Question about Saeco Vienna De Luxe Espresso Machine
I can make coffee but end up with a large puddle of water under my Vienna machine after a couple of cups. How can this be fixed?
  • 1,089 Answers
Hi
I would suspect the boiler is leaking. If something was broken you wouldn't be able to make a coffee. You will probably have to replace the boiler. If you need on I have them.
Posted on Nov 15, 2010
Saeco Vienna machine...after brewing a couple of cups of coffee, water leaks from somewhere and comes out underneath the front grilled tray and onto the counter. Can I do the repair with the proper parts?
Depending on your ability to do some technical and minutious manual work, unmounting and remounting the machine is feasable.
Concerning the leaking, what I've seen most is a leak from the seal under the water tank. Any leaks coming form there would occur even though no coffee would be dispensed. (i.e: Idle mode)
If leak is ONLY occurring when brewing cofee, I would check the following:
1- Check if the water inlet on the back of the brew unit is filled with residue (the inlet looks like the end of a smoke pipe)
2-Open the machine, take out the interior, and verify the water tubes coming in and out of the boiler. They both should be sealed with 2 small o-rings. After time, o-ring tend to expand under heat and may start to leak.
Hope this helps
Feb 27, 2011 | Saeco Vienna De Luxe Espresso Machine
Leaking Water after each Brew
did you already checked on the rubber as well are parts that are loosely reattach, try dismantling it and reinstall all parts and make sure that they are installed tightly. heat produces moist that acumulates on it thats why..
May 14, 2008 | Saeco Vienna Digital Coffee Maker,...
My Saeco Vienna Superautomatica leaks
Check the little chamber under the white plastic valve behind the brew unit, that might be blocked with coffee.
Apr 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
I have Saeco Vienna digital coffee machine already for 7 years. It was working fine but now I have problems. Only small amount of water/coffee goes to the cup and rest (clear water) goes to the tray and...
Hi
You boiler is leaking. You need to replace the boiler. sorry. Your water hardness might be set to low if you have been descaling when it tells you to. Boilers usually last 7 to 10 years, but need to be replaced. If you need one let me know. I have some new and rebuilt boilers for that machine.
Mar 08, 2010 | Saeco Vienna Digital Coffee Maker,...
A puddle of water forms under the machine and
Hi
If its dirty water your drain in back is plugged. There is a pocket below the injector nozzle that the pressure is relieved in when the brewing is done. This pocket can get clogged with residue after a while and then overflows under the drip tray. The drain is in back just above the back of the drip tray. If you pour water in the pocket it should come out the drain. If it doesn't, clean out the pocket, and that should take care of it. If it does,t, I need more information.
Oct 30, 2009 | Saeco Vienna De Luxe Espresso Machine
Won't brew
water puddling underneath machine indicates a broken boiler.
Machine needs to be sent in to have the boiler replaced.
Do not continue to use the machine because the seal on the boiler which is broke can end up splashing the electronic board and rendering your machine a paper weight.
Jul 06, 2009 | Saeco Vienna SuperAutomatica Coffee...
Red warning light comes on and stops
put a cup under the water spigot and turn the knob to release the pressure
Dec 09, 2008 | Saeco Vienna De Luxe Espresso Machine
I have a Saeco Vienna Deluxe Model. We have been experiencing water leaking from the machine. It leaks under the tank and floods the counter or leaks into the spent coffee disposal bin. I removed and...
If it leaks under the water tank then you have to replace the gasket in the machine where the water tank inlet are.
If you have a leek inside the door, make sure the hole behind the brewing unit (in the chassis) are clean.
That you get a half cup of coffee one time and a full next time can be the electric board in the machine but can also be the flow meter.
Hope this can help you.
Best regards
/Mirran
Aug 25, 2008 | Saeco Vienna De Luxe Espresso Machine
Problem getting a Full Cup of Coffee
besides descaling you need to lube the brew group, especially the bit that accepts the group nozzle. You might have a leaking boiler too, 6 years is pretty good for a vienna.
Remove the brew group and look for the two red o-rings on teh brass bit, smear some lube on it, they might need replacing by now, but luckily they aren't too expensive and readily available albeit a bit tricky to install, a good light and some patience is very important.
Dec 14, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
254 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
