Question about Kenmore Washing Machines
I have a kenmore front loading washer serial # XC34713478. Just before final rinse, the water pump extracts all of the water out of the system but it never stops pumping. I can stop the washer, turn the control knob 1 click to the right, restart and the washer will finish it's cycle. It just gets hung up before the final rinse. Somehow the cycle doesn't know when it's suppose to stop the water pump and continue with the final rinse. I've already replaced the water pump. What's next?
  • 1 more comment
  • dennistrunne Nov 13, 2010
    I have the dryer attached to the top of the washer. There is a lot of work involved for a "why not give it a try solution". How does the water pump know when there's no more water to pump, and what tells the system to move on to the next cycle. This problem only presents itself in the Eco-cycle mode. The power wash mode seems to be working just fine. In other suggestions before I waste half a day on why not give it a try, can't hurt theory?
    Ok, so what next. What's the fix? Do I replace the control behind that knob?
  • dennistrunne Nov 15, 2010
    You know I don't mind taking this thing apart to fix it. I would just like to be able to diagnose the problem before I start wasting time. For some reason the problem has at least temporarily fixed itself. Seems to be working fine in all cycles. However I'm a little hesitant to run any loads without carefully watching it. When it stuck it tried to burn up the pump as it probably ran for an hour or more. The pump still worked but it made a lot of noise. It still hung up once after I installed the new pump, but has worked ever since I tried another cycle. Is it possible these "controls" are now working in sync with the new pump, or is this a glitch that's liable to resurface at an inopportune time?
  • Kenmore Master
  • 8,220 Answers
The fancy control monitors the water right? It knows when it took too long to fill and to drain right?
I would remove the top and blow out the sediment in the tubing to see if that fixes it before ordering any expensive parts. I have a kenmore front - themobilian_125.jpgremove that tubing from that pressure switch and blow it out. It don't hurt to try. themobilian_127.jpg Manual and more photos
Posted on Nov 12, 2010
  • 1 more comment
  • Dan Webster
    Dan Webster Nov 13, 2010
    You probably have a glitch in the control. If you only have the problem in one cycle. If what I suggested was really the cause you would be having the same problem in all the cycles.
  • Dan Webster
    Did you say all the wash cycle were fine except for that one? I do not know that I would bother in that case.
  • Dan Webster
    You still have to remove the top to get to the controls.
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Nov 05, 2015 | Kenmore Washing Machines
Lg front loader when during the cycle is the bleach dispenced
bleach? do u mean detergent? normally machines run pump/then start to fill.water will pass through drawer then they heat /wash/drain/spin then refil for rinse conditioner/spin rinse drain fast spin end pretty much
Aug 08, 2014 | LG WM2101HW Front Load Washer, White, 4.0...
My kenmore 3.5 front load does not drain during the final rinse and spin cycle. It does clear all of the soap and water during wash.
Check for foreign objects in drain pump or if not defective pump. Accessible from bottom front panel, two screws holding it in place
Jun 05, 2011 | Kenmore 44102 Front Load Washer
Not all the water is extracted from neptune 2000 loads. final rinse makes sound like sand grinding? Front end washer
Not Good you have a bad center bearing not worth fixing will run you a easy $500-$800 I see this all the time you can run it till the shaft locks down onto the bearing sorry for the trouble.
Jan 06, 2011 | Maytag Neptune MLE2000A Front Load Stacked...
Kenmore Elite HE3T model 110 44932 200 I'm getting an F02 error code during the rinse cycle. I've lost my manual - pls advise thx
Clean Out your Water pump filter if that is not dirty replace the water pump. f02 is Code for LD Long Drain something is clogging your water drain in the washer or your kids rock or pen got stuck and chewed up the blades on the water pump
Jun 06, 2010 | Kenmore 44932 Front Load Washer
Front load washer, will not do final rinse
A lot of times it is the strainer clogged at the pump. Hope that helps.
Sep 08, 2009 | Frigidaire Affinity ATF7000E Front Load...
Final spin /rinse cycle won"t stop
It's usually a control board problem. sorry for the bad news :(
Jul 07, 2009 | Maytag EPIC MFW9700S Front Load Washer
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Mike Squire
