Question about Refrigerators
The HS-102 wont go below 15 deg C , and cant work out the electronic control panel
3 Suggested Answers
  • 3197 Answers
SOURCE: I have a sears door opener that wont work when the
It is common for electronic components to become sensitive to temperature. If you have more than one remote and they both act the same you will need a new logic board.
Posted on Jan 15, 2010
dj_relly999
  • 4070 Answers
SOURCE: I can't get the the
Hi! You may want to replace the distributor coil and distributor cap. They may be worn thats why you can't get the timing right. Hope this helps and thank you for using FixYa!
Posted on Sep 13, 2010
GE PT916S R2SS Wall Oven gets moisture in the control panel and quits working Then we have to reset the circuit to get it to work again.
There is a good chance you will need to replace it - again and again and again. Electronics were never intended to be utilized in hot or damp/moist environments. But appliance manufacturers could not resist the urge to go modern and replace the perfectly good knobs we all grew up with with buttons and displays that tend to confuse more that help. It is for this reason that appliances today will never last the 10-15 years that the ones our parents bought lasted. The manufacturers know this as well and they're laughing all the way to the bank...
Aug 31, 2016 | GE Profile 30" Built-In Wall Oven PT916
Please help me with torque settings for chev utility 1.4 2012 thanks
if your engine code(suffix) is z14xep
head bolts-renew bolts 25nm 60 deg 60 deg 60 deg
main bearings-bolt sizeM6-10nm 60 deg 15 deg
M8-25nm 60 deg 15 deg
big ends-bolt size-M6-10nm 60 deg 15 deg
M6.5-13 nm 60 deg 15 deg
Mar 13, 2016 | Chevrolet Cars & Trucks
Fridge too warm
It is likely to be either the circulation fan in the freezer or the defrost element. The cold air is blown from the freezer into the fridge if the fan doesn't work then no cold in fridge( actually I think there are 2 fans in these, 1 horizontal 1 vertical) otherwise it could be a defrost problem, if the element doesn't work the rear fills up with ice and the air cant flow. Both are behind the rear panel of the freezer
Jul 08, 2013 | GE Energy Star PDS22SIS Stainless Steel...
I have a 2006 F150 FX4 and after sticking a voltometer into several plugs behind my center console, I no longer have any working gauges, and I cannot shift out of park unless I do the manual override. I...
Fuse # 102 to the ing switch feeds fuses 1, 15, 18, 21, and 27 for the instrument cluster.
The fuses for the shift interlock are 15, 16 and 102.
The common fuse to these 2 issues is fuse # 15, 5A. I would suspect this fuse to be blown.
Not too sure if you used your meter to check the fuse pins on both sides of the back of the fuse with the key in the run position, or if you tried the pull and stare method to check the fuses.
If you change Fuse #15, 5A it should cure the problems.
Jul 08, 2011 | 2006 Ford F-150
I am having trouble getting new fridge cool enough in fridge. Should it get below 40 f in fridge on mid setting of both freezer and fridge section
fresh food tempt should be 38 deg ( this is good ) and 40 is close . as it will be 5 deg up and down freezer thempt should be around 5 to 15 deg or ice mker will not work . make sure the coils ore clean and fans are working or these tempt can not be obtained . mm feed back pls
Jan 01, 2011 | KitchenAid Architect Series II KSRG25FVMS...
The ice maker was making noise, and not ejecting ice. I remved it and defrosted it with a hairdryer. I reinstalled it, but now it won't fill up with water
if you had to defrost it then the defrost system has failed and the coil is blocked with ice . this will cause the freezer to be warmer then 15 deg and the ice mker will not work untill its below 15 deg . so you may have the defrost heater failure of timer.
Apr 19, 2010 | Amana ARB2257C Bottom Freezer Refrigerator
I have a sears door opener that wont work when the temp goes below 40 deg
Jan 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
Creative HS-400 headset & Mic
I had the same problem... with my laptop, using vista. I plugged the mic dirrectly into my laptop and for some miracle, it works! try it out! ^-^
Sep 25, 2008 | Creative Labs HS-400 Headset
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
