Question about Xantrex Technology Trace Series Inverter / Charger 1500w
I Have a trace DR 2424 inverter with low output voltage, about 75 volts no load and 60 volts under load. Any hints appreciated. Bill
  • 68 Answers
SOURCE: Trace inverter high AC voltage
Not to worry. First thing is you are probably not using a true RMS volt meter. You are reading an average voltage of peak. You have a sine wave inverter. The RV 2012 has a peak of 164 volts. I could go into much more tech detail but may confuse you. If you want to learn more her is a link from my dealer tech sheets. Also if you have checked voltage in a float state it will read high.
Hope this helps you
Thank you for using Fixya and please rate us.
Jerry
http://www.xantrex.com/web/id/325/DocServe.aspx
Posted on Mar 26, 2009
  • 12 Answers
SOURCE: Low voltage output from inverter
Ignore peak, that means nothing. RMS * 1.414 = peak. RMS is the actual usage you will get, thats all. Peak doesnt mean it will supply the peak wattage for a short period of time: salesmen with no electrionics training tell people this and its a big fat lie.
See what the unit is drawing, use a clamp-on ammeter on ONE lead (not both, or it will read 0). That shoudl tell you if your device is drawing too much. You should only be able to run that device UNDER the 800 Watts (watts = volts * amps, not including loss of efficiency which might be 10% or more, and even greater when warm)
Source: I'm a maintenance electrician. Like the home-builder kind, same apprenticeship (more hours; 10,400) but also with much industrial training in PLCs, transformers, converters, inverters, motors, controls, etc.
Posted on Mar 31, 2009
  • 5 Answers
SOURCE: Trace DR 2412 inverter won't run older front-loading washer
IF your washing machine is a conventional model with a common AC induction motor, waveform isn't the problem. Normal starting current for typical AC induction motors is usually 5 to 7 times the rated running current. Even though that current draw only lasts a fraction of a second, it's marginal for a 2.4 kw inverter's surge capacity. The trick of switching on other small loads (preferably resistive loads like incandescent bulbs) before starting the washer may help. Another area to check is your battery cables and connections The inverter pulls a huge amount of current to produce it's max surge output and even a little resistance in the battery circuit may cause the inverter to trip off. If you've got one of the fancy new electronic controlled washers with a D.C. motor, (so called energy saving or high efficiency models) then the waveform may be an issue and a pure sine wave might be needed.
Posted on Aug 28, 2009
SOURCE: new batteries new cables still 99 volts output
What kind of inverter is it and what kind of meter are you using to check the voltage with? If the inverter puts out modified sine wave, you have to use a true rms volt meter to accurately check the voltage with. A non rms volt meter will show a low reading.
Posted on Sep 21, 2009
snowghost1
  • 784 Answers
SOURCE: I have 2 DR 15/24's,
hello,
here is the pdf manual for your inverter,, it will walk you thru the equalization process of your system. www.donrowe.com/user_guides/xantrex/trace_series...
the equalization information is on page '2-14'
if you are still having troubles you can write me back here and I will walk you thru the process.
you can also visit the xantrex web site at : www.xantrex.com.
have a great day,
c...
Posted on Feb 18, 2011
Trace SW 5548 output ac voltage is 164 volts, under a medium to heavy load it will lower to a 142 or 144 volt output.
Is your 12 volt source able to supply 1500 watts of power? You can't draw more watts out than you put in. What is your 12volt source? A standard automotive alternator cannot make close to 1500 watts.
Jun 07, 2011 | Xantrex Technology Trace Series Inverter /...
I have a Yanmar 4.5 KVA Generator running into a Trace 2.5 KVA inverter/charger, the inverter requires 205-220volts to operate,once the inverter connects the voltage drops on the genny over a ten second+-...
try adjusting the gen voltage at no load to run at 240 volts
when the load comes on it will drop back to 220-235 volts
check the load output from the inverter as 2.5 kv is nearly 80% of the genset duty cycle
4.5 KV is start up KV and the duty KV is around 3..8 kv not the plated 4.5 kv
to get constant 4.5 kv you will need a 5.5-6 kv unit
if the current draw from the inverter is excessive , the engine may not have enough in reserve to over come the load and will not pick up the rpms
take the gen set and the inverter to a shop that has a calibrated load bank to test accurate power output to determine if the engine needs an overhaul
May 28, 2017 | Electrical Supplies
My generator is not putting out the proper voltage? it's only putting out approx 75 volts on the 120 volt circit. i adjust the idle to full out and i get approx 112v.
Most low voltage conditions on generators are simply due to a low engine rpm. Most modern generators are 2- pole windings. So your engine rpm should theoretically run @ 3600 rpm. which will produce 120/240 volts @ 60 HZ. In actuality You want to set your rpm's @ Approx. 3720rpm no load. About 62.5 Hz. Without getting to technical this will give you your desired 120/240 volts loaded. Hope this helps.
Aug 09, 2010 | Northstar Electrical Supplies
New batteries new cables still 99 volts output from trace inverter
Sep 21, 2009 | Xantrex Technology Trace Series Inverter /...
I got a output voltage of 100.1 on a trace dr3624
The rms voltage is what counts, because it tells how much power the output will deliver to a resistive load. Inexpensive multimeters on their AC ranges are usually average-responding rms-calibrated meters. This means they measure the average of the absolute value of the AC component of the signal, and display that average multiplied by about 1.11 (actually, pi over sqrt(8)), the ratio of rms to average value for a pure sine wave. That way, the meter will give the right rms reading for a sine wave.
If the signal is a square wave, where the average and rms values are equal, the average-responding meter will read 11% too high.
Many inverters put out a modified sine wave (MSW), which sits at zero for a while, goes to a constant positive level for a while, goes back to zero for a while, and goes to a constant negative level for a while to complete the cycle. The positive and negative parts of the signal have the same magnitude and duration.
The rms and average values of an MSW depend on its duty cycle D, the fraction of a cycle for which the signal is not at zero. In a well-designed inverter, the duty cycle will be adjusted when the DC input voltage goes up and down to maintain the nominal rms output voltage. If we use peak voltage Vp to mean the magnitude of the positive and negative voltages the signal goes to, then Vavg for an MSW is equal to Vp times D, and Vrms is equal to Vp times the square root of D.
The duty cycle for which an MSW will have the same rms to average ratio as a sine wave is 8 over pi squared, or 81%. For any duty cycle less than this, an average-responding meter will read a lower voltage than the inverter rms output, and for a duty cycle higher than this, the meter will read too high.
If your MSW inverter is putting out 120 volts rms and its duty cycle varies from 50% to 75%, the meter reading will vary from 94 volts to 115 volts. I avoid the problem by using a Radio Shack 22-174B true rms digital multimeter.
Aug 27, 2009 | Xantrex Technology DR2412 Inverter /...
My aims 2000 pure sine wave inverter is pluged to 2 240amp/h 6 volt batteries. When | plug in a 1800 watt hairdrier i get an alarm as if the batt. were to low. they are new and at full charge. is the load...
Your inverter has a peak of 3000 watts rating and should power that hair dryer. Make sure your batteries are in good shape. The inverter can only put out what it takes in. 1800 watt demand on the inverter requires 1800 watts from the batteries.
Jul 14, 2009 | Inverter Aims Pure Sine Wave Power...
My tram 2512 is stuck in waiting for AC mode, ac is clearly reaching the unit, both by shore power and genset. What could the problem be?
If you are referring to a Trace 2412 inverter, which series is it? An SW or a DR series? In either case, if it won't accept generator power, but the AC input indicator is flashing, the problem is most likely the generator output power is off frequency or voltage. Trace inverters will only connect when the AC input is within certain limits. I'd suggest checking the frequency and voltage output of the generator. If it won't connect to shore power, check the voltage from that source. Make the voltage checks at the inverter input terminals.
May 11, 2009 | Xantrex Technology Trace Series Inverter /...
I am thinking this a high impediance device problem and this is normal operation - the user manual of my inverter warns about use with high impediance devices - if not I am interested also...
Jan 23, 2009 | Electronics - Others
Xantrex Technology Trace Series Inverter / Charger 1500w Logo
191 people viewed this question
Top Xantrex Technology Electronics - Others Experts
Jimmer_9
Level 1 Expert
richie46
Jay Plesset
Are you a Xantrex Technology Electronics - Other Expert? Answer questions, earn points and help others
