Question about Whirlpool GHW9400 Front Load Washer
Washer fills with watrt runs for one minute and shuts off. It feads a code of FH. Please help.
  • 4,323 Answers
Hi
Error code FH appears when No water is detected entering machine or Pressure switch trip is not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Press PAUSE/CANCEL twice to clear the display. If there is no water entering the unit then make sure that the inlet valves are working fine. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hose, it may be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
Posted on Nov 12, 2010
Fh showing on my kenmore washer
First try turning off the machine for 30 minutes. Then check your inlet valve. Shut off valve, switch off machine & see if the water comes full flow. Check the filters on the machine inlet entry, they could be blocked, clean out.
The FH indicates a fill failure and this is usually caused by a bad water valve, flow meter or pressure switch.
One key to determining the cause of the FH error is how fast the error comes up in a cycle. If the error appears within 1 or 2 minutes then the most likely cause will be the water valve or flow meter.
If the error doesn't appear for several minutes then the pressure switch can be the source of the problem.
Both water valves must be turned on and working. Even if a cold wash is selected at some point during the fill the hot water valve will be energized and if there is no water then the FH error will show up. Sometimes a consumer will turn the hot water valve off to save energy but you can't turn one valve off on this washer.
Inlet valves can be purchased thru the net and fitted by you easily.
Feb 27, 2013 | Kenmore Elite HE4 Electric Dryer
Timer display blinks fh on maytag epic front loader
Feb 25, 2013 | Maytag EPIC MFW9700S Front Load Washer
F and H keep coming up on screen
The information provided is general. For information specific to your washer please resubmit the question, including the model number.
The "F" is at the beginning of all error codes. This indicates the a Fault has taken place. The second number or letter indicates what the Fault is.
FH : Is displayed when no water has been detected entering the washer.
If the control has turned on the fill valve and after 8 minutes the flow meter has detected 10.5 gallons of water and not detected a pressure switch trip, the valve will be turned off and the failure code will flash in the display
Unplug the washer from its electrical source and wait for 30 seconds.
Replug the cord into the electrical source and try to start a normal cycle or a cancel drain cycle.
The machine should start the pump out mode and empty the water.
If, after 30 second, the machine has not detected water entering into the machine, the valves will be shut off and the failure code of FH will be displayed.
Check all hose connection and valves, both hot and cold, are turned on completely.
Verify that water is at the fill hose connections at the back of the washer.
The main control has sensed a component failure in the machine and will be needing a diagnostic visit for a possible repair or replacement.
Hope helps (remember to rating this free answer and leave a comment)
Sep 30, 2011 | Maytag EPIC MFW9700S Front Load Washer
What does code fh mean?
FH error indicates that either you have no water coming into the washer, or very little water. Since you can see it filling, the error indicates low flow. A flow meter in the unit detects if 10.5 gallons fills the tub within 8 minutes; yours must not be. This will turn off the inlet valves and the error code will be displayed. Check the follow link for additional details: support/error_code_HF
Hope this helps (remember to rate and comment this answer).
Jun 28, 2011 | Whirlpool AWM8103/1 Front Load Washer
HE3t has an FH error code checked the following and are OK. pressure switch, flow meter, and inlet valves water flows in without restriction. What else could it be? Craig
Thank you for contacting fixya.com.
FH error code means low water inflow. In this error washer is not filling when the fill valve opens.
To clear the error please follow the bellow instructions:-
Press the "Stop" button twice with your finger. This cancels the cycle and stops the washer. Unplug the power cord from the wall outlet.Turn the water shut off valves clockwise to stop the water flow to the washer through the supply hoses. Pull the washer away from the wall enough that you can access the hose connections at the back of the washer.
Set a bucket under the area of the hose connections. Unscrew the hose connections from the back of the washer. If necessary, use a pair of slip joint pliers to help start the connections turning until you can turn them by hand. Set the ends of the hoses inside the bucket.Inspect the screens on the inlet ports on the back of the washer where the hoses connect. Sediment and other debris can block these screens, causing fill problems. Clean the screen with an old toothbrush.
Thread the hoses back onto the washer. Look for kinks in the hoses. Kinks cut off water supply to the washer which causes the FH error code. Once you connect the hoses, turn the water supply valves counter-clockwise to supply water to the washer. Move the bucket away from the washer and push the washer back into its working position.Plug the power cord back into the outlet and start the wash cycle again. If the FH error code comes up again, call a service repairman. If the hoses have no kinks and the inlet screens are clean, there is a problem with either the pressure switch or the flow meter.
Please get back to us if you have further query else please accept the suggestion.
Jun 02, 2011 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
How do you fix a FH code ( water inlet problem) on a Kenmore Elite HE3t front load washer
One key to determining the cause of the FH error is how fast the error comes up in a cycle. If the error appears within a1 or 2 minutes then the most likely cause will be the water valve or flow meter.
If the error doesn't appear foe several minutes then the pressure switch can be the source of the problem.
Nov 28, 2010 | Kenmore Washing Machines
After 27 minutes into wash get an FH error
The FH code on the Whirlpool Duet washers indicates that the unit is not detecting water fill at the flowmeter. The flowmeter is sits right in front of the water inlet valve and is attached via a hose and is off to the left of the central control unit (ccu). If the washer seems to be filling alright, check out the wiring from the flowmeter to the control unit. Make sure all connections are clean and tight. These connections have been known to jiggle loose and cause this code. Hope this helped and best wishes.
Aug 02, 2009 | Washing Machines
WASHER RUNS FOR 1-2 MINUTES, THEN STOPS & STARTS FLASHING H/F
can u switch of hte michine at the wall and leave it for 20 mins and turn it on again
Jan 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer came up with fh error message. how do i clear this?
The following link explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
This is one of the more challenging error codes to diagnose, because there are so many potential causes. First, try unplugging the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches. If the error code reappears, then I would recommend starting with the easy items to eliminate first. Check your fill hoses and water source, followed by making sure you don't have a siphoning situation. Then, I would recommend checking the drain pump.
Read through the link carefully, and let me knwo if you have questions. If you require additional assistance, please let me knoww before you rate the solution. I hope this helps you.
Jan 19, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore elite he3 flashing FH
The following link explains the "FH" error:
This can be a rather tough one to figure out, even with the error code explanation. I would recommend unplugging the washer for AT LEAST 30 minutes first. This will reset the Central Control Unit (CCU). In many cases this is all that is required to correct momentary glitches with the unit. If the error code reappears, check your washer installation to rule out the easiest possiblities, first. This means checking to ensure you don't have a siphoning condition, checking your drain lines and checking to ensure your fill hoses aren't kinked or clogged. Read through the link thoroughly and let me know if you have questions. I hope this helps you.
Jan 09, 2009 | Kenmore 46462 Front Load Washer
Whirlpool GHW9400 Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
