Question about Garmin StreetPilot C330 GPS Receiver
I bought an disk to up grade it. and now all it does is: Say put in disk, it killed the GPS can't get anything on it.
  • 1 more comment
  • sherry8883 Nov 17, 2010
    tried what Silverdragon wrote did not work.GPS keeps saying system software missing. We never had any system software with it. It said it was pre loaded. The only software we have is the upgrade that we ordered that killed the GPS
  • sherry8883 Nov 22, 2010
    We have had D.Sandles and Silverdragon's help but both didn't help.I bought a disk to upgrade and now all it says is System Software Missing. Our GPS won't do anything. This GPS is c330. It worked great until the GPS told us to upgrade. This was pre loaded so when we bought it new all we did was plug it in and it worked.
  • sherry8883 Nov 29, 2010
    It says system software missing and does nothing else
    President:
  • 1,851 Answers
Hi
many 330's were sold refurbished. I had one - worked perfect then died - this is how I fixed mine - and it works on many - - get a wall plug charger that matches your model - then plug it in for a day. Mine eventually came back. You will need to go to GARMIN web site - download the garmin software -plug the unit into the PC ----- open the upgraded maps and then load it from the pc into the 330..
This is the way it works.
Gary
Posted on Nov 26, 2010
  • Gary Rice
    Gary Rice Nov 29, 2010
    Have you tried to reset the unit? There are other things to do. Try plugging it in and leaving it plugged in for 4 hours or so even though it isn't working. Set it up like it works and see if it will 'come on line' on it's own. The only other thing I can think of is to send the unit to GARMIN - you can also call GARMIN FREE> the disk must be put on the pc and then transferred to the unit via the mini USB cable. You don't say if you're using he USB cable or not?
    Best of it
    Gary @ Fix Ya
  • 643 Answers
  • Remove the faceplate of your Garmin StreetPilot C330 by putting your thumbnail into the space between the logo and the faceplate. The device should be turned off. Lift up to remove the faceplate.
  • 2 Locate the reset button for your Garmin StreetPilot C330. It's located on the right side of the device next to the screen. It's higher up on the device than the power button.
  • 3 Press and hold the reset button that is uncovered by removing the faceplate of your Garmin StreetPilot C330.
  • 4 Snap the faceplate back on and press the power button to turn on your Garmin StreetPilot C330. You can now operate it normally.
  • after the reset you should be able to update the device via usb from the website.
    Posted on Nov 17, 2010
    • 12,061 Answers
    Try resetting the unit via the reset button, press this button for a couple of seconds and the unit should Boot up, if it doesn't then don't panic, you can hook it up to the USB and hopefully reflash the program back onto the device.
    With the unit off, place your thumbnail in the groove located under the Garmin logo on the face plate, gently pull off the face place. Press the reset button and turn the unit back on.
    You need to install the Garmin software, http://www8.garmin.com/support/collection.jsp?product=010-00401-10
    http://www8.garmin.com/products/webupdater/howtoinstall.jsp
    after this you connect up the device to the usb port and download and install the latest firmware, if successful, then you probably won't/don't need to use the DVD anyway.
    http://www.tech-recipes.com/rx/1385/garmin-streetpilot-c320c330-easter-eggs-hacks-and-tips/
    Please go to this website it has great info and things for you.
    Posted on Nov 13, 2010
    Garmin 225. I can't get a GPS signal and have gone through all the correct procedures. Only used it once since I bought it. Now out of warranty and Garmin want £90 to send it away and get it fixed.
    If it is not a poor connection on the aerial then return is the best option as a new/refurbished grade A replacement will be sent to you.
    May 15, 2017 | Garmin GPS
    Put code in but wont conect
    it bepends on the software you have in the parrot, most probably you will need to up-grade the software to suit your phone
    Oct 27, 2012 | Parrot CAR PAICK3300 GPS Receiver
    I purchased a Garmin 1300 abought 45 days ago.put i can't up graded as i did not get a cable with it to up graded on my computer
    You should have got a "mini USB cable" with it for connecting to the computer. If you bought it in a shop, rather than on line, you might be able to go back to the shop and get one.
    Other wise you may have one for some other item as the same cable is used for connecting other items to your computer e.g. external hard drives, some cameras, some camcorders etc. If all else fails you can buy the cable at any computer shop.
    Jun 11, 2011 | Garmin nuvi 1300 Car GPS Receiver
    Wanting to upgrade maps on LG Model # LN730. how, where, $$ ?
    if u garmin gps user u can get free map every update
    Jul 19, 2009 | LG LN735 GPS
    Disk is asking to be formatted - already been in use
    this could be a help to you,first off most,cds, and memory disk,get scratched or worn out,that causes errors or corrupt file readings. so thats why it asked you to format,formating helps clean the drive up,like a tune up on and old car.and if you dont and try to put high grade gas in before the tune up your still going to have the same problem,so in saying you have to put the old one back in,format it. and then put the new one in after you completed formating the old one.good luck,hope that helped you.
    Mar 22, 2009 | Kodak EasyShare C330 Digital Camera
    1 iQue 3600 no Installation Disks or anything else.
    You can download for free the installation disk software from www.garmin.com. You can also download a base map, but may have to buy maps from Garmin for more detailed maps/charts. You may need the serial number of the unit to unlock the maps, this is on a paper sticker under the gps antenna.
    Mar 06, 2009 | Garmin iQue 3600 GPS Receiver
    Upgrade maps
    You can get the updated maps for 2009 from this website, but you will have to pay for them: http://www.gpsnow.com/Garmin_StreetPilot_c330_Maps.htm
    Feb 09, 2009 | Garmin StreetPilot C330 GPS Receiver
    Kenwood kvt-815 dvd
    hi bought a kvt-815 dvd player via gumtree was told needed a ribbon,,did have screen in pic but wont do anything at all no power all cables tested working can any one help...
    Oct 26, 2007 | Car Audio & Video
    Magellan Maestro 3100
    this one is for suziebeech,make sure your cd drive is a (dvd rom only) drive meaning that it will read dvd only,i had a problem trying to update my unit i put my dvd into the dvdr /rw-rdl- +, and it took a while,then i put it on the second computer that has a dvd rom only drive it read it and popped up fast was able to update the unit so try that.
    Oct 08, 2007 | Magellan Maestro 4040 GPS Receiver
    Garmin StreetPilot C330 GPS Receiver Logo
    46 people viewed this question
    Top Garmin GPS Experts
    SHARCNET-USA
    SHARCNET-USA
    Steve
    Are you a Garmin GPS Expert? Answer questions, earn points and help others
