Question about Sony STR-DA5000ES Receiver
Got sony str-da5000es and has code 11 on it, can somebody please tell me how to reset it Thanks
Noggin
  • 944 Answers
SOURCE: sony receiver str-da2000
Here is the link for the user manual if you need it; http://esupport.sony.com/US/perl/model-documents.pl?mdl=STRDA2000ES®ion_id=1 Check page 54 for details of the error message - it should disappear if the speakers are connected properly and the unit is switched off and on. Check page 17 for speaker connection details, and ensure they are all correct. Check page 19 for details of the factory reset/memory clearing. Hopefully this will clear the error code and let you set the unit up. Hope this helps, please ask again if no luck :)
Posted on Jul 14, 2007
SOURCE: Sony STR-DA5000ES 7.1 Receiver
its for digital decoding of the sound source. You need to connect a digital cable (ie optical) from the DVD player to the optical input in the receiver. The receiver should then decode the source into multichannel components ie 5 channels for example
Posted on Jul 27, 2008
SOURCE: How do I correct protector code 11 on sony str
Sometimes the protector code means audio amplifier IC fried and need to replace him
Posted on May 13, 2009
  • 36 Answers
SOURCE: mySony str-da5000es is showing error code 11 and
error code 11 (protector) - According to the manual, 11/PROTECTOR means, "Irregular current is output from the speakers. Turn of the receiver, check the speaker connection and turn on the power again." Most likely, a strand of speaker wire is shorted to the chassis at one of the speaker terminals.
Hope this helps !
Posted on Jun 18, 2009
bud1643
SOURCE: I need to reset my
1) Turn unit off.
2) While holding dowm the MUSIC button, press the ON/OFF button.
"SF Initialize" appears in the display and all sound feilds are reset to the initial sttings.
Posted on Oct 17, 2010
I turned Zone 2 on on my Sony AV System and now can't turn it off. There must be something simple that I'm overlooking, I just can't find an off function. The remote says RM-AAE003 R on it. Thanks for...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-STR-DA5000ES-Receivers-manual/id/387ag920/t/2/
Page 18 tells how to reset the Receiver to its factory defaults. But if Zone 2 or 3 are on it won't work. Quite the Catch-22, huh?
It claims the RM-US106 should be the remote, which has explicit Zone Keys right on it.
This is SONY's own post for that remote (which requires its own manual) and it seems to be a dead end.
http://esupport.sony.com/US/perl/model-home.pl?mdl=RMAAE003&LOC=3
I
Mar 09, 2011 | Sony STR-DA5000ES Receiver
I need to reset my Sony DA5000ES to factory settings!!? Please help!!!
1) Turn unit off.
Oct 17, 2010 | Sony STR-DA5000ES Receiver
My sony str- is getting a sony protector check code 22. Is that a fuse problem or do i have to get sony to fix it? napa.king@yahoo.com
Unfortunately this is not a fuse problem, as the fuse would burn before the protector check code appears. Probably there is a short circuit and you should take to an authorized sony repair shop. Good Luck.
Flavio/BRAZIL
Jul 22, 2010 | Sony STR-DA5000ES Receiver
I get a message "protector check code 11" and then it powers off
Page 59 of the manual (avaliable at retrevo.com after you register)...
"PROTECTOR/CHECK CODE 11
Irregular current is output from the speakers. Turn off the receiver , check the speaker conenction and turn on power again"
What this means is it senses a short circuit in one or more of the speaker paths. Disconnect all speakers, see if it works with none; then start connecting speakers again until you find the problem.
Feb 13, 2010 | Sony STR-DA5000ES Receiver
Can i have two 400 w spekers on sony DA5000ES?
Be very careful here.
If you put the speakers in parallel, the amp may well blow (4 ohm speakers in parallel would kill it at high volumes), and it may take the speakers with it.
I wouldn't try to extract more than the rated power from the amp. At it's rated output, it's seriously distorting, to a point where it becomes unlistenable. So, trying to ramp up the power further would only make it sound worse.
Putting the speakers in series is a safer route for your amp.
Jan 13, 2010 | Sony STR-DA5000ES Receiver
PROTECTOR/CHECK CODE 21 COMES ON ONCE A WEEK OR SO.
STR-DA2000ES, STR-DA3000ES and STR-DA5000ES:
Doument Reference: E23914196
Subject/Description: "Protect 21" is displayed when connecting to speaker/powered subwoofer combo
SYMPTOMS
Protect 21 is displayed when connecting to speaker/powered subwoofer combination model such as the SA-VA7000ED. The problem was also found to occur when connected to the Definitive Technology POWER MONITOR 500 and POWER MONITOR 700 series speakers.
CAUSE
The DC detection circuit is triggered when the speakers are connected.
RESOLUTION
Add a 4.7k metal oxide film resistor across capacitors C1319 and C1329 located on the D-AMP board.
Hope this helps. =)
Oct 23, 2009 | Sony STR-DA5000ES Receiver
MySony str-da5000es is showing error code 11 and shut off by itself after few seconds.check and disconnect all speakers, unplugged power from wall and still showing error 11. am missing something in here...
Hope this helps !
Jun 17, 2009 | Sony STR-DA5000ES Receiver
Jul 23, 2008 | Sony STR-DA5000ES Receiver
No Digital Output
"Unlocked" only means that it isn't detecting a digital signal on the input. "Locked" conversely means that it has locked on to a digital signal. My Sony receiver behaves this way.
Dec 05, 2007 | Sony STR-DA5000ES Receiver
Sony STR-DA5000ES Receiver Logo
111 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
