Question about SanDisk Sansa m240 MP3 Player
Can't make the player turn on. What do I do?
  • 593 Answers
First try and reset the player.
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
If that does not work try this,
Remove the battery - Power cycle the player
1. Connect the device to the PC.
2. Leave the device connected for about 2 minutes.
Turn on the device
1. Disconnect the player from the PC.
2. Insert a fresh AAA battery into the player.
3. Turn on the player.
STEP 1 - Connect the device to the computer
1. Remove the battery from the player's battery compartment.
2. Put the hold/lock switch to lock.
3. Plug in your device to the computer.
STEP 2 - Format the device
1. Double-click My Computer.
2. Right-click on the player, which might show up as a Removable Drive, select Format.
3. Click Start.
4. Click OK when a "Format Complete" dialog appears.
5. Click Close.
Posted on Nov 13, 2010
Samsung HT-C330 how can i convert to multi region my home theather player because i bought it in europe now i'm using here in the philippines
Do the following to make you dvd player region free,
1. Remove disc from tray.
2. Switch off player and unplug from mains.
3. Wait 30 seconds, then reconnect mains.
4. Turn on player with remote. Wait for player to finish loading and display 'no disc'.
5. Press enter on remote. (There will be no on-screen response.)
6. Press 8, 4, 2, 6, 9 on the remote. (There will be no on-screen response.)
7. Press enter on the remote. Player will automatically shut off.
8. Turn player on. (NOT FROM REMOTE)
9. turn off. (NOT FROM REMOTE)
10. Turn player off then on again. (Maybe you can try 2 ways turn on and off and on again and just turning on)
11. Player is now region-free.
12. Enjoy.
ok
Jul 16, 2011 | Televison & Video
I ahve a no name mpe player and try to sart it and it just comes up with the loading symbol but will not go any further
Hi there
Flip the MP3 player's "Hold" switch to "Off" if the switch is on. Depending on the MP3 player you own, this switch is likely located at the side or top of the player. Once the switch is off, try to turn the player on.
Let the battery of the MP3 player die. A frozen MP3 player is technically still running, and thus the battery for that player is being drained. Wait until the battery is fully dead before moving to Step 3.
Charge the MP3 player using either a computer (that's turned on) or an electronic MP3 charger. Charging the player's battery may "jolt" the player out of its frozen state. Connect the player to the computer or charger via the player's USB cable. Charge the player for 30 minutes before attempting to turn it on.
Sync the player with the appropriate software program (for example, Windows Media Player) for the MP3 player. Connect the player to the computer as described in the previous step. Open the software program and click the "Sync" tab at the top or side of the program. If necessary, click "Start Sync" underneath the tab. The name of the player appears under the "Sync" tab if the player has synced successfully. Try turning the player on once it has synced with the program.
Press the small "Reset" button on the MP3 player. This hard reset shuts the player down completely. Use a pin, tack or thin nail to press down the very small "Reset" button on the side or back of the MP3 player to reset the player. Then, try to turn the player on.
Sep 16, 2010 | Jwin MP3 Player
How to turn off nwz-a826 becuse its not turn off jut standby
To turn the portable player on, press the Play/Pause button until the screen appears. To turn the portable player off, press and hold the Play/Pause button until POWER OFF appears.
To save the battery consumption, the player will do the following:
After turning on the power, if there is no operation or playback performed for about 1 minute, the power of the player turns off.
If there is no operation for a certain period of time while in stop mode, the display turns off automatically and the player enters standby status. If there is no operation for the next 30 minutes, the power of the player turns off.
Jul 27, 2010 | Sony Walkman NWZ-A826 Digital Media Player
Cant find intructions?
To turn on the player
Press the >|| (center round button) button to turn on the player. The player resumes the operation from the point where you last turned off.
If “HOLD” appears in the display, slide the HOLD switch in the opposite direction of the arrow (--->) to release the HOLD function.
To turn off the player
Press and hold the >|| (center round button) button to turn off the player. “POWER OFF” appears.
Hints
If there is no operation for a certain period of time while in stop mode, the display turns off automatically to save the battery power. If there is no operation for an extended period, the player turns off completely. The batteries are consumed a little in this status.
You cannot operate the player when it is connected to a computer. Disconnect the player before operating the player.
Link to manual: NWZ-B142 Manual
May 26, 2010 | Sony Walkman NWZ-B142 MP3 Player
Sansa clip on turn on
can u more specific? u mean how to turn on your sansa clip or your clip can't turn on?
if the first one:
u may can see the instructions.
if the second one:
SOLUTION 1 - Reset the player.
SOLUTION 2
- Make sure the player is fully charged.
1. Connect the player to the PC.
2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode, then connect it to the PC.
3. Leave the player connected for approximately 2 hours to charge.
4. Disconnect the player from the PC.
5. Verify if you can turn on the player.
6. Reset the player if necessary.
Feb 25, 2010 | SanDisk Sansa Clip MP3 Player
My sansa will not turn on
Make sure player is fully charged. Connect the player to the PC. Make sure the computer detects the player.
NOTE: you may need to switch the player to MSC mode, then connect it to the PC.
Leave the player connected for approximately 2 hours to charge. Disconnect the player from the PC. Verify if you can turn on the player. Reset the player if necessary. Reset the player. To reset -- Slide and hold the Power switch up for approximately 20 seconds. Release the Power switch. To turn the player on, slide the Power switch up then release instantly.
Feb 14, 2010 | SanDisk Sansa Fuze MP3 Player
When I disconnet the sync cord and go to turn on the sansa e-250 it doesn't turn on
Make sure player is fully charged. 1. Connect the player to the PC. 2. Make sure the computer detects the player.
3. Leave the player connected for approximately 2 hours to charge. 4. Disconnect the player from the PC. 5. Verify if you can turn on the player. 6. Reset the player if necessary.
SOLUTION 2 - Reset the player. Resetting the player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.+
Feb 13, 2010 | SanDisk Sansa e250 MP3 Player
My sansa disc MP3 player is not turning on at all I have connected to my computer and it still does not turn on I have used new batteries but nothing seems to work can you please halp me. My sansa mp3...
Washed? Water damage is irreversible - that player needs to be replaced. Call Sansa and say your player won't turn on - don't mention water. See what they say.
Jul 05, 2008 | SanDisk Sansa Clip MP3 Player
Heed to unlock an samsung dvd ht-x30
1. Remove Disc from Tray.
2. Switch Off Player
3. Wait 30 Seconds, Then Reconnect Mains.
4. Turn On player with Remote Control. Wait for player to Finish Loading and Display 'No Disc'.
5. Press Enter on Remote Control. (There will be No On-Screen Response.)
6. Press 8, 4, 2, 6, 9 on the remote. (There will be No On-screen Response.)
7. Press Enter on the Remote Control. Player will Automatically Turn Off.
8. Turn Player On.
9. Open Tray
10. Close tray.
11. Turn Player Off then On Again.
12. Player is Now Region Free
May 05, 2008 | Televison & Video
My mp3 won't turn on!!
Sorry, as far as i know you can't, you nead to reset: 1. Recharge the product by connecting to the pc (pc must be running). 2. Press the reset button using a sharp tool. Wait 10 minutes then connect the player and pc. (The reset button is between the FUNC and MODE buttons.) 3. Turn the player off and press the mode button while making the player and pc connection. 4. The message ¡°USB Connected¡± displays when turning the player on. 5. Disconnect the player and pc. 6. Connect the player and pc after turning off the player. The player is charged in about 2 hours if the player is off. 7. Upgrade to the latest firmware (Ver. 1.11 or higher).
Nov 14, 2005 | Mpio FG200 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
860 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
