Question about Emerson EWF2704 TV
TV turns on and a white line is horizontal, and i can hear sound.
    Top Expert:
  • Emerson Master
  • 74,106 Answers
Hello
There is total vertical swee failure occured on your TV. All CRT based telivisions have both vertical and horizontal sweep to display picture on the screen. In your TV, vertcal sweep has gone out; and horizontal sweep is there, that is why you see a bright horizontal line on the screen.
There are mainly two reasons for this fault. One is bad soldering at the legs of the vertical output Ic, and the other is Vertical Output Ic failure.
You just open your tv, and locate the vertical output Ic. It can be located by following the wires that goes from the deflection Yoke of the picture tube to main board. This will contain four wires, out of which two of them will be thick, usuall red and blue, and the other two will be thin relative to the above said pair, may be green and black, or green and yellow. You just follow the two thin wires, as they are carrying vertical sweep signal to the deflection yoke.
Normally these four wires are socket pin type arrangements, which has pluged into the printed circuit board, and can be detached by pulling its plug from the board. Just make the board upside down and carefully look for any loose contacted solder joints of any other to the solderings of this plug. If it is found ok, then follow the print to where it goes to. it will lead you to vertical output Ic said above. It will be screwed onto a metal plate, to radiate heat out of it when it works. Just look for any loose solderings there on the legs of the Ic. It is quite normal that these solderings will get loose with time, as these ponts are heated and cooled several times.
Resolder all these legs with applying a little more solder, without any short between these legs. Switch on the TV all connections have given. Normally this will retify your problem. If not, IC stated above is faulty. Resolder it out from the board and go for a same type and number. Replacing it will rectify your complaint. OK.
Posted on Nov 13, 2010
Hi.. Mine is a sansui tv and I bought it 3 years back. Now it is showing a horizontal line on the screen. Sound is fine but I can't see the picture, I just see one white horizontal line on tv...
The problem is vertical failure. Vertical output section to your TV ahs the fault. You ahve to check the vertcial output circuit for any component failure or loose solderings.
May 11, 2012 | SansuiS3275 TV
Tv has power, can hear sound, but picture is black. when i shut it off a horizontal white line appears for a short second. can this be easily fixed?
Well, If you are technically sound, you can fixed it, but I will like you to check the line Or Fly-back Transformer and the horizontal and vertical side of the circuit very well.
Jun 15, 2011 | JVC AV-32720 32" TV
I have the Philips 27PT6441/37 TV that turns on to the point of hearing sound then instantly turns off and flashes the led 3,2,1.
Plus horizontal lines on top of the screen
Jul 08, 2009 | Philips 27PT6441 27" TV
Gray screen with horizontal lines accross it
sounds like you may have a bad ic it probley is a surface mount on the bottom of the board it could couse this problem would need to take to a shop to repair. The ic probley is numbered ic101 on board.
Mar 01, 2009 | Sanyo DS32224 TV
Proscan PS27123 TV Problem
just to be sure, is it vertical or horizontal? Anyway, if it is vertical, it could point out to the vertical Ic section or some loose contacts along the lines. If it is horizontal, it could be a filter capacitor along the horizontal Circuitry. Mark the high voltage capacitors along the high voltage sections.
regards,
chris
Jul 23, 2008 | Proscan PS27123 TV
No Picture but have sound
OK I got my first TV, first to repair myself that is, and I have no training at all but am kind of a tech dork wannabe. So I checked and I have sound but no signal through the TV tuner, so I hooked up my Zenith VCR to aux 1 and sound with signal appeared, the VCR tuner still works :) so I am leaning toward the TV tuner. It is visibly damaged, and I'm hoping it is as simple as a broken connection. I also noticed a vertical flash and pattern of horizontal lines when it is turned off (white). sooooo I push on.... help!!!!!!!!!!!!! :>}
May 02, 2008 | Televison & Video
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
Horizontal white lines
if you cant adjust the A1s then it sounds like the F.B.T. is up the swanny (faulty).
Jun 01, 2007 | Jensen Q2049J 20" TV
Horizontal grey lines on TV
Sound like you have to turn down the G2 (screen)controls. They are turned up too high.
Jan 01, 2007 | Panasonic PT-56WXF95 56" Rear Projection...
Emerson EWF2704 TV Logo
231 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
