Question about Watches
I have recieved an ABACUS AU 4008 digital watch,In Chicago last month it appeared to be keeping good time, but since we moved next to the Mexican border, and at the same time DST changed, I have been playing with the buttons repeated ly ,to no avail. I want to set the time. Unfortunatly I do not posess a MANUAL.any help would be welcome.
    President:
  • 1,961 Answers
Hi!
The famous Atomic watch ....Abacus AU4008 digital watch is made by FOSSIL.
Here is the instruction manual for this watch
Abacus Atomic AU4008.pdf
Remember You must have an adobe acrobat reader installed in your system to view this file.
If this is the manual you've been looking for...please do accept this solution and give this answer a four thumbs up rating.
Thank you for using Fixya.
Alp
Posted on Nov 16, 2010
  • 3,083 Answers
Try these instructions for setting the watch:
http://support.radioshack.com/support_tutorials/computer/faq-6305315.htm
As soon as the watch catches the WWV Atomic signal, it will set itself to that. If, for some strange reason, you're in a gray area time zone, it may reset to a different time. I think the Atomic time overrides manual settings with these watches, though I've never owned one.
Good luck, and hope this helps.
My Abacus Fossil AU4005 110504 wont charge any more,wen i put it on the charger nothing happen,it does not light up any more,do i need a new battery and where do i get it?
I had the same problem but easy fix.
first make sure you put the watch on charger for a few hours first-- the problem is not the battery not taking charge it is the watch that is not turning on probably.
After a few hours on the charger, remove the four screws on the back cover-- WARNING- remove cover carefully. there are two thin copper wires attached to the cover to the charing coil. set the cover aside. remove battery back (unplug tiny connector). WAIT a10 minutes-- this is to discharge any remaining charge that may be held by capacitor in the watch. plug the battery back in. Voila! working now. This is my way of resetting the watch to factory setting. Isn't it almost always work when you remove power to electronic device to reset it?
Nov 09, 2012 | Fossil Abacus AU4002 wristwatch
I lost the Wrist Net power supply but I do have the charger base. What voltage is the power supply?
Wow, I haven't used my SPOT watch in years--but I found it!
The charging base for my Abacus AU4000 uses an adapter rated at 12 volts, .11 amps, center positive. I believe that all the charging cradles for the Abacus Wrist Net series watches were the same--the different model numbers referred to different case and band options.
Good luck, and don't hesitate to follow up if you have any additional questions.
May 26, 2011 | Fossil Abacus AU4002 wristwatch
How do you set this watch....4 buttons
SETTING THE TIME AND DATE ON AN OLD 4 BUTTON DIGITAL WATCH
[L1] [R1]
[L2] [R2]
SETTING THE TIME.
Press [L2] to move through the modes. When the time display flashes, you are in the correct mode to set the time. The hours first, then the minutes and seconds.
Press [R1] to advance the numbers, [R2] to go to the next.
Press [L2] to save your settings. [L1] is not used; it's the light.
SETTING THE DATE AND DAY. After setting the time (seconds flashing) push [R2] to move though time, backwards, to date, [R1] to set day, [R2] to move to month [R1] to set the month. Push [R2] to get to the day of the week, then [R1] to change. [L2] to end.
Jul 26, 2010 | Fossil JR9455 Watch
I purchased a abacus wrist net on line with msn direct , and my battery isn't charging with my charger.
Your issue may not be that the watch is not recharging, it may just need to be reset. This will work on most, but not all of the abacus watches. You need to press all but the top left button at the same time. Do this 20x if successful, your watch will magically power up. I have this issue from time to time, usually right after a static shock. Hope this helps!
Dec 15, 2009 | Fossil Abacus AU4002 wristwatch
I HAVE A CASIO 3054 WAVE CEPTOR WV-58A WATCH. It
I tried putting your module number in (3054) and was able to download the instructions.
Try the following link http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3054.pdf . This was successful in finding the manual you require.
Good luck and a happy new year.
Nov 05, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
I cant find a battery for my Fossill Abacus Wristnet AU 4005
Hai,
It has a Powerful rechargeable Li-ion battery so there is no need to purchase extra battery kits!
Aug 25, 2009 | Fossil AU4003 Wristwatch
Trying to set time on my columbia CL5046
When The Watch Is In Normal Time Mode, Press The "SET" Button. Then Keep Pressing The "ST/SP" Button Until The Time Is What You Want. Then Press The "MODE" Button To Move On To The Next Field. When You Are Completely Done, Just Press The "SET" Button Again. Hope This Helped
Jun 16, 2009 | Columbia All Sport Digital watch
Changing the hand time only w/o changing the digital time
For Casio Waveceptor:
--- A
( ) Button Reference
--- B
Set in correct order:
1) Hand Home Position
2) Digital Time Set
1) Hand Home Position:
Press and hold A and B for 5 seconds, Press A to move Second Hand to 12: position: (if not there). Press B to enter Hour/Min set mode. Press A to move both hands to 12: position. Hold A to move hands fast, Press A again to stop hands. All 3 hands are now at 12' oclock.
Press B to exit Hand Home Position mode and enter Timekeeping Mode.
2) Digital Time Set: (hands will self set when done)
Press and hold B for 5 seconds to enter setting mode.
Press A to advance current item or scroll through choices. Press B to set item and advance to next item.
<Order of Items to Set>
GMT Differential -> Daylight Savings auto/on/off -> Seconds -> Hour -> Minutes -> Year -> Month -> Day -> Day of week language -> Auto receive -> (back to Timekeeping Mode).
<Setting each Item>
GMT Differential: Press A untill your time zone is reached (E=eastern, C=central, M=mountain, P=pacific). Press B to set (advances to next item).
Daylight Savings: Press A untill desired DST mode is reached: ("At" auto, "On" after spring change, "Of" after fall change) Press B to set (advances to next item).
Repeat to set: Seconds (resets to :00), Hour, Minutes, Year, Month, Day, Day of Week Language, and Auto Receive (on/off).
For each item, Press A to advance, and B to set.
Pressing B to set last item exits Setting Mode and enters Timekeeping Mode. Hands advance to current time.
Good luck,
Techjoel
May 10, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Accutron Tahoe Chronograph
i have the same watch it needs a cleaning by a watch maker not jewler hope this helps
Nov 13, 2006 | Bulova Men's Accutron Tahoe Watch
Watches Logo
611 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
