Question about GE JE1390GV/WV Microwave Oven
When cook is pressed, interior light comes on but microwave does not start
  • wmwright Nov 13, 2010
    What I thought. Thanks
  • 2,382 Answers
O.k...
Posted on Nov 13, 2010
  • GE Master
  • 12,061 Answers
Microwaves have protection circuitry built in so that if they develop a "Fault' then they are shut down. So a MW that doesn't work is a common symptom.
Most usually the fault is to do with the magnetron, and or the High Voltage diode, and or the Power Supply. There is not all that much to a MW. However sometimes it can be a "Door" switch,or some "Protection" mechanism that's been invoked for whatever reason.
One must perform diagnostic steps to isolate the problem, and repair, which requires a service manual, tools and knowledge.
MW's are very dangerous device to service and in my opinion should always be serviced by a professional. They have a very large Capacitor, that stores enough Joules to kill anyone who touches it. It remains charged even when the power is removed and must be discharged each and every time after it has been powered on..
Always ask for a 'Quote' from the service agent before allowing any repair work to be undertaken.
4 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Kenmore Microwave, overhead household, Model 721-6264900
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Sep 16, 2008
MNfisherman
  • 11896 Answers
SOURCE: Microwave doesn't work
Sounds like you have a faulty control panel. I would use a meter and test the power from the control board to the magnetron and circuit board. Chances are the control panel is faulty
Posted on Jul 25, 2010
  • 6771 Answers
SOURCE: ge microwave je2160sf03
From the description one of the door switches is defective, or a more serious problem has developed.
Posted on Jun 03, 2012
Should the light come on when the door is opened
think so but then who knows what an engineer does or why
Mar 02, 2015 | Frigidaire FFCM1134LB Microwave Oven
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
R-402JW-T won't cook
From your description you have a bad door switch, there are usually a few of them located inside the microwave under the keypad control board that will need a digital meter to trouble shoot.
Jun 28, 2012 | Sharp Microwave Ovens
Ge microwave je2160sf03
Jun 02, 2012 | GE Spacemaker Over-the-Range Microwave
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
Jul 25, 2010 | GE Microwave Ovens
Light fails to operate with door open
If the light comes on during cooking then the bulb is ok.. in all probability the problem is the door switch that senses when teh door is open and activates the light... Hope that helps..
Aug 15, 2008 | Frigidaire GLMV168K Microwave Oven
GE JE1390GV/WV Microwave Oven Logo
37 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
