and set back up. Now you need to conenct to your SSID on your wireless computers and input your WEP key and you will connectt.
Hope this helps!
Dec 15, 2010 | D-Link DI-524 4 Port Wireless-G Router -...
I can't get into ip address 192.168.1.1 I seem
Sometimes these IP address 192.168.1.1 when you type it in the address bar don't work in internet browser like mozilla firefox and ggogle chrome.
If you are using windows xp... use the "e explorer" (internet explorer) as your browser
On the address bar type 192.168.1.1
There you can access the configuration of your router.
May 19, 2010 | Computers & Internet
Explorer will not open, it either freezes and does not respond or it crashes.
Is this Internet Explorer or File Explorer? If its Internet Explorer then try this:
Goto Start > Run
in the Run box type 'explorer' without the quotes
in the address bar of explorer type in the website address you are trying to go to.
If that works then you need to uninstall and reinstall Internet Explorer or better yet uninstal IE and install FireFox.
Jan 31, 2010 | Dell Dimension 4400 PC Desktop
How to change router settings for BUffalo WCR-G54 wifi router? i can't access the URL: http://192.168.0.11.1 thanks!
This is actually wrong: http://192.168.0.11.1
If your router is connected to your computer via ethernet cable you will be able to get the configuration page of the router.
Windows XP
1. Click start
2. Click run
3. Type cmd in the box and press enter
4. On the black screen type ipconfig and press enter
5. Look for the default gateway
6. Copy that and use that to access the configuration page using the internet explorer
7. Open internet explorer, type http://the default gateway you copied in the address bar of the internet explorer
ex: http://192.168.1.0
Windows Vista
1. Click pearl button (start in xp)
2. Click on start search box (run in xp)
4. Right click the black icon up at the top
5. Click on run as administrator
6. Click on continue
7. On the black screen type ipconfig and press enter
8. Look for the default gateway
9. Copy that and use that to access the configuration page using the internet explorer
10. Open internet explorer, type http://the default gateway you copied in the address bar of the internet explorer
Jan 14, 2010 | Buffalo Technology WHR-G54S Wireless...
When my desk top come up I dont know what icon to click on to get on line
1. Goto Start >> Connect To >> Select Any Connection >> Double-Click to connect internet.
2. Goto Start >> Internet Explorer / Mozilla Firefox >> Type any website address in the Address Bar >> Press Enter.
3. Goto Start >> Programs >> Internet Explorer / Mozilla Firefox.
4. Click on Internet Explorer ('e' symbol) in the Quik Launch Bar (right-side of Start button).
5. Double-Click the Internet Explorer ('e' symbol) on the Desktop.
please rate this advice if it helps....tc! :)
Jan 12, 2010 | HP Pavilion Slimline S3123W Desktop PC -...
I can't search in my address bar anymore. I have Windows XP, Int
download either firefox or internet explorer 8 or back up your data and re install your o/s because i presume youve spent hours trawling for solutions and this is a guarentee if you need a o/s contact me and ill sort it for you!
Jun 27, 2009 | Microsoft Internet Explorer 7
Computers & Internet Logo
174 people viewed this question
David Payne
David Payne
