Question about Linksys Wireless-G WRT54G Router
How do the cables connect? Which cable goes where?
  • Linksys Master
  • 7,733 Answers
Step 1:
Connect the broadband modem to the router's WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we'll connect the computer to port number 3.
NOTE: It is advisable to connect the computer to one of the Ethernet (1, 2, 3 or 4) ports when setting up the router for the first time. If you have successfully configured the router using a wireless computer, unplug the Ethernet cable which connects the computer to the router for you to have wireless Internet connection. For instructions on how to connect the wireless computer to go online using the Linksys router, click here.
SteHow do the cables connect? Which cable goes where? - 3678-005.png/b>Make sure the power adapter is plugged in to an available power outlet.
3678-005.png Step 4:
Check if the corresponding LEDs on the router are lit. For instructions, click here.
Related Articles:
Accessing the Router's Web-Based Setup Page
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Posted on Nov 12, 2010
  • Linksys Master
  • 4,338 Answers
Step by step:
http://techblissonline.com/how-to-set-up-linksys-router/+
http://www.ehow.com/how_2091718_set-up-linksys-wireless-router.html
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Where do i connect 5 wire data cable power cable
red and black are the + and -
The other wires can connect up to an external NMEA device. If you are not going to connect an external device then just tape them up to get them out of the way
Jun 20, 2014 | Lowrance Elite-5 HDI 83/200 455/800 Combo...
Replace throttle cable
There are two cables leading to the throttle. Both have two pieces.
Cable 1 goes from the throttle about 12" long and connects to an adjustment piece joining it to cable2 which goes to the throttle body.
Cable 3 also goes from the throttle and is about 12" long and connects to and adjustment piece joining it to cable 4 which goes to the spring on the throttle body.
To change any of them you must loosen the adjustment piece until the ends can be removed from it.
Then to change cables 1 and 3 you have to remove the throttle cover on the grip. you will be able to see how they are removed. Then reverse these steps to install the new cable.
To change cables 2 and 4 in no more difficult but more time consuming as you will have to route these longer cables from the adjuster to where they connect to the throttle body.
When cables have been install and all parts reassembled you can carefully adjust the tension on the cables until the throttle responds the way you like it.
Hope this helps
Sep 19, 2011 | Harley Davidson XLH Sportster 883 Hugger...
I am trying to hook the dvd player up to my old tv and am only getting sound, I am using the red, white and yellow cord.
I hope this will clarify things, you have 3 connections on each end.
DVD
  • Yellow Cable goes on Video Out (Yellow)
  • White Cable goes on Left Audio Out (White)
  • Red Cable goes on Right Audio Out (Red)
TV
  • Yellow Cable goes on Video IN (Yellow)
  • White Cable goes on Left Audio IN (White)
  • Red Cable goes on Right Audio IN (Red)
the coaxial audio connection does NOT need to be connected.
I hope this helps,
Magoo
Mar 10, 2011 | Toshiba SD4990 DVD Player
Im am trying to connect my cox cable box to my LG computer monitor and if i try and input the screen just goes black
You can't directly connect any cable connections to a computer monitor. You will either have to connect the cable box to a network router or to your computer tower via stantard Ethernet cables if this is for Internet usage.
If you are trying to connect this for viewing "Cable/TV" content, then you would have to have some kind of TV card installed and connect the coax/antenna cable to that connection.
Aug 09, 2010 | LG Computers & Internet
How to have connections in my other pc if im using router , but if i direct the cable to the modem theres a connection?
One Ethernet cable goes from the WAN port on the router to the cable-modem (or DSL-modem).
Another Ethernet cable goes from one of the LAN ports on the rouer to your first PC.
Another Ethernet cable goes from one of the LAN ports on the rouer to your second PC.
Jul 27, 2010 | D-Link Computers & Internet
I removed my nutone door chime transformer a while ago to work on an electrical problem. Now i want to reinstall it but don't have the instructions. The transformer reads nutone class 2 LR2982 10va 16v
I couldn't find a manual for the LR2982, so I'll give a general description of how to wire a door chime. Most chimes have 3 contacts. F (Front), R (Rear) and C (Common). Some have just two contacts. If your chime has more than 3 contacts do _not_ follow these instructions.
Inside the junction box on the wall where the chime will be mounted, you should have at least 2 cables (usually brown) each, with at least two wires (usually red and white) each. One of those cables goes to the transformer and the other cable goes to the door button.
The beauty of it is that since it's only 24 volts or less and _polarity_ doesn't matter, you don't need to know which cable goes where for a _single_ door button scenario.
For _single_ door button wiring, pick a wire (say the red) from one cable (doesn't matter which cable) and connect it to the "C" contact on the chime. Pick a wire (say the red) from the _other_ cable and connect it to the "F" contact on the chime (if the chime has 3 contacts). If the chime only has 2 contacts connect it to the only contact that is left.
Then all one needs to do is twist the 2 remaining wires together (both white) and cap them off with a wire nut.
If your junction box for the chime has 3 cables in it, the extra cable goes to a rear door button. In that case you _do_ need to know which cable goes to the _transformer_. You can pick up a cheapo voltmeter for about $10 just about anywhere. The cable that reads anywhere from 16 to 24 volts AC between the red and the white wires is the cable that goes to the transformer.
Make sure one of those wires from the transformer goes to the "C" contact (pick one, say the red). Now you know the 2 remaining cables go to the front and rear door buttons. For now, just connect a red from one of the remaining cables to the "F" and one red from the other remaining cable to the "R". Then just twist the 3 remaining white wires (including the white wire from the transformer) together and cap them with a wire nut.
If the rear chime sounds when the front door button is pushed, just swap the wires on "F" with the "R"contacts..
May 13, 2010 | Broan-NuTone Door Chime Kit by NuTone
I have a RCA Thomson DHG 535-2 without the disk for the installation and the ethernet wont help everything is hooked up etherent/cable to tv power yes... and that's about ti all im really missing is the...
Thomson Cable modem has an ethernet connection...
The ethernet connection goes to your computer via a standard Cat5e patch cable. There is no USB that I know of...
Cablevision wire goes to the modem. It should be the first device on the cablevision wire. If you need a splitter, it needs to be a GOOD one, connected DIRECTLY to the incoming Cablevision wire as it enters the house. Use good copper wire.
Order of events:
Connect the cablevision wire to the Modem.
Connect the Ethernet cable to the computer and the modem.
Power on the cable modem.
Right click the network Icon near the clock and click 'repair' (Or reboot the computer)
Apply for and get an account for cable Internet from your Cable company.
After a few days, cable Internet should work.
Apr 16, 2010 | RCA Thomson Digital Cable Modem (DCM305R)
I change my battery post now I don't know where they go on the - or + side can you help me out
Hello. Yes. the black wire is the ground wire. It goes from the frame to the negative post of the battery. The red wire is the hot wire and it goes to the positive post.
Nov 24, 2009 | 1994 Buick LeSabre
I just purchased a Sherwood RD 6513 reciever, I'm trying to connect a hd cable box (motorola dch 3200), dvd player (sony dvp ns710h) and a rca hd tv (l32hd41). I connected hdmi cords from both components...
Hi! I will be more than glad to assist you. I f you are going to hook up your cable box - motorola to the sherwood receiver, connect an hdmi cable to the back of the motorola cable box, there is only 1 hdmi output there, then connect the other end to the sherwood receiver on the hdmi input, then connect another hdmi cable to the hdmi output and the other end goes to your rca hd tv.
for the sony dvp, you have only one hdmi out, connect an hdmi cable to the back of the sony dvp if u have another spare. connect it to the hdmi input of the sherwood receiver. there is only 1 hdmi output at the sherwood, so u need to use a component cable to be connected at the back of the sherwood receiver component output then the other end goes to the component input of the hd tv.
if you dont have anymore hdmi cable to hook up your sony dvp, u can use component cable, the connection will goes like this, connect a component cable on the output of the sony dvp and the other end goes to the sherwood component input then connect another component cable to the component output of the sherwood and the other end goes to the rca hd tv on the component input.
I hope this will solve your concern, if you have any question, u can get in touch..
Aug 21, 2009 | Televison & Video
When you go to turnover the car the battery cables heat to the point they smoke when we turned the car over the positive cable clamp melted tried connecting the solinoid differently which almost started...
Your red cable from the solenoid( the large one) goes to the positive +. Make sure your cables are tightned securely. A poor cable connection as well as a short in the starter windings can overheat the cables.
Jul 13, 2009 | 1994 Suzuki Sidekick
Linksys Wireless-G WRT54G Router Logo
288 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
