Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
Problem with Fisher & Paykel Active Smart E522B Bottom Freezer Refrigerator Keeps on making a beeping noise as if the door is open . The temp. control keeps on flashing. Now the fridge and freezer are no longer working. Please can you advise what to do. Thanking you. Percy
  • Anonymous Mar 31, 2014
    beeping
  • 1,998 Answers
So both the freezer and the frigerator are both warm then? If this is the case then you can try to remove the rear panel down where the compressor is leave machine off for about ten minutes then plug the machine back in there isa small box like unit or relay on the side of the compressor if your hearing it click on and off or if you disconnect the wires going to it and shake it lightly to hear if something is rattleing on the inside also if you have a multimeter and a pair of needle nose you can do this to test the relay
Remove the cover on the compressor relay box. The cover is usually held in place by retaining clips or tension clips. There are usually three components inside this box: the compressor relay, the compressor motor terminals and the overload protector. The compressor relay is the largest component and will either be wirewound or solid state. If the part is solid state, then you will have to have a professional test the part, as it requires specific equipment for testing. If you have a wirewound relay, pull it straight off of the compressor.
  • 5
    Use a pair of needlenose pliers to pull the connector off of the relay's terminal. Be sure to pull it off by grasping the connector and NOT the wire. Check both the wire connector and the compressor relay for any signs of corrosion.
  • 6
    After you dust the relay off, take a good look at it. You should see two plug-type terminals marked "S" and "M" and the slip-on terminal marked "L." Set your multitester to read ohms (usually the X1 or RX1 setting). Set the relay on a flat surface so that the "S" and "M" terminals are on the bottom.
  • 7
    Insert one probe of your tester into the "S" terminal and one in the "M" terminal. Your tester should have a reading of "zero" ohms. Keeping the probes inserted in the terminals, turn the relay over. You should hear an audible "click" and the tester's reading should change from "zero" to "infinity."
  • 8
    Turn the relay back over. Now, touch one probe to the "S" terminal and the other probe to the "L" terminal. The tester should read "zero" ohms. Turn it over again with the probes still on the terminals and the tester should read "infinity."
  • 9
    Turn the relay back over. Now, touch one probe to the "M" terminal and the other to the "L" terminal. The tester should read "zero" ohms. Turn the relay over with the probes still in place and the tester's reading should not change -- it will remain at zero ohms.
  • 10
    If your compressor relay passes this series of tests, then your relay is not the problem with your refrigerator. If it fails any one of these tests, then take it to an appliance parts shop and purchase a replacement. Replace everything back in its original position and be sure to remove the 20-ohm resistor from the capacitor before plugging the refrigerator back in.
  • note if you are unable to perform these tests please call a technician if you have any further questions please message me back as well as please remember to rate how this opinion has helped in your appliance repair all in all if your machine is warm its either the relay or the compressor Thanks again
  • Rick
  • Posted on Dec 02, 2010
    Opening fridge door and it beeps
    perhaps the reed switch (the magnetic switch to tell the PCB the door is open/closed).
    With F&P fridges, the amount of beeps will indicate the error code which relates to which component is faulty.
    Sep 14, 2016 | Fisher and Paykel Active Smart E522B...
    I have a fisher & paykel active smart fridge the fridge part freezes everything and wont stop beeping when door open
    Your fridge is telling you there is a fault, i'd say one of the 2 fans are not working. If everything is freezing in the bottom of the food compartment then the upper fan is faulty. You have to remove the shelves & remove the rear panel, the fan is in the shute at the bottom, remove, repair the broken wire or replace. Make sure unit is unpluged.
    Aug 10, 2014 | Fisher and Paykel Active Smart E522B...
    Refrigerator runs too cold even on lowest setting
    they had door closer problems make sure door it fully closed and not staying open just slitely and letting air out, hing closer is plactic pieces on ref door bottom and piece on hing itself.
    for parts go to (coolblueworld.com) THIS IS FISHER PAYKEL WED SIGHT.
    May 02, 2014 | Fisher and Paykel Active Smart E522B...
    Fault code F2
    Hi when the door is opened for to long alarm will beep to let you know
    Mar 08, 2014 | Fisher and Paykel Active Smart E522B...
    Fisher & paykel active smart fridge not keeping cold
    Do you see any ice buildup on the back wall of the freezer or behind it?
    Nov 28, 2012 | Fisher and Paykel Active Smart E522B...
    Hi My Fisher & Paykel Model: E522B starts beeping for no reason at random times. When I press the cooler/warmer settings it stops but will start beeping again randomly at a later time. Please...
    Hi - I believe the problem is the power module located on the rear of the machine. I have not done work on F&Paykels for a long time.
    Whats happenning is the controls is picking up an error with the input power supply, the modules perhaps got an intyermittent issue.
    Try this turn your fridge off & back on again - the E522B will start to beep indicating the lose of power which is exactly whats happening to the unit at the moment, to eliminate the beeps you reset with the temp button on the inside.
    Jun 14, 2011 | Fisher and Paykel Active Smart E522B...
    Fridge making knocking sound, only stops when fridge of freezer door is opened.
    Here is a tip that I wrote about refrigerators and the fan noise that they develop sometimes...
    Refrigerator Fan Noise
    heatman101
    Jan 23, 2011 | Fisher and Paykel Active Smart E522B...
    Hi friend has a fisher and paykel refridgeator and its sounding an alarm of one beep and then 3 or 4 long beep followed by a short beeps then then a single beep its a top freezer model and the refrigeator...
    kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
    Jun 11, 2010 | Fisher and Paykel Active Smart E522B...
    Fisher & Paykel active smart fridge keeps beeping for no apparent reason, while door closed
    press the select button ( the button that you choose the temperature on the fridge and freezer) and check that the fan on both fridge and freezer are working.
    Nov 04, 2009 | Fisher and Paykel Active Smart® E522BR...
    Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
    168 people viewed this question
    Top Fisher and Paykel Refrigerators Experts
    Brian Coughlan
    Charles T Nevin
    Charles T Nevin
    Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
