Question about Quinny Buzz Three Wheel Stroller
How do you adjust the seat straps on the stroller. How do you take off the sear cover?
  • 286 Answers
Hi i think this video will answer both your questions if not please leave a comment and i will help out further
http://www.youtube.com/watch?v=LijugaF1nFA
this is from dorel quinny
Posted on Nov 13, 2010
How do i remove the seat cover from Maclaren Quest Sport 2010 model stroller?
Dear maclaren were do I buy these steps at my nephew is disable he loves this stroller so much but straps are broken were can I purchase them at or please get me in the right direction. Thank you oscar o
Mar 09, 2011 | Maclaren Quest Sport Stroller
Hi I would like to replace the straps on my Quinny Buzz 3 stroller. Where can I buy a new set of straps? Thanks
I don't believe they are replaceable as such as they are an integral part of the seat frame and are sewn in. You could replace the seat unit - many are sold cheaply on e bay, or you could clean them if they have gotten a little grubby. I found soaking them in vanish oxi action multi and then rinsing them next day made them look good as new. (I took the memory foam cover off, then balanced an ice cream container with the sprayed straps in between the strap anchor points so as to keep the wet straps contained - they dry quite quickly afterwards)
Jun 27, 2010 | Quinny Buzz Three Wheel Stroller
The seatbelt seems to rub badly on either side of my child's head
Hi you can get harness extensions from Dorel free a lot of peole have the same problem, I take it you bought it in 2007. If so you can also get the xl seat cover for 18mth + free from dorel
May 10, 2010 | Quinny Buzz Three Wheel Stroller
Change the seat cover on quinny buzz
Hi the seat is attatched to the frame with a hard edging.
1st; take it off the bootom which is velco
2nd; slide the seat cover out of the frame from bottom to top, this is a tricky
3rd; The top of the seat cover is attatched the same way but sideways, you need to undo the straps from the top then feed them through the holes in the cover.
4th; Attatch new seat cover the same way but in reverse.
May 01, 2010 | Quinny ZAPP Stroller
How do we attach the new seat cover to the graco
madelin, do you have still your stroller manual? you can check it there.
If not, may I know your graco stroller model?
Jan 31, 2010 | Baby Gear
How to fold a beby trend expedition single
TO FOLD STROLLER
• Close the canopy as described in the canopy section. Recline seat by releasing buckle as described in seatback positioning section.
• The stroller is folded by simultaneously pulling each trigger fold. . When the fold latches are released, the handle will begin to fall toward the floor. Release the fold buttons and press downward on the stroller handle until the stroller is completely folded. Secure the stroller in the folded position by hooking the fold latch, located on the right side of the stroller, over the rivet that protrudes from the frame.
CANOPY
* The canopy features a ratchet system that allows the canopy to be moved forward to block the sun or wind. To adjust the canopy’s position, push forward or backward on the canopy until the canopy is in the desired position. See figure 23.
SEATBACK POSITIONING
* The seat has a multiple position recline that is controlled by a strap and buckle assembly behind the seat. . To recline the seat, loosen the strap through the buckle and adjust to the required recline position. To place the seat back in the upright position, press upward on the seat back with one hand while pulling the strap through the buckle with the other. The strap will lock automatically.
http://www.babytrend.com/download/2007061021349109CT_instructions.pdf
Apr 28, 2009 | Baby Trend Expedition LE Jogger
How to adjust straps on the evenflo journey clairmont carseat?
You posted this in August so I'm not sure if you figured it out yet. I was loving this system until I ran into this problem tonight especially when I couldn't find this in the manual, but I figured it out. On the back of the car seat you'll see the black thingys that keeps the straps in place, above them are these two clips that you have to push down. push down the clip and pull the black thing up , it will release from car seat and from there you're able to adjust the straps height. I already contat evenflo about not putting this info in there manaul.
Aug 09, 2008 | Evenflo Journey Premier Stroller
Eddie bauer travel system manual (bryant)
Hi, on the reverse side of the seat is a strap that is fastened by a clasp. By squeezing the clasp, you allow the straps to pass through the clasp, and adjust the strap length. By doing this the angle of the seat can be adjusted
Jun 05, 2008 | Eddie Bauer Lightweight Travel System...
Evenflo journer
on the back of the carseat the are black plastic holders the straps go threw and there is a part in the middle that you push down and you pull the front staps to loosen or the back straps to tighten
Feb 17, 2008 | Evenflo Journey Premier Stroller
How do i get the seat of to wash?
I was able to find an online instruction manual for this stroller. From that manual, I was able to find the following instructions for removing the seat for cleaning.
"10 REMOVING AND REFITTING THE SEAT COVER
Remove hood from stroller if fitted.
A Twist shoulder strap end buckles and feed through holes.
B Feed waist and crotch straps through holes.
C Unclip seat cover retaining straps.
D Unfasten seat fabric from handle tubes and seat base.
E Slide fabric from seat back and base.
F When refitting seat fabric, insert seat back support tubes
into fabric slits.
G When refitting seat fabric to seat base, loop fabric flap over legrest
strap and pass crotch strap buckle through both holes in seat fabric
and then hole in seat base.
H When refitting shoulder straps, twist buckles and feed through holes."
Dec 18, 2007 | Maclaren Quest Mod Stroller
Quinny Buzz Three Wheel Stroller Logo
147 people viewed this question
Top Quinny Baby Gear Experts
Jennifer Rock
Jennifer Rock
Oloyede Monsuru
ray gallant
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
