Question about Konica Minolta Magicolor 1600W Printer
Remote panel utility won't open on my desktop
My phones won't connect to my WBR-1310 router unless I go upstairs nearly every time and unplug/reset it. My laptop always seemed to connect with no problem. Now I have a wireless card in my des
HP PCs - Troubleshooting remote system and Internet (Windows Vista)
This report relates to HP PCs utilizing a remote system (a switch) with Windows Vista.
Wi-Fi organizing is a helpful approach to get to the Internet. In any case, a considerable measure of things that can turn out badly when utilizing a remote association and it can baffle when the association is moderate, irregularly drops, or can't interface. The means in this archive give devices that have been discovered useful in taking care of numerous issues that can happen with a remote system and Internet associations.
Stage 1: Using programmed investigating
To utilize the programmed troubleshooter, take after these means:
On the off chance that your PC has a remote key or catch on or close to the console and the remote movement light is off or golden in shading, at that point press the key or catch to empower your remote connector. This key may be the F10 key, F12 key or marked with an image of a plane.
In the event that remote movement goes ahead or the action light turns blue, you have empowered remote on your framework. Take a stab at interfacing with the Internet once more. On the off chance that issues hold on, keep utilizing these means.
In the event that your PC does not have a remote key or the remote movement lights stays off or orange, at that point keep utilizing these means.
Snap Start, sort investigating into the Search field.
Select investigating from the query items.
Snap Network and Internet.
Snap Internet Connections.
SparkNotes sunnywalker Profile
Oct 25, 2017 | D-Link 802.11g Wireless Router WBR-1310...
Tip
How to Connect a Windows 7 Computer to a Windows XP
Even though Windows XP and 7 are different versions of Windows, you can still connect a computer running Windows 7 to an XP computer using Remote Desktop Connection. Remote Desktop Connection is a utility in Windows that allows you to log in to a remote computer directly from your computer's desktop. However, before you can use the utility on your Windows 7 computer, you must enable it on the Windows XP computer. To connect to the Windows XP computer, you also need to know the XP computer's name.
Instructions
Enable Remote Desktop on the Windows XP Computer
  1. Click "Start" on the Windows XP computer, and then right-click "My Computer."
  2. Click "Properties" from the pop-up menu.
  3. Click the "Remote" tab, and then click the "Allow Users to Connect Remotely to This Computer" check box.
  4. Click "OK" to confirm the change when prompted on the pop-up window. Click "OK" on the open windows to close them.
Connect to the Windows XP Computer
  1. Click "Start" on the Windows 7 computer, and then type "Remote Desktop Connection" in the search box. Press "Enter."
  2. Click "Remote Desktop Connection" from the results list.
  3. Type the name of the XP computer in the "Computer" box, and then click "Connect" to connect to the XP computer.
References
  • ( Microsoft Support ) How to Use the Remote Desktop Feature of Windows XP Professional
  • !!!!CLICK HERE!!!!!
  • ( Microsoft Windows ) Connect to Another Computer Using Remote Desktop Connection
  • ( Microsoft Windows ) Remote Desktop Connection: Frequently Asked Questions
*please leave a rating if this information is helpful and beneficial to you.
Regards
MultilinkEnt.
on Jun 05, 2011 | Computers & Internet
Reinstalled Windows XP on an old computer (DELL Dimension 2400) and the monitor won't display above basic resolution. Downloaded and reinstalled the monitor driver and still no good. Opened up START
According to the Dell Support web site the Dell Dimension 2400 has a built in Intel 3D extreme graphics adapter, assuming you are using this and not a PCI graphics card.
Go to the Intel Download Centre and run their Intel Driver Update Utility which will automatically scan your system for updated drivers for any installed or integrated Intel devices.
If the Intel Utility identifies an updated driver for your graphics adapter then download and install that which should enable you to configure a higher resolution for your display.
Dec 24, 2011 | Computers & Internet
1999 aurora front door won't open from outside with either remote or key won't open from inside with handle
If you can't open the door you can pull the corresponding seat to gain access and remove the inner door panel
Oct 29, 2011 | 1999 Oldsmobile Aurora
Remote panel for konica magicolor 1600 w won't open in windows 7- 64 bits
I had the same issue win 7 x64
What I did:
I removed the Remote Panel form the desktop, and taskbar and made sure it wasn't running in task manager.
I then went to the Minolta support site http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productname=1600w and downlaoded the latest version of Remote Panel V0.28 with a 12/30/09 http://onyxftp.mykonicaminolta.com/DownloadFile/Download.ashx?fileid=19385&productid=1164 it is a zip file. Extract all the files , and then right click Setup.exe , run as administrator. (you could try this w/o running setup as administrator). You will have the yellow K on the desktop for Remote_Panel.exe, double left click that (or right click - open). That will start the remote panel and place a yellow K in the lower right (task bar). It does not open the panel, You go to the task bar , and dbl left click to open the panel (or right click -> Open panel).
Before I did the above clicking the taskbar K did nothing. Open Panel did nothing. I now have access to the panel and now I have to learn what some of the settings are :-)
Feb 04, 2011 | Konica Minolta Magicolor 1600W Printer
Dell dimension 3000 series won,t install drivers and utilities cd after fresh install of windows xp sp2
Hello
Run the windows update again to win sp3.
Sp3 has most of the drivers in the dowload.IF not you should be able to install utilities after you get win xp sp3
Apr 12, 2010 | Dell Dimension 3000 PC Desktop
Where is the remote desktop menu?
in control panel. why are you still using xp?? get 7 its alot better then any of microsofts os's!!!! hope helps :D
Feb 13, 2010 | Microsoft Windows XP Professional Remote...
Vista Remote logoff problem
the computer most likely goes into screensaver and it is set to logout / lock the computer everytime the screensaver is opened.
right click on your desktop select personalize, look in the screensaver settings. Take the Check out from the box that says, On resume display login screen.
now the computer wont sign you out every time the screensaver comes on.
Jun 16, 2009 | Microsoft Remote Desktop (V3H011652)
Can't connect to Desktop PC with Dameware using Netgear Router
Hi brianaugusti,
You need to open a port in the new router to allow remote connection. The port used by dameware is 6129, and the windows remote port is 3389
Please provide the model of your router so I can assist you with the next steps and how to open the ports.
Jan 09, 2009 | DameWare NT Utilities
Remote Desktop
hi,
Right click on my Computer then go to properties and left click on it.
Click on remote tab and then check mark the two check boxes for remote assistance and remote desktop.....If it solves the problem then thats fine...else..
Start>control panel>administration tools>services.
list of services will be open.
Look for all the entries with remote access.
Start these services.....thats all
May 23, 2008 | Computers & Internet
Konica Minolta Magicolor 1600W Printer Logo
675 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
