Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
The second drawer won't drain...can you please advise what to do. Thanks
  • Fisher and P... Master
  • 3,247 Answers
It could be due to some blockage in either drain sump or the filter plate or the pump rotor.
If you do not have the user manual then post a comment and I will send you the link. The cleaning process is described in the user manual.
Posted on Nov 13, 2010
Monogram DISP480DXASS jack hammer noise behind the Climate Control Drawer.
By the way you discribe it, it sounds like it's going into defrost mode check and make sure freezer side isn't iced over or that the drain isn't iced over if it's a side by side drain should be at the very bottom of freezer side usually hidden behind a piece of plastic if it's a top and bottom the drain will in the freezer very back bottom also hidden hope this helps
Mar 04, 2016 | Refrigerators
DD-603 cycle and draining problems.
check your kitchen drain as it might be blocked or if you have a garbage disposal (kitchen insinkerator) make sure it is cleared before running the dishwasher.
Jul 18, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fabric conditioner won't drain from the drawer of my washing machine
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Feb 08, 2012 | Washing Machines
The machine drains but does not spin. please can you advise what this could be? Many Thanks
check the safety switch in the door,, the machine won't spin if thats not in the closed position
May 30, 2011 | Washing Machines
Dishwasher top drawer was dead so i was told to change the heater under the drawer i did that but now i got more broblems the top drawer lights up just beeps for a second and does nothing as for the...
Whenever the Drawer is Dead, there could be a couple of Reasons. First, it could be a Bad Heater Plate or Bad Control Board on the Front.You could remove the Control Board and Check.More often, you would find visually, that they are Hot and Bad.
On Few Models, there are two Circles.You could use a Pliers and twist them out.The Front will Slide and you could check all the Connections.Make sure they are tight and secure.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 08, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Bottom drawer won't clean or drain
My top draw F&P won't drain, it seems to want to go thru the cycle, but then leaves about 3 inches of water. no codes are displaying. No extra beeping. please help!
Jun 30, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & pakel dd-603ss top drawer wont drain
Have you cleaned the drain filter ? If not, clean that ( it is beneath the rack where the utensil bin is normally positioned and accessible by lifting up the plastic door..If that is clogged up then your drain flow will be restricted. Also, check to make sure the drain line is not restricted ( pinced or clogged). .And yes , the drain is pumped out. If these tips do not get you going, please write back and let me know.. will help get your dw going ...
Regards
Oct 10, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Front loader won't start
first make sure the door is closed good look for the door locked light to come on second open and close the dispenser drawer make sure its closed all the way as there is a switch in there that wont let it start if not closed then advise me and we will go from there
Jan 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Drainout procedure incomplete
please clarify "The lower drawer does not have a similar problem." did the "but we lowered it by about 30mm as he required." make any difference? run this test: disconnect power to the unit. then find and disconnect the drain pump's wires (or connector). then apply power to the pump (I am assuming you have a 115VAC house supply) by a separate wire cord. run the pump on this cord until you see all the water pump out. if it does, then your timer is shutting down the pump too early. the water level sensor is mostly used for the other case during water fill only.
May 25, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
98 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
