Question about Dometic Refrigerators
I have a Dometic refrig. in my 2004 Mobile Suites 5th wheel. Model #: NDR1062 Prod#:921-1461-13 Serial#: 409-03032 Problem: when the ice maker fills with water, excess water drips into the ice plastic receptacle. When the frozen cubes dump, they fall into the water and create a block of frozen ice. Are there any adjustments I can make or should I seek a repair service.? THANK YOU!
  • fstephens194 Nov 15, 2010
    Yes...the solution was good information...maay or may not fix my problem.
    President:
  • 1,796 Answers
Hi!!
Your problem could be a defective water dispenser valve. click on the following link for price and availability http://www.campingworld.com/shopping/item/dometic-new-dimensions-ndr1062-2-way-refrigerator-with-icemaker-double-door-10-cu-ft-/15999 .
I want to bring to your attention that there is a NHTSA 06E076000 Recall for your NDR 1062 in case you haven't been notified.
Defect Summary:CERTAIN DOMETIC TWO-DOOR REFRIGERATORS MANUFACTURED BETWEEN APRIL 1997 AND MAY 2003: SERIAL NOS. 713XXXXX THROUGH 752XXXXX; 801XXXXX THROUGH 852XXXXX; 901XXXXX THROUGH 952XXXXX; 001XXXXX THROUGH 052XXXXX; 101XXXXX THROUGH 152XXXXX; 201XXXXX THROUGH 252XXXXX; 301XXXXX THROUGH 319XXXXX, INSTALLED IN CERTAIN RECREATIONAL VEHICLES AS ORIGINAL EQUIPMENT AND SOLD AS AFTERMARKET EQUIPMENT. A FATIGUE CRACK MAY DEVELOP IN THE BOILER TUBE WHICH MAY RELEASE A SUFFICIENT AMOUNT OF PRESSURIZED COOLANT SOLUTION INTO AN AREA WHERE AN IGNITION SOURCE (GAS FLAME) IS PRESENT.
Consequence Summary:THE RELEASE OF COOLANT UNDER CERTAIN CONDITIONS COULD IGNITE AND RESULT IN A FIRE.
Corrective Summary:THE VEHICLE MANUFACTURERS WILL NOTIFY OWNERS OF RECREATIONAL VEHICLES THAT HAD THE REFRIGERATORS INSTALLED AS ORIGINAL EQUIPMENT AND DOMETIC WILL NOTIFY OWNERS OF THE AFTERMARKET REFRIGERATORS. DOMETIC WILL INSTALL A SECONDARY BURNER HOUSING FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN BETWEEN APRIL AND JUNE 2007. OWNERS MAY CONTACT DOMETIC AT 888-446-5157.
A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Nov 13, 2010
I need the fuseblock location on a 2004 Fleetwood Wilderness 5th wheel RV
There are two fuse block. One for high voltage block. It's next to input wiring block. Another on for DC voltage. It's in PCB board.(o.5ml)
Oct 27, 2011 | Dometic Rooftop RV Air Conditioner
My Dometic NDR1062 only runs on gas, its set for auto and has 110
There is a control board and a step down transformer that may be at fault.
These should be located in the lower rear of the unit.
Jul 11, 2010 | Dometic NDR 1062 Refrigerator
Cant find the fuse for the refrig. no power
Check connection for 12 volts, at back of fridge behind vent cover .(outside) Make sure 12 volts getting to the lugs where they join. If you have 12 volts to there, unplug fridge at receptacle usually on left side by back of fridge, just to be safe. Remove cover on circuit board and look for a blown (glass type fuse in there.)
May 03, 2010 | Dometic NDR 1292 Refrigerator
Dewinterized 5th wheel. Turned on Refrigerator.
good day,
hope this link below will solve your problem.
ref
May 09, 2009 | Dometic NDR 1292 Refrigerator
Inside light switch to be replaced only by getting the product
I can get you a light switch, I may even have one in stock. Have replaced several.rvtech@myway.com
Jan 26, 2009 | Dometic NDR 1062 Refrigerator
Refrigerators Logo
125 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
